P1855 Software Status Monitoring Sporadically
Pasi_222
Post18-09-2022, 18:29    Subject: P1855 Software Status Monitoring Sporadically Quote
Hey everyone, I'm new here on the forum.
I have a Passat 3BG 1.9 TDI with the Avf engine. I recently replaced the ABS control unit, exactly the same as my old one, and I coded it using the same method as I used with my old one, so all the data is exactly the same. He has identified the control unit, but when I perform a car scan, the error codes P1855 and P1649 appear. I would like to know why these error codes are now being stored in the memory. I would appreciate a response.
Best regards, Florian
dieselschrauber likes this.
Post19-09-2022, 11:36    Subject: P1855 Software Status Monitoring Sporadically Quote
Please set up the complete car scan here.
Pasi_222
Post19-09-2022, 21:46    Subject: P1855 Software Status Monitoring Sporadically Quote
"The scan of the steering angle sensor is already complete, but the other 2 are still throwing errors into the fault memory."
 File size:  5.71 MB
 Viewed:  3343 times
Post20-09-2022, 7:23    Subject: P1855 Software Status Monitoring Sporadically Quote
guste100 wrote:
Please set up the complete Auto Scan here.
Please save the complete Autoscan as text and post it here. This includes both the detected errors and the dependencies to other control units. It is also possible to check whether you are using a legitimate VCDS or a pirated copy.
Greetings
Guste
Simon89
Post15-09-2024, 11:03    Subject: P1855 Software Status Monitoring Sporadically Quote
Hello.
Is there already a solution to the problem?
I'm having the same problem. The error is in the engine control unit, and the ABS control unit cannot be coded despite using ODIS.
Maybe the OP is still active here and has a solution.
Simon
Knox92
Karma: +22 / -0   Thank you, like it!
Post15-09-2024, 21:51    Subject: P1855 Software Status Monitoring Sporadically Quote
Do you have a complete scan of the vehicle?
Is the control unit new or a used one that you installed?
Are the part numbers from the control units identical, especially the index at the end, which is often very important?
Best regards!
VCDS, VCP, Fahrzeugdoku & Anleitungen vorhanden
________________________________
Fahrzeuge:
- Golf 5 1.4 BUD 2009
- Touran 1T 1.9 BLS 2011
Simon89
Post19-09-2024, 9:16    Subject: P1855 Software Status Monitoring Sporadically Quote
Hello.
Thank you for your response. The scan is attached.
ABS control unit is the original. But it reset itself automatically.
Greetings
Log-DIRK-WVWZZZ3BZ2E422490-350890km.txt
 File name:  Log-DIRK-WVWZZZ3BZ2E422490-350890km.txt
 File size:  4.41 KB
 Downloaded:  205 times
No new posts ABS Light On: VW Transporter T4 Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L, Golf 4 etc. - Turn signal relay is malfunctio... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 8E2 Wiper Problems: Fix Sticking Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost Pressure Issues: Intermittent Problems? Diesel Engine Technology
No new posts ESP Warning Light: Causes and Solutions On-Board Diagnostics (OBD)
No new posts Coupling issues (intermittent) Diesel Engine Technology
No new posts Multi-Factor Authentication Issues: Troubleshooting Guide Transmission, Chassis, Body & Interior
