ACC Coding for A4 B8 FL After AHK Installation
Go to page: 1, 2, 3  Next
michiglaser
2007 Audi A4 Avant
Post01-08-2016, 11:34    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
Hello!
Does anyone know the correct encoding for the ACC (Adaptive Cruise Control) after installing an AHK (Aftermarket Head Unit)?
Unfortunately, the system doesn't work that way.
Sure, here's the translation:
"Thanks."
Michael.
Tuesday, July 26, 2016, 20:31:23:39738
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x86.
VCDS Version: RKS 15.7.4.1
Data as of: 20160226
Vehicle Identification Number: WAUZZZ8K5D
License plate:
Mileage: 167390 km
Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 8K (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 42 44 46 52 53 56 5C 5F 62
69 72
Mileage: 167390 km
01-Motor electronics -- Status: Error 0010.
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: Error 0010.
13-meter distance rule -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
56-Radio -- Status: Error 0010.
5C Lane Keeping Assist. -- Status: OK 0000
5F-Information Selection. I -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
Address 01: Engine Control Module (J623-CDUC) Label file: DRV\059-907-401-V2.clb
Part number SW: 8K5 907 401 A, hardware number: 4G0 907 401.
Component: 3.0TDI EDC17 H37 0002
Revision: 53H37---
Encoding: 12254012047603020000
Operating number: WSC 06208 123 12345
ASAM Dataset: EV_ECM30TDI0118K5907401A 001006
ROD: EV_ECM30TDI0118K5907401A.rod
VCID: 2E568D74718C7F4EDC-807A
"One error found:"
4330 - Functionality limited due to received error value.
U1113 00 [039] - -
unconfirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2.
Error frequency: 1.
Mileage: 167399 km
Date: 2016.07.26
Time: 20:14:39
Readiness: 0 0 0 0 1
Address 02: Transmission (J217) Label file: DRV\0B5-927-156.clb
Part number SW: 8K1 927 156 Q, hardware number: 0B5 927 156 F.
Component: 0B5 30 TDIRdW H10 0007
Revision: --H10--- Serial number: 0000000676
Encoding: 000001
Operating number: WSC 06335 000 00000
ASAM Dataset: EV_TCMDL501 A02196
ROD: EV_TCMDL501.rod
VCID: 4380CCC0CA0EE22623-8016
No error codes found.
Address 03: Brake Electronics (J104)
Label file: DRV\8K0-907-379-V1.clb
Part number SW: 8K0 907 379 CK, hardware: 8K0 907 379 CK.
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Encoding: 39DD4C
Operating number: WSC 06334 123 12345
VCID: 04020FDC8780251E5A-8050
Address 05: Access/Startup Authorization (J393) Label file: DRV\8K0-907-064-05.clb
Part number SW: 8K0 907 064 FE, hardware number: 8K0 907 064 FE.
Component: BCM2 2.0 H10 0602
Revision: 00002001
Encoding: 01A20000000000000000
VCID: 78FA6B2CCB4871FE46-802C
Subsystem 1 - Part number SW: 8T0 959 754 D HW: 8T0 959 754 D
Part number: FBSAUDIB8 IDG H60 0072.
Address: 08: Climate Control/Heating (J255)
Label file: DRV\8Kx-820-043-3Z.clb
Part number SW: 8K1 820 043 N, Hardware: 8K1 820 043 N.
Component: CLIMATE CONTROL, 3 ZONES, H04 0036.
Revision: C1000000 Serial number: 01260420120111
Encoding: 3638028080
Operating number: WSC 06335 123 12345
VCID: 33609C0092AE52A6B3-8066
2 error codes found:
01207 - Control unit for auxiliary heater (J364)
004 - No signal/communication.
Error status: 01100100
Error priority: 6
Error frequency: 1.
Lost Count: 161
Mileage: 167399 km
Time: 0.
Date: 2016.07.26
Time: 20:11:27
00457 - Body control module (J519)
013 - Please read the error memory.
Error status: 01101101
Error priority: 6
Error frequency: 2.
Lost Count: 161
Mileage: 167399 km
Time: 0.
Date: 2016.07.26
Time: 20:11:27
Address 09: Central Electronics (J519)
Label file: DRV\8K0-907-063.clb
Part number SW: 8K0 907 063 DH, Part number HW: 8K0 907 063 AH.
