A6 2.5 TDI: Won't Start? Troubleshooting Guide
Marco89
Post10-02-2023, 19:52    Subject: A6 2.5 TDI: Won't Start? Troubleshooting Guide Quote
Hello everyone,
My A6 4B with a 2.5 TDI 180hp engine (BAU code) won't start.
When trying to start the engine, it almost starts but doesn't quite make it. The engine speed when cranking is 250 RPM. Based on my feeling, I would say that the injection timing is likely incorrect.
Based on this suspicion, I replaced the timing belt, as it wasn't in the best condition anyway, and blocked the engine using the special tool required for the job. Unfortunately, this didn't solve the problem; the issue persists.
The pre-charge pump is working as it should and is providing 0.5 bar of pressure.
MWB 18 is only displaying zeros. The field to the right of it occasionally showed that one impulse was within the normal range and one was outside of it.
There is no air visible inside the clear tube.
However, if you start the engine with the initial settings in mode 4, and then try to start it, it will briefly start, run for a few seconds, and then shut off again. Otherwise, it only produces white/gray smoke. However, the injection timing always shows 0 degrees in mode 4.
"The pump control unit was already repaired by the previous owner about 2 years ago. I noticed that the insulation on the two cables leading to the lower solenoid valve was damaged, and they were making contact with each other. I cleaned and re-insulated them and reconnected them. Unfortunately, this didn't solve the problem either."
There are no error codes stored in the error memory.
Does anyone have any other ideas about what might be causing this?
Thank you in advance.
Translated on 18-09-2026, 19:58.
Karma: +807 / -0   Thank you, like it!
Post10-02-2023, 22:35    Subject: A6 2.5 TDI: Won't Start? Troubleshooting Guide Quote
Autoscan?
Translated on 18-09-2026, 20:01.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AAZ: Hesitant Start, Blue Smoke - Troubleshooting Diesel Engine Technology
No new posts BMW 325 tds; Starts poorly when the engine is warm + Weak... Diesel Engine Technology
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
