VCDS Update, Firmware Update - Troubleshooting
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post31-01-2025, 16:28    Subject: VCDS Update, Firmware Update - Troubleshooting Quote
Occasionally, I receive questions regarding VCDS updates or firmware updates. This article aims to address these recurring issues.
Generally, when using VCDS and many other diagnostic software programs on Windows computers, the following types of problems can occur:
  • During the software installation, parts of the installation package are skipped/deleted/quarantined.
    The cause is usually an overly aggressive antivirus scanner that "removes" parts of the software. So, if certain files, usually .exe files, are missing, check for that. For these types of problems, I recommend using Windows Defender as your antivirus software. The virus scanner has been identified as a problem; reconfigure it accordingly or remove it (use Windows Defender). Install VCDS over the existing installation.
  • Problems with the network configuration, especially firewalls.
    To update the firmware of a HEX-V2 or HEX-NET, certain ports on the internet must be accessible to the Ross-Tech servers. Check the corresponding messages from the firewall software, or inquire with (company IT) personnel to determine if the specified ports are accessible.
In some updates and with new features, VCDS not only updates the software installed on the PC, but also the firmware in the HEX-V2 or HEX-NET. To do this, the program VCIConfig.exe is used. I recently encountered a case with a customer where this program was missing (due to an antivirus scanner issue).
Some company IT systems are designed in a way that "hides" firewall or antivirus alerts, either to avoid alarming unsuspecting users or to conceal their own lack of competence. This is particularly frustrating because it's difficult to identify the root cause of these problems, and the programs simply don't behave as expected without any indication of what's being "prevented" in the background.
Good luck, Rainer.
PS: If you have any questions about the VCDS update, please post them in this thread.
FAQ about customer accounts, downloads (software updates), etc.
 Hinweisdialog vom VCDS Anschlusstest, der Klick auf "OK" öffnet VCIConfig.exe.
 File size:  158.84 KB
 Viewed:  2211 times
 VCDS Anschlusstest in den Einstellungen von VCDS.
 File size:  473.86 KB
 Viewed:  2261 times
 Fehlende Funktionalität im VCDS Interface aufgrund nicht durchgeführten, notwendigen Firmwareupdate(s).
 File size:  597.61 KB
 Viewed:  2137 times
 VCIConfig.exe, befindet sich im Installationsverzeichnis von VCDS.
Der Rechner muss zum VCDS Firmwareupdate Internetzugang haben und die entsprechenden Ports erreichbar sein. Wenn die IT von Dritten verwaltet wird, bitte mit Screenshot diese kontaktieren um die notwendigen Port(s) freizuschalten.
Das HEX-V2 bzw. das HEX-NET muss zum Firmwareupdate über USB mit dem Rechner verbunden sein.
 File size:  82.17 KB
 Viewed:  2139 times
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS 22.10 Update & HEX-V2 Firmware Update On-Board Diagnostics (OBD)
No new posts VCDS Update 20.12.0 On-Board Diagnostics (OBD)
No new posts VCDS RKS Update: MAC & Windows XP Support On-Board Diagnostics (OBD)
No new posts VCDS Update: Version 17.8.0 Released On-Board Diagnostics (OBD)