Component: BCM1 1.0 H14 0103
Revision: 08014001 Serial number: 00000029453401
Encoding: 26000011C134AFE20181408300001D0D4F9CE70826090201000008000401030100000024000000
Operating number: WSC 77976 150 85349
Subsystem 1 - Part number SW: 8K1 955 119 A HW: 8T1 955 119 Label file: DRV\1KX-955-119.CLB
Component: WWS 280412 H07 0070
Encoding: 00FD11
Subsystem 2 - Part number SW: 8U0 955 559 B HW: 8U0 955 559 B Label file: DRV\8U0-955-559.CLB
Component: G397_RLFS H06 0002
Encoding: 02005D
Subsystem 3 - Part number SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part number SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
01771 - Headlight leveling control unit (J431)
Error priority: 6
Error frequency: 1.
Lost Count: 161
Mileage: 167399 km
Time: 0.
Date: 2016.07.26
Time: 20:11:28
03608 - Humidifier in the fresh air intake duct.
014 - defective.
Error status: 01101110
Error priority: 3.
Error frequency: 2.
Lost Count: 161
Mileage: 167399 km
Time: 0.
Date: 2016.07.26
Time: 20:11:31
Address 13: Distance Control (J428)
Label file: DRV\8K0-907-561.clb
Part number SW: 8K0 907 561 B, hardware: 8K0 907 561 B.
Component: ACC3 H09 0100
Serial number: 00000000000000
Encoding: 008190
VCID: 316C960868B260B6C1-8064
"One error found:"
01044 - Control unit incorrectly coded.
000 - -
Error status: 01100000
Error priority: 2.
Error frequency: 1.
Lost Count: 161
Mileage: 167399 km
Time: 0.
Date: 2016.07.26
Time: 20:11:27
Temperature: 33.0°C
Voltage: 12.16 V
Hex value: 0x005D
Speed: 0.0 km/h
Transverse acceleration: 0.00 m/s^2.
Address 15: Airbag (J234)
Label file: DRV\8K0-959-655.clb
Part number SW: 8K0 959 655 N, Hardware: 8K0 959 655 N.
Part number: Airbag VW-AU10 H45 0610
Serial number: 003KFD92NTVG
Encoding: 30514435363030303030554A304C384B3053
Operating number: WSC 49559 001 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 489ADBECF328C17EF6-801C
Crash sensor for driver-side side airbag:
Serial number: 6334MSME6D0355106
Crash sensor for the side airbag, passenger side:
Serial number: 6344MSME6D23024EI
Rear side airbag crash sensor (driver's side).
Serial number: 6352QSME3512527EG
Crash sensor for rear side airbag, passenger side.
Serial number: 6362QSME271305444
Crash sensor for front airbag, driver's side:
Serial number: 63732SME52110644M
Crash sensor for front airbag, passenger side:
Serial number: 63832SME57113872Y
Address 16: Steering Wheel Electronics (J527)
Label file: DRV\8K0-953-568.clb
Part number SW: 8K0 953 568 M, Hardware number: 8K0 953 568 M.
Component: Steering module H03 0004.
Revision: -------- Serial number: 90372LDI0027E
Encoding: 0000DF
VCID: 4482CFDCC700E51E1A-8010
Component: E221 - MFL H03 0003
Address 17: Terminal block module (J285)
Label file: DRV\8T0-920-xxx-17.clb
Part number SW: 8K0 920 931 F, HW: 8K0 920 931 F.
Bauteil: KOMBIINSTR. H35 0540
Revision: 00000000 Serial number: NTL74JL4D
Encoding: 136F110047010008000000
Address 19: Diagnostic interface (J533)
Label file: DRV\8T0-907-468.clb
Part number SW: 8R0 907 468 D, Hardware: 8R0 907 468 D.
Component: GW-BEM 5CAN-M H10 0025
Revision: 1Z070014 Serial number: 1441Z12403005C
Encoding: 00CF07FF00
VCID: 408AC3CCD318F93E3E-8014
Subsystem 1 - Part number SW: 8T0 915 181 HW: 8T0 915 181
Part number: J367-BDM, Hella H03 8041.
Subsystem 2 - Part number SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Address 42: Door electrical driver (J386)
Label file: 8K0-959-793.clb
Part number SW: 8K0 959 793 P, hardware number: 8K0 959 793 P.
Component: TSG FA H02 0506
Revision: Serial number: 0000028977204
Encoding: 011C02204000410001
VCID: 4D94EAF8144A2456C5-8018
Address 44: Steering Assist (J500)
Label file: DRV\8K0-909-144.clb
Part number SW: 8K0 909 144 F, HW: 8K0 909 144 B.
