Marco Guest
21-05-2002, 0:02 Subject: Whining during coupling |
Hello everyone,
'Recently, my Golf IV has been experiencing an intermittent issue.'
To hear a howling sound when engaging the clutch. It usually occurs when the engine is cold.
It's making a noise and it sounds like metal is grinding against metal.
You often hear it when you're going uphill.
approaches. The clutch seems to be functioning properly.
At least it doesn't slip, and the car only has 57,000 kilometers on it. Where could the error be?
Marco
Translated on 04-07-2026, 21:26.
TL;-) Guest
21-05-2002, 8:30 Subject: Whining during coupling |
Since the car only has 57,000 kilometers (approximately 35,000 miles), it's probably not very old. Why don't you go to a VW dealership and ask about goodwill options? Perhaps the clutch fluid level is too low?
Best regards, Thorsten.
Translated on 04-07-2026, 21:27.
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
21-05-2002, 10:30 Subject: Hm... what does this mean? |
TL;-) wrote: | Perhaps the clutch fluid level is too low?
Best regards, thorsten |
Profile PM WWW Garage |
Marco Guest
21-05-2002, 22:40 Subject: Whining during coupling |
I'll try that, thank you.
Marco
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
22-05-2002, 10:26 Subject: Whining during coupling |
If there is oil present in the clutch housing,
The clutch is damaged because it is a dry clutch.
If you're referring to the hydraulic fluid used for the clutch actuation, then a...
The low level was indicated by the brake fluid level sensor, as it is the same reservoir. Tschüss
Michael II
Translated on 04-07-2026, 21:28.
