Audi A6 2.5L 180hp Quattro not running.:(
viviane-w
Post27-02-2023, 13:04    Subject: Audi A6 2.5L 180hp Quattro not running.:( Quote
Hello, I'm new here, a woman, and I have no idea icon_rolleyes.gif.
"I bought an Audi A6 2.5L Quattro, manufactured in 2002 with 180 horsepower, about three weeks ago. The car had a faulty diesel pump when I purchased it."
I had the diesel pump replaced. The car starts for 1 or 2 seconds and then turns off; it also doesn't respond to acceleration.
If you turn the ignition on and off a few times, it will start again for a few seconds before turning off. If you try to start it immediately after that, it will crank endlessly without starting.
Could it be that he's not getting enough diesel? I'm really at a loss now icon_cry.gif. I also don't want to put €100 or more into the car icon_rolleyes.gif.
It would be really great if someone could help me icon_smile.gif[/b].
Audi A6 2,5l Quattro 180PS Schaltgetriebe
Motorkennbuchstabe AKE
Translated on 17-07-2026, 1:35.
Back to top Profile PM Email
dieselschrauber likes this.
Post27-02-2023, 13:25    Subject: Audi A6 2.5L 180hp Quattro not running.:( Quote
Reading the error codes and posting them here would be the first step in troubleshooting. This will help determine if, for example, the immobilizer is preventing the car from starting.
P.S.: Why would someone buy a broken car if they don't have any knowledge about cars themselves?
Translated on 17-07-2026, 1:37.
viviane-w
Post27-02-2023, 13:56    Subject: Audi A6 2.5L 180hp Quattro not running.:( Quote
I'll post a picture of the error codes later.
I think it said "Engine Control Unit locked."
"I bought the car as a project and got it for a good price. My mechanic and I are at a loss, so he asked me if I could ask about it in the forum."
I only received one key for the car. I would need the immobilizer code if it's necessary.
"lg" translates to "best regards" or "kindly regards" in English. It is a common abbreviation used at the end of emails and letters.
Translated on 17-07-2026, 1:38.
Karma: +647 / -0   Thank you, like it!
dieselschrauber and Turbinchen likes this.
Post27-02-2023, 17:11    Subject: Audi A6 2.5L 180hp Quattro not running.:( Quote
The fact is that the VP 44 or its control unit needs to be programmed to the immobilizer. If you don't have the necessary data, you need to go to Audi or find someone who can read out the login code.
Translated on 17-07-2026, 1:39.
alevuz
Karma: +32 / -0   Thank you, like it!
Post19-03-2023, 12:12    Subject: Audi A6 2.5L 180hp Quattro not running.:( Quote
Hello there...
I once spent a lot of time troubleshooting to get a car running after changing the diesel filter!
Bleed the fuel injection pump very carefully!
The pre-charge pump wasn't working and appeared defective (also check the fuse). There was no obvious pumping action even when directly connected to 12V; it seems to be a rather unique system.
Finally, I got two friends to help. One was at the starter motor, the other blew air into the fuel tank with 1 bar of pressure. I opened two injector lines, and then we started it... After just 2 seconds, it ran. We closed the two lines again, and that was it – everything was working as if nothing had ever happened.
Before you start, check the anti-return valve (check valve) and also inspect the filter to make sure it's not blocked, especially considering the very low fuel flow coming from the tank! If in doubt, replace the diesel filter; there might be some water inside.
Note: If there's even the slightest amount of air in the system somewhere, it won't work!
Please also take into account what the previous speaker said - I did NOT experience that situation back then!
Maybe this will help you...
Good luck, Best regards, Manfred.
Touareg V10 TDI (AYH)
Translated on 17-07-2026, 1:41.
Post20-03-2023, 20:12    Subject: Audi A6 2.5L 180hp Quattro not running.:( Quote
Bei 1 bar kann der Tank bzw. dessen Befestigung u.U. Schaden nehmen. icon_idea.gif
(1) Fuel tanks must be corrosion-resistant. They must be leak-tight at twice the operating overpressure, or at least at an overpressure of 0.3 bar.
Translated on 17-07-2026, 1:43.
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B6 Rear Door Won't Unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 4B 2.5 TDI: Won't Start? Troubleshooting. Diesel Engine Technology
No new posts Automatic shift timing programming for Audi A6 quattro On-Board Diagnostics (OBD)
No new posts Audi 4B Quattro: Short Circuit to Positive Terminal On-Board Diagnostics (OBD)
No new posts Audi A6 Avant: Humming Noise When Turning Diesel Engine Technology