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0011505732
Encoding: 100001010001
Operating number: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X.rod
VCID: 34629F1C9FA0559EAA-8060
Address 46: Comfort System (J393)
Label file: DRV\8K0-907-064-46.clb
Revision: 00002001 Serial number: 0175560601
Encoding: 0100062020B900148120023680000000
Subsystem 1 - Part number SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS150 H08 0043
Subsystem 2 - Part number SW: 8K0 959 591 B HW: 8K0 959 591
Component: J394 PS240 H08 0043
Address 52: Door electric, passenger side (J387)
Label file: 8K0-959-792.clb
Part number SW: 8K0 959 792 P, Hardware: 8K0 959 792 P.
Component: TSG BF H02 0506
Revision: Serial number: 0000029354243
Encoding: 011C02204C00410001
VCID: 4C92E7FCEF502D5ED2-8018
Address 53: Parking brake (----)
Label file: DRV\8K0-907-801-V2.clb
Part number SW: 8K0 907 801 J, HW: 8K0 907 801 J.
Component: EPB-4 H01 0001
Revision: -------- Serial number: 00000000054691
ASAM Dataset: EV_ParkBrake 001022
ROD: EV_ParkiBrake_AU48.rod
VCID: 3666A51489DC478E94-8062
Address 56: Radio (R) Label file: DRV\4F0-035-0xx-56.clb
Part number SW: 4G0 035 056 E, HW: 4G0 035 056.
Component: Radio U STD H60 0093.
Revision: AB001007 Serial number: 230D-0C7561686
Encoding: 010003020100000001
VCID: 23406C40224EC22643-8076
"One error found:"
03029 - Subwoofer (R157)
011 - Interruption.
Error status: 01101011
Error priority: 5.
Error frequency: 1.
Lost Count: 161
Mileage: 167399 km
Time: 0.
Date: 2016.07.26
Time: 20:11:29
Voltage: 12.10 V
Address 5C: Lane Keeping Assist. Label file: DRV\8T0-907-217.clb.
Part number SW: 8T0 907 217, Part number HW: 4E0 907 217 C.
Component: J759 HC 0020
Revision: 00H08003 Serial number: 30021241700039
Encoding: 0022001
VCID: 76E66514015C078E54-8022
Address 5F: Information Selection. I (J794)
Label file: DRV\4E0-035-6xx-5F.clb
Part number SW: 8R1 035 670 C, hardware number: 8R1 035 670 C.
Part number: H-BNT-EU H44 0524
Revision: -------- Serial number: 207DS0C7500762
Encoding: 0F0100010106EBED2D80EF5E0000040304000000000000000000
Subsystem 1 - Part number: 8R0 060 884 AR
Component: ECE 2013 1505
Subsystem 2 - Part number SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Subsystem 3 - Part number SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380, operated by H02 0030.
Subsystem 4 - Part number: 8R0 060 961 C.
Component: CD-Database 3638.
Address 62: Door electric, left/right (J388)
Label file: 8K0-959-795.clb
Part number SW: 8K0 959 795 D, Hardware: 8K0 959 795 D.
Component: TSG HL H01 0506
Revision: Serial number: 0000029143726
Encoding: 010C02204000210001
VCID: 4380CCC0C20EE22623-8016
Address 69: Trailer (J345)
Label file: DRV\8K0-907-383.clb
Part number SW: 8K0 907 383 E, Part number HW: 8K0 907 383 E.
Part: Trailer H09 0100
Revision: 1A001001 Serial number: 00000146620353
Encoding: 0100000000000000
Operating number: WSC 00000 000 00000
VCID: 3666A51481DC478E94-8062
Address 72: Door electric, high, right (J389)
Component: TSG HR H01 0506
Revision: Serial number: 0000029143095
End----------------------------(Duration: 03:46)-----------------------------
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 13-09-2026, 7:06.
DieselBär30x
Avatar-DieselBär30x
Post01-08-2016, 12:08    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
Hi Michi!
Please first go to the main page of VCDS, click the "Settings" tab on the top right, and change the WSC to a numerical sequence.
Many StGe (likely referring to a specific group or term) dislike the implausible WSC (likely an abbreviation) with lots of zeros. icon_wink.gif
Best regards from Munich!
Karma: +1354 / -0   Thank you, like it!
