P242F error code, Porsche Cayenne
Ralph75
dieselschrauber likes this.
Post01-09-2023, 20:24    Subject: P242F error code, Porsche Cayenne Quote
Okay, I'm back. The vehicle is still running in limp mode with error code P242F.
The problem continued to be caused by the DPF. I regenerated it, but there was no improvement; the ash content remained the same. I also couldn't clear the error code. It's driving me crazy. The MKL (check engine light) and glow plug warning light are on, and the error code is always the same: DPF P242F.
Okay, I was completely stumped. I went to a friend who specializes in vehicle coding. I tried everything, but I couldn't delete the error code. I removed the control unit, connected it externally to the computer, reset everything to zero, reinstalled it, and even without starting the engine, the P242F error code reappeared.
"This is unbelievable... Let's continue brainstorming."
What has been replaced, and what could it be?
Der Differenzdrucksensor wurde ersetzt und neu angelernt mit dem Gutmann OBD-Diagnosegerät. AHA, sagt der Codierer. Is it original?
"No," I say, "one from Metzger."
He knew exactly what the problem was. It was the sensor. And he was right.
After disconnecting the oxygen sensor, the P242F error code could be cleared, and we were finally able to continue working.
Now it's running without errors, and I'm satisfied again.
I remember having a similar problem with the DDS from Metzger on a 1.9 CDTI engine from Opel before.
Greetings.
Ralph.
Translated on 09-07-2026, 0:51.
Karma: +647 / -0   Thank you, like it!
Post02-09-2023, 6:06    Subject: P242F error code, Porsche Cayenne Quote
I only buy meat products from the butcher.
This so-called brand only sells the cheapest, low-quality products, both in terms of price and quality.
Translated on 09-07-2026, 0:53.
Turbinchen likes this.
Post02-09-2023, 8:00    Subject: P242F error code, Porsche Cayenne Quote
Ralph75 wrote:
Diesen habe ich regeneriert, keine Besserung, Aschegehalt blieb gleich.
The ash mass and ash volume are never reduced by DPF regeneration; for details, see the relevant articles on DPFs.
Ralph75
Post03-09-2023, 13:46    Subject: P242F error code, Porsche Cayenne Quote
Best regards, Rainer
Ash on my head X
Sure, man. It's been a tough week.
But I'm glad mine is working again. Our own always seem to be the ones that break down.
I'm happy to be here; I've already read a lot. Although I'm from Rüsselsheim and involved with Opel, I still have a lot to do with Porsche and Audi. So, this fits in well. X
Ralph.
Translated on 09-07-2026, 0:54.
No new posts Used Porsche Mileage: What to Look For General Tips
No new posts Error code P1351 General Tips
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-Com and Porsche Cayenne? On-Board Diagnostics (OBD)
No new posts Overload A6 2.7 BPP P242F - Max Load Exceeded Diesel Engine Technology
No new posts Cayenne Lowering Springs: Pocom Performance On-Board Diagnostics (OBD)
No new posts P0087, Fuel Rail Pressure Too Low, Cayenne Diesel Engine Technology
