VCDS CodingLog.csv
Post15-01-2008, 22:27    Subject: VCDS CodingLog.csv Quote
Hi.
My VCDS 607.3 wrote a "CodingLog.csv" file in the "Debug" directory.
It's very nice for me because I'm always playing around with code, and I'm guaranteed to eventually forget the original coding.
704.1 and 711.1 beta versions do not do that.
Post21-01-2023, 22:35    Subject: VCDS CodingLog.csv Quote
Current VCDS versions: Log files for coding, adaptation, etc. can be found in the "Debug" folder within the VCDS installation directory.
Logs allow you to track changes made during coding and adaptation.
It is recommended to perform an initial scan of the vehicle before making any changes and to archive the results. For example, I have archived the vehicle's original delivery condition.
 Codierungen bei VCDS nachvollziehen
 File size:  48.43 KB
 Viewed:  649 times
VCDS-Handbuch.pdf
 VCDS Benutzerhandbuch
 File name:  VCDS-Handbuch.pdf
 File size:  1.43 MB
 Downloaded:  1253 times
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
No new posts VCDS 11.11.5 is outdated, VCDS: Software is outdated On-Board Diagnostics (OBD)
No new posts VCDS-RKS 12.12.2: Update & Features On-Board Diagnostics (OBD)
No new posts VCDS-RKS: Version 11.11.2 Update & Features On-Board Diagnostics (OBD)