Post01-08-2016, 17:45    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
What exactly was done, and what does the ACC (not) do?
Translated on 13-09-2026, 7:07.
michiglaser
2007 Audi A4 Avant
Post01-08-2016, 21:34    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
Okay, I will change that regarding the WSC.
I installed an auxiliary heating system (Westfalia with a Jaeger electric kit).
I was able to reprogram all the control units to match the installed trailer hitch, except for the ACC (Adaptive Cruise Control) module.
After starting, it displays "Braking guard off" in small letters and then prompts me to activate the cruise control or ACC: "ACC: not available."
According to various online forums, I'm not alone in experiencing this problem, but no one else seems to have the exact same original configuration as I do.
I'm not sure if I should try any kind of coding that has worked for others to get the system running again - after all, the system actively interferes with the driving process.
Of course, I could already have it registered with Audi and have it coded there using an SMV code.
It's likely there will be complications, as I only have a 600W fan installed, and Audi probably requires an 800W fan when using a trailer hitch.
(But I'll take responsibility for that. Pulling a 750kg trailer 3km to the recycling center should be doable with 600W...)
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 13-09-2026, 7:09.
Post01-08-2016, 23:36    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
Please provide the details of the coding for the distance control module (i.e., which checkboxes are set). You can take a Screenshot to show this.
Translated on 13-09-2026, 7:10.
Post02-08-2016, 8:58    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
I'm not sure if I should try any kind of coding that has worked for others to get the system running again - after all, the system actively intervenes in the driving process.
Please do not try out random encodings and make sure to record or archive the original encoding (e.g., using an Autoscan).
Please provide a Screenshot...
Translated on 13-09-2026, 7:11.
Benni
Post15-05-2017, 8:11    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
Unfortunately, the ACC (Adaptive Cruise Control) feature of the FL model is still not documented in VCDS (Vehicle Diagnostic System).
Is there any new information available now?
I can provide a complete scan and Screenshot later if you'd like.
Translated on 13-09-2026, 7:12.
Post15-05-2017, 8:24    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
Hi Benni,
Is the most recent dataset, dated May 5, 2017, already being used?
Benni
Post15-05-2017, 9:51    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
Hi Reiner,
Yes, I specifically downloaded and installed the latest version again on Saturday.
I now also have an appointment where the entire process will be coded using SVM. It would be great if Rosstech could make some progress with the documentation.
I'm a bit sad that there's such a big gap now. However, it's understandable given the increased complexity.
But they really have to work hard to keep up with the competition.
Thanks in advance, as I mentioned, the data will be available tonight.
Translated on 13-09-2026, 7:13.
Post15-05-2017, 15:21    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
Please initiate an automatic scan.
Translated on 13-09-2026, 7:14.
Benni
Post15-05-2017, 19:50    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
Saturday, May 13, 2017, 10:34:56:22413
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64 (VirtualBox).
VCDS Version RKS 17.1.3.0
Data as of: 20170505 DS267.9
Vehicle Identification Number: WAUZZZ8F License Plate:
Vehicle type: 8F (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 26 42 44 46 52 53 56 5C
5F 62 69 72
Mileage: 35,080 km
03-Brake electronics -- Status: Error 0010.
05-Access/Startup Report -- Status: Error 0010.
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
19-pin diagnostic interface -- Status: Error 0010.
High Beam Assist -- Status: OK 0000
26-Electrical roof installation -- Status: OK 0000
56-Radio -- Status: OK 0000
5C Lane Keeping Assist. -- Status: Error 0010.
69 followers -- Status: not registered 0001
Address 01: Engine Control Module (J623-CNCD)
Label file: 06L-907-115-V1.clb
Part number SW: 8T2 907 115. Part number HW: 8T2 907 115.
Component: 2.0l R4 TFSI, part number H13 0005.
Revision: --H13---
Encoding: 222500322446010B2000
Operating number: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TFS0218T2907115 001006
ROD: EV_ECM20TFS0218T2907115.rod
VCID: 75EA21F8D496BBE9CA-8021
4 error codes found:
17176 - Received error value on the data bus.
U1123 00 [039] - -
Error priority: 6
Error frequency: 4
Mileage: 35,070 km
Date: 2017.05.12
Time: 21:43:37
Motor speed: 0.00 rpm.
Normalized load value: 0.0%
Vehicle speed: 0 km/h
Coolant temperature: 31 °C
Intake air temperature: 33 °C
Atmospheric pressure: 990 mbar.
