1.4 TSI CAX Idle Jerking/Surging
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Gasoline Engine Technology
golifix
Post29-05-2022, 23:09    Subject: 1.4 TSI CAX Idle Jerking/Surging Quote
Hello everyone,
I'm new to this forum and I'm from Austria. In my fleet of vehicles, I have some older TDI and TSI models, and it was because of the problems these "problem children" can cause that I finally invested in a professional diagnostic system.
Currently, my A3 is experiencing the problem mentioned in the title, and neither my one-man workshop nor I can figure out the cause of the issue.
Here's a brief summary: Audi A3 8P 1.4 TSI, manufactured in 2008, purchased in 2012 with approximately 50,000 km. Timing chain replacement (without tensioner) at 125,000 km. At 175,000 km, the water pump and timing chain tensioner failed, requiring a complete timing chain replacement including the tensioner. Not operated under the longlife service interval; auxiliary heater used in winter.
In April, at 200,000 km, the engine suddenly developed a very unstable idle without any warning. The engine shakes and sounds "rough." The RPM drops to approximately 640 rpm. After a few seconds, the engine recovers and runs smoothly at 720 rpm. This cycle then repeats after about 10 seconds, or sometimes not at all. The engine accelerates normally, and no hesitation is noticeable even under light load conditions.
OEAMTC (Austrian Touring Club) diagnosed a misfire on all cylinders, particularly cylinder 3. The ignition coils and spark plugs were swapped to see if it would change anything, but there was no improvement. A new coil brought by the owner also didn't resolve the issue. The throttle body was cleaned, and the intake manifold was checked for vacuum leaks – still no improvement. The driver ultimately decided to take the car to a workshop based on this diagnosis.
In meiner Werkstatt wurden probeweise beide Ansaugluft/TemperaturfĂŒhler und der Benzindrucksensor getauscht, keine VerĂ€nderung. Danach die AnsaugbrĂŒcke abgebaut und ein Einspritzventil ersetzt. Keine Erkenntnisse, außer das der Ansaugtrakt völlig verrußt ist. Auto mit dem Hinweis das Beste wĂ€re es den Kopf zur Reinigung abzubauen heimgeholt. Zuhause die AnsaugkanĂ€le mit diversen Lösemitteln und KunststoffbĂŒrsten „fast wie neu“ gereinigt. Wagen "It pulls much better, the RPM only drops to 680 rpm now. The actual problem still persists, but there are no more misfire codes in the error memory!"
Recently, I replaced the high-pressure pump and the filter. The pump had been making unusual noises for a while, and after being idle for a long time, the engine wouldn't start properly on the first attempt – that issue is now resolved with the new pump.
What remains is an unstable idle state, lasting approximately 10 seconds, followed by a drop in RPM, shaking, and then stabilization after another 10 seconds. When the air conditioning is on, this entire process occurs with the RPM being roughly 100 RPM higher.
"I'm sorry for the long text, but maybe someone has a tip for me about what I should be looking for..."
Best regards, Andreas.
(Autoscann attached)
Translated on 14-07-2026, 22:05.
golifix
dieselschrauber likes this.
Post29-05-2022, 23:22    Subject: 1.4 TSI CAX Idle Jerking/Surging Quote
Sorry, this is my first post and I've already ended up in the wrong category; it seems the Autoscan file is also lost... icon_peinlich.gif I'm pasting it here.
And could someone please move this to the correct category for me?
Thank you.
Andreas.
Saturday, April 30, 2022, 3:38:28:33531.
VCDS – a Windows-based VAG/VAS emulator – runs on Windows 8.1 x64.
VCDS version: RKS 21.9.0.6 HEX-V2 CB: 0.4555.4
Data as of: 20220120 DS330.0
http://shop.dieselschrauber.org/en
Vehicle Identification Number (VIN): WAUZZZ8PX8A108440 License plate:
Vehicle type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
Vehicle Identification Number (VIN): WAUZZZ8PX8A108440. Mileage: 207,600 km.
