TDI Cold Start Issues: AEL R5 Fine Tuning
jproberts
Post05-06-2022, 7:10    Subject: TDI Cold Start Issues: AEL R5 Fine Tuning Quote
Hi everyone,
"Because the engine was showing a timing value of 115 degrees BTDC on VCDS TDIgraph (too early), we adjusted the pump a bit later (VCDS values of approximately 55, requesting 1.9 degrees BTDC versus the actual 1.8-4). Now, the engine is sputtering during cold starts before it starts. Black smoke is now coming from the exhaust again, like before."
I would appreciate your feedback.
JPRoberts
Translated on 14-10-2026, 23:11.
jproberts
Post10-06-2022, 14:40    Subject: SEO-Optimized Title: **"Best SEO Tools: Improve Your Rankings Now"** Quote
Your help is welcome.
Translated on 14-10-2026, 23:12.
Post11-06-2022, 9:59    Subject: TDI Cold Start Issues: AEL R5 Fine Tuning Quote
Hello.
The start of injection is determined by the needle lift sensor in the central injector. If this sensor is heavily worn and the opening pressure is too low, the start of injection timing may be correct for that cylinder, but not necessarily for the remaining 4 cylinders.
Fiddling with symptoms is not enough; everything needs to function properly.
jproberts
Post11-06-2022, 10:44    Subject: TDI Cold Start Issues: AEL R5 Fine Tuning Quote
Good morning, Reiner.
Thank you for your message!
VCDS doesn't show any engine or other error codes. How else can I determine if the injector nozzle is faulty? If I use a diagnostic tool, what values should I expect? Or would it be better to do something else?
JP
Translated on 14-10-2026, 23:13.
Post11-06-2022, 16:30    Subject: TDI Cold Start Issues: AEL R5 Fine Tuning Quote
Rainer & #128521;
The target values are even printed on the nozzles, and anyone who can check and adjust them knows that.
Those who don't know how can even find instructions as a non-customer.
Ich kann den Inhalt dieser URL nicht abrufen, da ich keinen Zugriff auf externe Websites habe. Bitte gib den Text, den du übersetzt haben möchtest, direkt an.
/viewtopic.php?t=10197
Further assistance is only available through the Autoscan feature, which displays customer status, or by using a support key.
https://shop.dieselschrauber.org/en/obd-support-key-p-112.php
Translated on 14-10-2026, 23:15.
jproberts
dieselschrauber likes this.
Post11-06-2022, 22:16    Subject: TDI Cold Start Issues: AEL R5 Fine Tuning Quote
Thank you very much, Rainer!
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 TDI: Cold Start Problems After Timing Belt Change Diesel Engine Technology
No new posts AFN Cold Start Problems Diesel Engine Technology
No new posts Cold start problems 1Z Diesel Engine Technology
No new posts T4 2.5 TDI ACV: Cold Start Problems Upload
