Mechanic Wanted (R5 TDI PD) for Main Bearing
dleds
Karma: +14 / -1   Thank you, like it!
Post10-03-2023, 19:08    Subject: Mechanic Wanted (R5 TDI PD) for Main Bearing Quote
Hello everyone,
I have a Touareg parked on my farm that has unfortunately been contaminated with diesel fuel.
After extensive searching and various emails to engine repair shops, I now find myself in a difficult situation, as the local workshops either don't manufacture aluminum blocks or don't have enough time due to a lack of staff.
The question now is, does anyone know of a workshop where you can have the engine fitted with guide bushings?
Greetings
Jan
Turbinchen likes this.
Post10-03-2023, 19:13    Subject: Mechanic Wanted (R5 TDI PD) for Main Bearing Quote
You can also ask: https://www.autoservice-leupold.de/motoreninstandsetzung
However, it has been a very long time since I was there. The repaired parts are still functioning today. icon_wink.gif
Best regards, Rainer
dieselschrauber likes this.
Post11-03-2023, 9:12    Subject: Mechanic Wanted (R5 TDI PD) for Main Bearing Quote
Please ask here.
Redhead Cylinder Head Technology: Your Partner for High-Performance Cylinder Heads
We specialize in the design, development, and manufacturing of high-performance cylinder heads for a wide range of applications, including:
* **Race Engines**
* **Performance Street Cars**
* **Off-Road Vehicles**
Our cylinder heads are engineered to deliver maximum power, optimal airflow, and exceptional durability. We use only the highest quality materials and manufacturing processes to ensure that our cylinder heads meet the most demanding performance requirements.
**Features:**
* **Optimized Port Design:** Our cylinder heads feature a carefully designed port system that maximizes airflow and minimizes flow restriction.
* **High-Flow Combustion Chambers:** Our combustion chambers are designed to promote efficient combustion and maximize power output.
* **Durable Construction:** Our cylinder heads are built to withstand the stresses of high-performance engine operation.
* **Precision Machining:** Our cylinder heads are manufactured using state-of-the-art machining techniques to ensure accuracy and consistency.
**Applications:**
Our cylinder heads are suitable for a wide range of applications, including:
* **Small Block Ford Engines**
* **LS Engines**
* **SRT Engines**
Cheap will only be possible if it is feasible, but not at all.
dleds
Post13-03-2023, 14:30    Subject: Mechanic Wanted (R5 TDI PD) for Main Bearing Quote
Hi Rudi,
Have you had any personal experiences with them? To be honest, the multimedia aspect is a bit intimidating to me. The focus should be on the work, not the camera work.
Regarding the costs, it's noteworthy that Tornau Motors offers refurbished engine blocks for 3500,- and new, original VW engine blocks for 3000,-. Their 24-month warranty, without mileage restrictions, for VW vehicles, exclusively for workshops.
Normally, one could have accepted the offer well (if something else had also been faulty), but 3000+ euros for 10 bushes is outrageous, and 5 drills plus pressing, plus one plan, is also a bit too much. Here, they charge 80 per bush for drilling and 65 for planing. With these prices, I can't even afford half. Even with new pistons and bearings, I remain below half.
Therefore, I was wondering if anyone might know a company that offers this service.
No new posts Erwin - Looking for a repair manual for VAG vehicles Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Looking for a diagnostic tool? Diesel Engine Technology
No new posts AI Specialists A4 B5 - We're Hiring! On-Board Diagnostics (OBD)
No new posts Einspritzdüse gesucht für 0 434 250 071 Diesel Engine Technology
No new posts Corrosion protection needed Transmission, Chassis, Body & Interior