Voltage at terminal 30: 11.718 V.
Lost learning counter via OBD: 40.
Powertrain Coordinator: ACC fault. ACC: Not active, even though the powertrain system is passive.
Powertrain Coordinator: ACC fault status - request to start and stop: Stop speed set.
Powertrain Coordinator: ACC Fault Status Bit 2: Not transmitted simultaneously.
Powertrain Coordinator: ACC Fault Status Bit 3: Does not reset after fault shutdown.
Powertrain Coordinator: ACC Fault Status Bit 4: Not active when the limiter is active.
Powertrain Coordinator: ACC Fault Status Bit 5: Not sending undefined signals.
Powertrain Coordinator: ACC Fault Status Bit 6: Not active when the main switch is off.
Powertrain Coordinator: ACC Fault Status Bit 7: Not active during driver braking.
Powertrain Coordinator: ACC Fault Status Bit 8: Not active during EPB emergency braking.
Powertrain coordinator: Brake error. ESP: No error.
Delay controller: Available.
Powertrain Coordinator: Brake error status handshake. TSK/ESP: No error.
Powertrain Coordinator: Brake Fault Status Bit 1: No Fault.
Powertrain Coordinator: Brake error status bit 3: No error due to inaccurate motor torques.
Drive system coordinator: Brake fault status bit 4: Indicates no consistency error in the drive system coordinator message.
Powertrain Coordinator: Brake fault status bit 6: Forced activation, OK.
Powertrain Coordinator: Brake error status: 4.
Powertrain Coordinator: Brake - Functional status - Parking brake: inactive.
Powertrain Coordinator: Brake Function Status - ACC: Not braking.
Powertrain Coordinator: Brake function status - ESP: TSK braking not performed.
Powertrain coordinator: Brake function status - Driver: Not braking.
Powertrain Coordinator: Brake function status - Hill Descent Assist: inactive.
Powertrain Coordinator: Brake function status - ASR: no intervention.
Powertrain Coordinator: Brake function status - ABS: no intervention.
Powertrain Coordinator: Brake - Functional Status - ADS: No intervention.
Powertrain Coordinator: Brake Function Status - EDS: No intervention.
Powertrain Coordinator: Brake - Functional Status - ASP: No intervention.
Powertrain Coordinator: Brake Function Status - AWV2: No Warning Pressure.
Powertrain Coordinator: Brake Function Status Bit 4: No intervention.
Powertrain Coordinator: Brake Function Status Bit 11: Not passively tested.
Powertrain Coordinator: Brake Function Status Bit 12: Not passively tested.
Powertrain Coordinator: Brake Function Status Bit 13: Standstill detected.
17178 - Received error value on the data bus.
U1123 00 [039] - -
Error priority: 6
Error frequency: 4
Mileage: 35,070 km
Date: 2017.05.12
Time: 21:43:37
Voltage at terminal 30: 11.738 V.
15270 - Bank 1; Variable camshaft timing (VCT) (N205)
P1528 00 [032] - Interruption.
Sporadic - unconfirmed - checked since last deletion.
15267 - Bank 1; Valve for variable valve timing; Exhaust (N318)
P1050 00 [032] - Interruption.
Readiness: 0000 0000
Part number SW: 8K9 927 156 C, HW: 0B5 927 156 K.
Part number: 0B5 20TFSIRdW H03 0005
Revision: --H03---
Encoding: 000001
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021_VW51.rod
VCID: 3D7AF9D8AC2623A9C2-8069
Label file: DRV\8K0-907-379-V2.clb
Part number SW: 8K0 907 379 CP, Part number HW: 8K0 907 379 CP.
Component: ESP8 quattro H09 0020.
Revision: -------- Serial Number: --------------
Encoding: 311DCC01
VCID: 09125D08A06ECF09BE-805D
"One error found:"
000 - -
Error priority: 2
Error frequency: 3
Lost Count: 163
Mileage: 35,070 km
Time: 0.
Date: 2017.05.12
Time: 21:43:37
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x0045
Hex Value: 0x0393
Hex Value: 0x0000
Part number SW: 8K0 907 064 KH, HW: 8K0 907 064 KH.
Component: BCM2 2.0, H15 0711.
Revision: 00002001
Encoding: 05A34F00000000000000
VCID: 0004402C93548E41E9-8055
"One error found:"
00956 - Key 2
002 - lower limit exceeded.
Error status: 01100010
Error priority: 3
Error frequency: 2.
