Power steering failure Audi A3, year 2003
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Karma: +580 / -0   Thank you, like it!
Post24-06-2024, 21:29    Subject: Power steering failure Audi A3, year 2003 Quote
Hello!
My father has an Audi A3.
Essentially, it's a second car used for winter driving and errands.
First registration was in August 2003.
FIN:
WAUZZZ8P64A047xxx
Recently, the power steering suddenly failed without any warning or signs.
It needs to be a fully electric steering system.
So far, I've checked all the fuses.
in the engine compartment, under the cover.
and also on the side of the dashboard.
Nothing unusual seen.
VCDS is unable to establish a connection with the steering assist control unit.
The rest of the car's data can be read out using the car scanner.
Currently, the car is on a lift.
At first glance, I didn't notice anything unusual.
"I haven't seen the connectors for the steering linkage yet."
I would probably have to remove a cover first, and then use a mirror to look.
Well, maybe someone with experience could write to me sometime.
what might be in store for my father.
and what happens next...
He would still like to continue using it.
The car is still in very good condition, both aesthetically, technically, and the interior is spotlessly clean.
Steffen!
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Doku A2 8Z0 MJ 2003, Hands-free device malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2003, noises from the front of the car Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N Servolenkung defekt 01309 On-Board Diagnostics (OBD)
No new posts Audi A6 4B, year 2003 - how to properly read the diagnost... On-Board Diagnostics (OBD)
No new posts Looking for Audi A4, year 2003, with VAG COM / Channel Ov... On-Board Diagnostics (OBD)
No new posts Audi A3 8L Bj 06/2003 Chorus II problem Transmission, Chassis, Body & Interior
