Information electronics restarts / shuts down
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
servusssss
dieselschrauber likes this.
Post25-08-2021, 10:50    Subject: Information electronics restarts / shuts down Quote
Hello everyone,
I hope someone here can help me.
My radio/navigation system in my Sharan has started turning on and off repeatedly.
After sending the device to a repair service, the diagnosis was that it could not be repaired. Since a new one costs over €1500, I found a replacement part from a parts supplier. However, it is Revision D, not Revision B.
The component protection could be replaced at the dealership, but now none of the features work, such as the navigation system, hands-free calling, or anything beyond the radio.
My question is, can this device actually work in my vehicle? Encoding was taken over by the faulty component.
Here's the Autoscan result.
Thank you very much for your efforts!
Autoscan.txt
 File name:  Autoscan.txt
 File size:  22.99 KB
 Downloaded:  490 times
vag-driver
Post25-08-2021, 14:11    Subject: Information electronics restarts / shuts down Quote
The first thing I notice is that the battery voltage is too low, at 12.15V. That could also be the reason why there are so many error entries.
Why is the address for the radio not available?
Andreas
servusssss
Post25-08-2021, 19:46    Subject: Information electronics restarts / shuts down Quote
Hello Andreas,
Thank you for the response.
I cannot answer your question about whether there is an address for the radio.
When checking the voltage, I need to check the battery.
Nothing is displayed, neither the PDC (Park Distance Control) nor anything else.
Right now, only the radio is working.
SG
vag-driver
Duese likes this.
Post25-08-2021, 20:37    Subject: Information electronics restarts / shuts down Quote
Why don't you go back to the dealer and report the problem? Who installed the radio? Is it connected correctly?
Andreas
servusssss
Post25-08-2021, 20:59    Subject: Information electronics restarts / shuts down Quote
I was already at the doctor's for several hours yesterday.
Tomorrow, I'm going to try again, let's see if everything works out this time.
I just wanted to check if anyone is familiar with this.
SG
Dagomanu
Karma: +55 / -0   Thank you, like it!
Post26-08-2021, 8:46    Subject: Information electronics restarts / shuts down Quote
Hello, please perform component coding and restore function activation.
Best regards, Dago.
vag-driver
Post26-08-2021, 9:01    Subject: Information electronics restarts / shuts down Quote
We don't know what the "Freundliche" (Friendly) person did, or what they should have done. But obviously, some steps are missing, otherwise the complete functions would be available.
Andreas
servusssss
Post27-08-2021, 4:56    Subject: Information electronics restarts / shuts down Quote
Hello everyone,
Here's a quick update. The navigation and Bluetooth are now working. Unfortunately, the PDC (Parking Distance Control) display and the traffic sign display in the navigation system are not working.
Whether this can be fixed with software or coding remains to be seen.
SG
Post27-08-2021, 6:39    Subject: Information electronics restarts / shuts down Quote
We can only guess here. All we know is that a Revision B was swapped for a Revision D. We don't know if it's an RNS 315, 510, or something else.
PDC is definitely a coding topic, as it doesn't require any additional cables.
But for that, we need more information, or even just an automated scan that includes the relevant component.
servusssss
Post27-08-2021, 7:04    Subject: Information electronics restarts / shuts down Quote
Hello.
Okay, I've attached the initial scan report to my first post. It shows so many errors because I always disconnected the fuse to protect the battery. The "Radio" boat got stuck in a loop.
It's about address 5F.
Code:
Adresse 5F: Informationselek. I (J794) Labeldatei: 5G0-035-MIB-STD2.clb
Teilenummer SW: 5C0 035 680 B HW: 5C0 035 680 B
The device was beyond repair, so I looked for a replacement part that was reliable (protected component). That search only turned up the part number 8C0 035 680 D.
It works fine overall, except for the parking distance control (the graphical display on the "radio" screen). As well as the traffic sign display feature in navigation mode, which appears on the "radio" screen.
The encoding is identical to that of the B and D devices, and there are no errors in the memory. I can run an Autoscan tonight and send you the results later to show you how things are.
Duese likes this.
Post27-08-2021, 7:32    Subject: Information electronics restarts / shuts down Quote
Am I understanding correctly that you replaced part B (defective) with part D (now newly installed)?
The scan is from the old one.
The RNS510 was essentially in production for about 10 years and was often revised during that time. Just between the two generations you're talking about, there's a different display generation, and of course, there were a lot of firmware updates. It's possible that there are some "incompatibilities" due to software versions.
What does the coding say about the PDC (Parking Distance Control) display?
servusssss
Duese likes this.
Post27-08-2021, 20:39    Subject: Information electronics restarts / shuts down Quote
Hello.
Unfortunately, I haven't become any wiser.
As far as I can tell, everything seems to be okay with the coding.
The OPS (Obstacle Pre-Scanning) feature is active in the parking sensor coding, as shown in the Screenshot. Reordering the values didn't make any difference.
There's nothing to find in the "Radio" section of the encoding, but there are a lot of adjustments there, although they are incomprehensible to me.
As far as I can tell, the firmware is the biggest difference between the devices.
The "B" models have firmware in the 200s, while the "D" models have firmware in the 300s. A change is not planned by VW.
My friend is checking to see if he can get anything else.
I just ran a recent car scan and have attached the results.
Thank you for your efforts!
SG
 Codierung PDC
 File size:  242.76 KB
 Viewed:  337 times
Log-WVWZZZ7NZGXXXX.txt
 File name:  Log-WVWZZZ7NZGXXXX.txt
 File size:  17.61 KB
 Downloaded:  401 times
Karma: +807 / -0   Thank you, like it!
Post28-08-2021, 12:05    Subject: Information electronics restarts / shuts down Quote
I also find it strange that the car scan doesn't show a radio. Do you not have a previous Autoscan?
Did someone with technical expertise disable the radio in the gateway's configuration list (control unit address 19) in order to make existing errors "disappear"?
servusssss
Post28-08-2021, 15:10    Subject: Information electronics restarts / shuts down Quote
Here's a log from November 2020.
There's no more radio like I understand it.
Everything is now categorized under "Information Electronics," but I just use "Radio" because it's shorter.
SG
Log-82960km Nov2020.txt
 File name:  Log-82960km Nov2020.txt
 File size:  22.48 KB
 Downloaded:  318 times
Dagomanu
Post28-08-2021, 15:38    Subject: Information electronics restarts / shuts down Quote
Hello, it's also possible that the radio is not supported by the device. The manufacturer often provides very little information about this, so you usually need to contact the TV manufacturer or supplier directly to get any information. For that, your friendly contact would need to take some time.
Otherwise, your VW workshop could try to obtain a build-state documentation for the 5F model (if that's possible) and also use an online software configuration tool. Perform steps STG. 10, A5, 19, and 09.
Best regards, Dago.
Post28-08-2021, 17:34    Subject: Information electronics restarts / shuts down Quote
SG
Okay, that's a shame. Thank you for the feedback!
No new posts VW Touran: GRA Disengagement Explained Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interior Lights Turn On Late: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Smart Fortwo: Gear won't shift from Neutral to Drive General Tips
No new posts Radio won't turn off? Troubleshooting tips On-Board Diagnostics (OBD)
No new posts Automatic Transmission Not Shifting? Fix It! Diesel Engine Technology
No new posts The radio won't turn off Electrical Systems, Vehicle Electronics, Multimedia
No new posts A6 2.5 TDI Automatic Transmission Problems (Solved) On-Board Diagnostics (OBD)