Lost Count: 98
Mileage: 30889 km
Time: 0.
Date: 2016.12.09
Time: 08:25:49
Address 08: Climate Control/Heating Unit (J255)
Part number SW: 8K1 820 043 AQ, Hardware number: 8K1 820 043 AQ.
Component: CLIMATE CONTROL, 3 ZONES, H04 0122.
Revision: C1000000 Serial Number: 01090220150700
Encoding: 642302C880
VCID: 77F62BF0C69AC9F9D8-8023
Part number SW: 8K0 907 063 DH Hardware number: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial Number: 00000997298401
Encoding: 260000118174AFE20181408300001D0D4F9CC3882609020100000B004401030100000064000000
VCID: 78F428CCCB84C681D1-802D
Subsystem 1 - Part number SW: 8F1 955 119 HW: 8K1 955 119 Label file: DRV\1KX-955-119.CLB
Component: WWS 300115 H07 0080
Serial number: SWF15011305827
Encoding: 00FD11
Subsystem 2 - Part number SW: 8U0 955 559 C, HW: 8U0 955 559 B, Label file: DRV\8U0-955-559.CLB.
Component: G397_RLFS H06 0004
Serial number: 20114410
Encoding: 02005D
Subsystem 3 - Part number SW: 8K0 941 531 AS, HW: 8K0 941 531 AS.
Component: E1 - LDS H03 0031.
Serial number: 00000000002701150660
Subsystem 4 - Part number SW: 4H0 907 658, HW: 4H0 907 658.
Serial number: BD184197000000000001
Part number SW: 8K0 907 561 B, HW: 8K0 907 561 B.
Component: ACC3 H11 0100
Encoding: 00CFB0
VCID: 3162D5E8687ED7C956-8065
3 error codes found:
000 - -
Error priority: 2
Error frequency: 1.
Lost Count: 162
Mileage: 35,070 km
Time: 0.
Date: 2017.05.12
Time: 21:43:38
Temperature: 18.0°C
Voltage: 11.65 V
Hex Value: 0x005D
Speed: 0.0 km/h
01314 - Engine Control Unit.
Error priority: 2
Error frequency: 1.
Lost Count: 162
Mileage: 35,070 km
Time: 0.
Date: 2017.05.12
Time: 21:43:38
01316 - Brake control unit.
Error priority: 6
Error frequency: 3
Lost Count: 163
Mileage: 35,070 km
Time: 0.
Date: 2017.05.12
Time: 21:43:38
Temperature: 18.0°C
Voltage: 11.65 V
Hex Value: 0x00C0
Speed: 0.0 km/h
Label file: 8F0-959-655.clb
Part number SW: 8F0 959 655 D, HW: 8F0 959 655 D.
Component: Airbag VW-AU10 H15 0430
Serial number: 003KGDB06L37
Encoding: 30394135353130303030554A304C38463053
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 3972EDC8B80E1F89EE-806D
Serial number: 6334MSME4D091574G
Crash sensor for side airbag, passenger side.
Serial number: 6344MSME4D3A4A1DW
Serial number: 6352QSME09503A52B
Serial number: 6362QSME2B4B2050D
Serial number: 63732SME1E4D52443
Crash sensor for front airbag, passenger side.
Serial number: 63832SME734F4270%
Part number SW: 8K0 953 568 M, Part number HW: 8K0 953 568 M.
Component: Steering module. Part number: H04 0005.
Revision: -------- Serial Number: 90372OB4000ZZ
Encoding: 0000DE
VCID: 448C8C3CC7CC52618D-8011
Component: E221 - MFL H03 0004
Address 17: Control panel module (J285)
Part number SW: 8T0 920 932 S, HW: 8T0 920 932 S.
Bauteil: KOMBIINSTR. H36 0567
Revision: 00100000 Serial Number: 5PN45DY1G
Encoding: 13EF190047010008000000
VCID: 4894980CFBE4760161-801D
Part number SW: 8R0 907 468 P, HW: 8R0 907 468 D.
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial Number: 3041Z152010F6B
Encoding: 80CF07FF00
VCID: 4C9CA41CEF9C9A2145-8019
Subsystem 1 - Part number SW: 8T0 915 181, HW: 8T0 915 181.
Part: J367-BDM, Hella, H03 8041.
Serial number: 5479125603
Subsystem 2 - Part number SW: 8K0 959 663, HW: 8K0 959 663.
