ckone Guest
24-03-2006, 20:39 Subject: Headlight leveling error code 01538 |
I'm having a problem with my headlights. As soon as I turn on the ignition, they move down and then up, which wasn't happening before.
I installed xenon headlights, and the control unit is displaying error code 01538.
If I delete the error, it reappears immediately.
Can someone tell me what the error is here?
The engines are still working perfectly.
Thank you.
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
24-03-2006, 23:37 Subject: Headlight leveling error code 01538 |
hi.
There are different systems... some start by going up and down, while others don't.
The error code indicates a problem with one of the motors responsible for closing the LWR (Low Voltage Release).
With a little luck, a new default setting might also help... (but I think there are probably separate error codes for that...)
ckone Guest
25-03-2006, 10:49 Subject: Headlight leveling error code 01538 |
So, mine usually don't go up and down.
I've already reset the basic settings.
Oh yes, it's also showing '16 00 - Signal out of tolerance'.
dieselschrauber likes this. |
25-03-2006, 12:19 Subject: Headlight leveling error code 01538 |
Morning!
Please provide the complete error memory content, including numbers and words.
(This will also indicate whether it's a VW-specific error code or a generic P-code.)
"The error code 1600 seems more like a throttle valve or oxygen sensor issue."
ckone Guest
28-03-2006, 17:27 Subject: Headlight leveling error code 01538 |
'That's what the error code says.'
01538 Servo motors for headlight range adjustment - V48/V49.
16:00 - Signal out of tolerance.
Pszuechter
02-11-2022, 15:33 Subject: Headlight leveling error code 01538 |
I'm experiencing the same error. How did you fix it? Sorry for reviving this old thread; I just didn't want to start a new thread with the same title.
The error code scan is attached.
The car is a Golf 5 2.0 TFSI GTI.
PS
| Description: |
| File size: |
7.05 MB |
| Viewed: |
591 times |
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1509 Karma: +644 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
02-11-2022, 18:09 Subject: Headlight leveling error code 01538 |
The thread creator is no longer logged in.
Profile PM Garage |
