STG Cornering Light Sharan 7N
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
vag-driver
Post02-08-2024, 11:00    Subject: STG Cornering Light Sharan 7N Quote
Hello everyone,
Currently, I am encountering the following error:
Address 55: Headlight range control (J745) Label file: .DRV\5M0-907-357-V3.clb
Part number SW: 5M0 907 357 F, HW: 7L6 907 357 C.
Component: AFS-ECU H04 0111
Revision: -------- Serial Number: --------------
Encoding: 05B200104F000200
Operating number: WSC 00020 999 00000
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlightRegulation_VW_AFS_Point_VW32.rod
VCID: 372A2DC67FCB4842DE8-8062
Left headlight power output stage:
Subsystem 1 - Part number: 1T0 941 329 A. Label file: 3D0-941-329.CLB.
Right headlight power output stage:
Subsystem 2 - Part number: 1T0 941 329 A
"One error found:"
5276435 - Static turn signal light, left side.
C1083 13 [00001001] - Interruption.
confirmed - checked since last deletion.
Environmental conditions:
Error priority: 2
Error frequency: 1.
Lost Count: 252
Mileage: 93790 km
Date: 2024.07.31
Time: 19:32:13
Is the engine control unit (ECU) actually defective? I was able to clear the error code, but it reappears after a short drive.
Andreas
Translated on 13-07-2026, 20:29.
Post02-08-2024, 11:41    Subject: STG Cornering Light Sharan 7N Quote
For me, the "static curve light left" refers to the left fog lamp, do they work? How is it set up on your car?
Often, the heating elements also break, so I would just replace the bulb with a new one.
Unfortunately, a loose connection with an LED often results in complete failure.
Translated on 13-07-2026, 20:33.
vag-driver
Post04-08-2024, 10:11    Subject: STG Cornering Light Sharan 7N Quote
In the Sharan, the cornering light is integrated next to the main headlight. The fog lights are working. We returned from our vacation yesterday. I will check the lights later.
Andreas
Translated on 13-07-2026, 20:34.
vag-driver
toast likes this.
Post04-08-2024, 12:25    Subject: STG Cornering Light Sharan 7N Quote
I just checked the bulb. It's okay. I measured 7.x volts at the terminals. Of course, that's not enough voltage.
a 12V light bulb.
It seems the performance module is actually defective. Where is it installed?
Andreas
Post04-08-2024, 12:50    Subject: STG Cornering Light Sharan 7N Quote
Do you know that the cornering light dims up and down?
The 7 V could be normal.
Does the problem occur on both the left and right sides? What is the voltage on the right side?
Translated on 13-07-2026, 20:35.
vag-driver
dieselschrauber likes this.
Post04-08-2024, 19:19    Subject: STG Cornering Light Sharan 7N Quote
The solution to the puzzle is: The light bulb on the driver's side was defective.
That's why the right side didn't work either.
Andreas
Translated on 13-07-2026, 20:36.
Post04-08-2024, 21:07    Subject: STG Cornering Light Sharan 7N Quote
Yes, that was also indicated in the error memory.
1 error found:
Error priority: 2.
Error frequency: 1.
Lost Count: 252
Mileage: 93790 km
Date: 2024.07.31
Time: 19:32:13
Translated on 13-07-2026, 20:37.
vag-driver
Post05-08-2024, 9:02    Subject: STG Cornering Light Sharan 7N Quote
Okay. However, I don't understand why the right side is also being shut down. That's why I brought up the performance module, because it doesn't make sense to me.
Andreas
Translated on 13-07-2026, 20:39.
Karma: +647 / -0   Thank you, like it!
Post05-08-2024, 12:03    Subject: STG Cornering Light Sharan 7N Quote
One-sided cornering lights are pointless.
vag-driver
Post05-08-2024, 14:21    Subject: STG Cornering Light Sharan 7N Quote
Sure. But generating an error message that mimics a complete system failure doesn't make sense either.
Andreas
Post05-08-2024, 15:17    Subject: STG Cornering Light Sharan 7N Quote
You're looking at it the wrong way.
The error message was as follows:
1 error found:
Error priority: 2.
Error frequency: 1.
Lost Count: 252
Mileage: 93790 km
Date: 2024.07.31
Time: 19:32:13
Translated on 13-07-2026, 20:40.
vag-driver
Post06-08-2024, 12:39    Subject: STG Cornering Light Sharan 7N Quote
When I say "error state," I mean taking the entire system out of operation, meaning deactivating both sides.
Andreas
Translated on 13-07-2026, 20:42.
No new posts Doku Sharan 7M9, Engine Noises at MKB ANU Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan 7M8: Reduced Steering Assist Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 B7 Curve Light Failure: Repair & Fix Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3C cornering light Transmission, Chassis, Body & Interior
No new posts AFS/Cornering Light Passat 3C: Jerky/Stuttering, No Error On-Board Diagnostics (OBD)
No new posts AGR Seat for VW Sharan 7N Diesel Engine Technology