Serial number: 15035002287021200181
"One error found:"
000 - -
Error priority: 1.
Error frequency: 1.
Lost Count: 162
Mileage: 35,070 km
Time: 0.
Date: 2017.05.12
Time: 21:43:39
Binary value: 10111
Voltage: 11.80 V
Quantity: 6
Address 20: High Beam Assist (J844)
Label file: DRV\8K0-857-511.clb
Part number SW: 8T0 857 511 AD, HW: 8T0 857 511 AD.
Component: FLA H04 0012
Revision: AA001002
Encoding: 02018A64747464545425363E00
VCID: 7CFC34DCFFBCEAA1B5-8029
Address 26: Electrical Roof System (J256)
Label file: 8F0-959-255.clb
Part number SW: 8F0 959 255 Part number HW: 8F0 959 255
Part: Laminated Glass - AUDI B8 H12 0190
Encoding: 010000
ASAM Dataset: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
VCID: 71E215E8A0FE97C916-8025
Address 42: Door electrical driver (J386) Label file: 8K0-959-793.clb
Part number SW: 8T0 959 793 P, HW: 8T0 959 793 G.
Component: TSG FA H10 0305
Encoding: 011C53725E08330C03
VCID: 56A846742150D0F1E3-8003
Part number SW: 8K0 909 144 J, Part number HW: 8K0 909 144 B.
Component: RCEPS H41 0509
Revision: 00001000 Serial Number: 0028458316
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X_008.rod
VCID: 3874E8CC8304068111-806D
Revision: 00002001 Serial number: 0359221778
Encoding: 01000EB800B900A18330033680000047
Address 52: Power door lock, front passenger side (J387)
Part number SW: 8T0 959 792 P, HW: 8T0 959 792 G.
Component: TSG BF H10 0305
Encoding: 011C53325E08330C03
VCID: 55AA41783C56DBE9EA-8001
Part number SW: 8K0 907 801 N, HW: 8K0 907 801 J.
Component: EPB-4 H02 0005
Revision: -------- Serial Number: 10000000497090
ASAM Dataset: EV_ParkBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 3A70F2C4BD081491E7-806F
Part number SW: 4G0 035 061 Q
Hardware: 4G0 035 061
Component: Radio with DAB functionality. Part number: H60 0150.
Revision: AB001007
Serial number: 109B/0F8007967
Encoding: 010103020100000101
VCID: 2B5EC7804A52BD196C-807F
Part number SW: 8T0 907 217 A, HW: 4E0 907 217 C.
Component: J759 HC 0040
Revision: 00H08006 Serial Number: 600215205001EA
Encoding: 0022002
VCID: 3776EBF0461A09F918-8063
"One error found:"
Error priority: 6
Error frequency: 5
Lost Count: 163
Mileage: 35,070 km
Time: 0.
Date: 2017.05.12
Time: 21:43:38
Part number SW: 8R1 035 670 J, Part number HW: 8R1 035 670 J.
Component: H-BNT-EU H49 0897
Revision: -------- Serial Number: 516B30F7509497
Encoding: 130100030006EBED2D80CB5E0000040104000000000000000000
VCID: 3A70F2C4B5081491E7-806F
Subsystem 1 - Part number: 8R0 060 884 CH
Component: EUR 2014 2004
Subsystem 2 - Part number SW: 8R0 919 604 A, HW: 8R0 919 604 A.
Component: DU7 High H42 0104
Serial number: A130BO0F3251772
Subsystem 3 - Part number SW: 8T0 919 611 L, HW: 8T0 919 611 C.
Component: E0380, Operated. H02 0030.
Serial number: 00000002125567
Subsystem 4 - Part number: 8R0 060 961 G
Component: CD Database 5950.
Address 62: Door electric, left/right (J388) Label file: 8K0-959-795.clb
Part number SW: 8T0 959 795 F, HW: 8T0 959 795 F.
Component: TSG HL H09 0305
Encoding: 010C13304008370C03
VCID: 4E98AE141980A8312B-801B
Address 69: Trailer (J345) Label file: DRV\8K0-907-383.clb
Component: Trailer H09 0100
Revision: 1A001001 Serial Number: 00000146620353
Operating Number: WSC 00000 000 00000
VCID: 3668E6F48110F0F103-8063
Label file: 8K0-959-794.clb
Component: TSG HR H09 0305
End----------------------------(Duration: 03:45)-----------------------------
Translated on 13-09-2026, 8:07.
