Tiguan AD1 LED Light
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Faxe
Post14-04-2023, 0:47    Subject: Tiguan AD1 LED Light Quote
I have a Tiguan AD1, manufactured in March 2018.
According to TÜV, there is a fault in the control unit (STG) for the LED headlights.
Shouldn't these control units be visible in the car scan?
Address 29: Left headlight control (power module for left headlight).
Address 39: Right headlight control (power module for the right headlight).
Address D6: Left-side lighting control 2 (Power module 1 for left-side LED headlights).
Address D7: Right-side lighting control 2 (Power module 1 for right-side LED headlights).
I'm attaching the Autoscan file.
Sincerely,
Faxes.
Log-WVGZZZ5NZJW399902-175031km Autoscan 13042023.txt
 File name:  Log-WVGZZZ5NZJW399902-175031km Autoscan 13042023.txt
 File size:  19.85 KB
 Downloaded:  522 times
Karma: +643 / -0   Thank you, like it!
dieselschrauber likes this.
Post14-04-2023, 6:57    Subject: Tiguan AD1 LED Light Quote
Does the error reappear after deleting?
Faxe
Post14-04-2023, 8:53    Subject: Tiguan AD1 LED Light Quote
I didn't delete any errors that were related to light.
What I found and deleted were entries related to the rear door lock and the key battery.
I don't understand icon_sad.gif why the admin deleted my original post.
I would like to understand which address controls the LED headlights. The addresses I mentioned do not appear in the Autoscan. Does my vehicle have these features, or are they simply not being detected?
Faxes.
Post14-04-2023, 10:22    Subject: Tiguan AD1 LED Light Quote
In the posted excerpt of the first automatic scan in the bathroom, errors were already visible in the overview.
The person who asked the question cut off the rest of the response, for whatever reason.
In the second scan, the overview was already error-free. This is only possible by clearing the errors, because some issues might reappear. But no scan that is completely full of errors.
Completely nonsensical.
Faxe
Post14-04-2023, 10:46    Subject: Tiguan AD1 LED Light Quote
Here's the car scan with the errors.
Which of these helps to answer the question?
Sincerely,
Faxes.
Log-OH-T 6822-WVGZZZ5NZJW399902-175031km.txt
 File name:  Log-OH-T 6822-WVGZZZ5NZJW399902-175031km.txt
 File size:  47.54 KB
 Downloaded:  202 times
Post14-04-2023, 11:18    Subject: Tiguan AD1 LED Light Quote
It's pointless to speculate about anything after the fact. As you can see, the information available is unreliable, and therefore, it's a waste of time.
And if someone has a problem with "lights" or whatever, then they should just post the TÜV report online, which will contain the relevant information.
What else would it be, the newspaper from yesterday?
This is turning into a discussion with Captain Bluebear, and for no reason whatsoever. Without me.
Faxe
Post14-04-2023, 12:48    Subject: Tiguan AD1 LED Light Quote
Thank you for this unhelpful dialogue icon_sad.gif.
Unfortunately, the simple initial question still hasn't been addressed.
Quote from the post that was flushed down the toilet:
"He pointed out an error in the:"
Combined headlight control unit - electrical fault, right headlight.
Which control unit or address are you referring to?
The phrase "Kombinierter..." is directly transcribed from the TÜV report. I can add the TÜV number DF4.1.4.
and the inquiry has not yet been answered:
It's a shame, perhaps there's someone else who is willing to contribute constructively here.
Best regards to the forum.
Faxes.
Karma: +1334 / -0   Thank you, like it!
Post14-04-2023, 14:27    Subject: Tiguan AD1 LED Light Quote
Your car is a 2018 model year. You are likely using a VCDS HEX-Can or similar device, but not a HEX-V2. Therefore, VCDS may not be able to read all control units (ECUs) in this case. That's why you're seeing the "INTERFACE HARDWARE NOT COMPATIBLE" messages, and that's why you're not seeing everything.
Faxe
Post14-04-2023, 15:29    Subject: Tiguan AD1 LED Light Quote
Hi Herbert,
Thank you for the answer icon_smile.gif.
Yes, I own a HEX-USB+CAN device from the Dieselschrauber-Shop.
Is the lighting control integrated into the 4B multifunction control unit?
Or am I simply not seeing the other engine options that the Tiguan could have (29, 39, D6, D7), even though they are listed?
Best regards from the far north.
Faxes.
Post14-04-2023, 15:50    Subject: Tiguan AD1 LED Light Quote
Or am I simply not seeing the other trim levels that the Tiguan could have, (29, 39, D6, D7), even though they are listed?
Are they unreadable or not visible? That's why I also had to switch to the 2018 Golf.
The parts list in the diagnostic interface might provide you with an overview.
You can find HEX-V2 here in our shop, with support available.
Faxe
Post17-04-2023, 14:36    Subject: Tiguan AD1 LED Light Quote
Ordered the Hex V2 upgrade, I'm curious to see what it will do.
Faxes.
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts FSE PREMIUM in Passat, Golf, Tiguan nachrüsten Troubleshooting & Guides
No new posts Golf4: Turn signals flickering, wipers too slow, lights t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kein Licht Diesel Engine Technology
No new posts Summer Licht Transmission, Chassis, Body & Interior
No new posts Elektrik - Licht Transmission, Chassis, Body & Interior
No new posts Reminder Tone: Light & Sound Transmission, Chassis, Body & Interior