Post16-05-2017, 9:10    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
Dana from Ross-Tech gave me some advice:
Dana wrote:
Hi Rainer,
The Q5 requires numerous modifications when retrofitting a 69-Trailer module. This list may not be 100% complete, but typically includes:
* 19-CAN Gateway - [Installation List] feature.
* 01-Engine
* 03-ABS Brakes - Security Access, followed by Long Coding bits.
* 09-Cent. Elect. - "Trailer hitch/Recognition active"
* 10-Park/Steer Assist - Not applicable in this case.
* 13-Car Distance. Security Access Required.
* 3C-Lane Change - Not applicable in this case.
* Maintain 5C-Lane.
* 6C backup camera. - Not applicable here.
* 69-Trailer
He didn't add 69 to the Installation List (not logged in), so I suggest that for now, when you request the original condition scan. The 13 coding requires a conversion from hexadecimal to decimal.
Encoding: 00CFB0 = 53168
xxxx?: Features / Specifications / Equipment
1 = Tow hitch installed.
8 = Tow hitch NOT installed.
I would change the coding from 53168 to 53161 and convert it back to hexadecimal for him: 00CFA9.
Best Regards,
Dana
So, besides the fact that the trailer control unit (address 69) is not registered in the vehicle's configuration list, the trick is that a tooltip for adjustment appears when using the adaptive cruise control (ACC), but the values cannot be properly adjusted.
"Normal encoding" is simply a number where, in binary representation, individual bits correspond to specific functions or settings.
If the tooltips display values in decimal notation, and the control unit provides them in hexadecimal notation, then you naturally need to convert them accordingly.
It is clear that 00CFB0 is a hexadecimal number, while it would not be clear that 002222 is a hexadecimal number.
"Does anyone have a Screenshot of the coding display? My suggestion would be that, since you're already doing the calculations instead of using pre-made buttons, you should write the number base before the number, like '0b1111' or '0x0f' or '15'."
@BenniViewing profile: Benni: Please test the suggestion that Dana made above.
Translated on 13-09-2026, 8:10.
Benni
Post16-05-2017, 11:22    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
"Thank you!"
I will do that.
I intentionally used the default, factory settings for the car scan. In the meantime, I registered the trailer hitch (AHK) and also informed the ESP system that a trailer hitch is now installed, so that the system would reactivate and I wouldn't be driving without ESP.
This morning, the car was brought to the workshop because it's leaking oil from all the seals. While it's there, the tow hitch will be registered online (via svm). I will then send a new vehicle scan.
While coding with ACC, I didn't expect a tooltip and immediately pressed the Long Coding Assistant, which then appeared empty.
Translated on 13-09-2026, 8:18.
Benni
Post29-05-2017, 19:07    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
Here is the result after the SVM analysis:
Encoding: 00CFA9
Operating Number: WSC 49974 002 1048576
I couldn't find any tooltips or similar help, I only get the Long Coding Assistant, and it doesn't display any documentation.
The result, however, at least confirms Ross-Tech's statement.
Translated on 13-09-2026, 8:21.
Post29-05-2017, 19:13    Subject: ACC Coding for A4 B8 FL After AHK Installation Quote
Thank you for the feedback! Could you please take a Screenshot of the control unit information for the affected control unit?
I have a suspicion...
Translated on 13-09-2026, 8:22.
misler11
Post02-08-2017, 0:56    Subject: ACC and AHK: Explained and Compared Quote
Good day.
I'm just chiming in here, I hope that's okay.
I installed a trailer hitch on my S4 B8, and now I'm having problems with the trailer hitch control unit, and the ACC (Adaptive Cruise Control) is failing when it's supposed to brake while towing.
The support team from the supplier says I encoded something incorrectly and now they want to sell me the correct encoding.
However, I would like to perform the coding using my VCDS device.
Could someone with expertise take a look at my car's diagnostic scan and point out any potential issues?
You're very welcome, and best regards.
Marco.
Fehlerspeicher Audi S4 Komplett.pdf
 Auto scan
Auto scan
 File name:  Fehlerspeicher Audi S4 Komplett.pdf
 File size:  161.7 KB
 Downloaded:  1133 times
Translated on 13-09-2026, 8:23.
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts GRA Installation Error: Troubleshooting Guide Diesel Engine Technology
No new posts Adjust timing belt tension after installation Diesel Engine Technology
No new posts Noise after installation of 0.216 injectors Diesel Engine Technology