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08 - Climate Control/Heating Unit - Status: Error 0010.
09-Central Electrical System -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: Error 0010.
17-Terminal block insert -- Status: OK 0000
19-pin diagnostic interface -- Status: Error 0010.
Immobilizer system -- Status: OK 0000
42-Door Electric Driver -- Status: Error 0010.
Steering assist - Status: OK 0000.
46-Comfort System -- Status: Error 0010.
52-door electric passenger door - Status: Error 0010.
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: Error 1010.
72- Door, electric, high, right side -- Status: OK 0000
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Feld und lÀsst das Gras sanft wiegen. Es ist ein wunderschöner Tag."
The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze blows through the field, causing the grass to sway softly. It's a beautiful day.
Address 01: Engine Control Module (ECM)
Label file: DRV\03C-906-022-CAX.clb
Part number SW: 03C 906 022, HW: 03C 906 022.
Component: MED17.5.20 G 1580
Revision: D3H05--- Serial Number: AUX7Z0GNFN5046
Encoding: 0000072
Operating number: WSC 00342 219 174720
VCID: 59EE71DBF5115D7380B-800C
VINID: 9D196AAAA220A08441008104003AF755EA
No error codes found.
Readiness: 0110 0001
Address 03: Brake Electronics
Label file: DRV\1K0-907-379-MK60-F.lbl
Part number SW: 1K0 907 379 AC, HW: 1K0 907 379 AC.
Component: ESP FRONT MK60 0101
Revision: 00H11001
Encoding: 0019074
Operating number: WSC 06314 000 00000
VCID: 73B2237377BD0723AA7-8026
Address 08: Climate Control/Heating. Label file: DRV\8P0-820-043.lbl
Part number SW: 8P0 820 043 AG HW: 8P0 820 043 AG
Component: Climate Control Unit H19 0420.
Revision: 215797 Serial number: 8P0820043AG
Operating number: WSC 00000 000 00000
VCID: 71BE297B0DA1353358B-8024
"One error found:"
01333 - Rear left door control unit (J388)
004 - No signal/communication - Intermittent.
Environmental conditions:
Error status: 00100100
Error priority: 3
Error frequency: 8
Lost Count: 250
Mileage: 206,567 km
Time: 0.
Date: 2022.03.31
Time: 18:08:52
one
Address 09: Central Electronics; Label file: .DRV\8P0-907-279-30-B.lbl
Part number SW: 8P0 907 279 J HW: 8P0 907 279 J
Component: On-board network module H54 2501.
Revision: 00H54000 Serial Number: 00000007838335
Encoding: 088C0F01901410004F1600001600000000084A175C010000000000000000
Operating number: WSC 06314 000 08192
VCID: 44D0B0AF6293F09BC3D-8010
Subsystem 1 - Part number: 8P1 955 119 E
Label file: DRV\1KX-955-119.CLB
Component: Wiper blade AU350 H01 0130.
Encoding: 00062736
5 error codes found:
03098 - Lamp for rear left turn signal (M6).
012 - Electrical fault in the circuit - Intermittent.
Error status: 00111100
Error priority: 2
Error frequency: 1.
Lost Count: 236
Mileage: 207,320 km
Time: 0.
Date: 2022.04.07
Time: 17:22:00
text
from
Voltage: 12.50 V
text
from
one
text
from
text
from
text
from
00987 - Lamp for left brake light (M9).
Error status: 00101100
Error priority: 1.
Error frequency: 1.
Lost Count: 236
Mileage: 195909 km
Time: 0.
Date: 2021.11.25
Time: 05:52:00
one
Voltage: 12.75 V
one
one
text
from
text
from
one
00984 - Lamp for left taillight (M4).
Error priority: 2
Error frequency: 1.
Lost Count: 236
Mileage: 207,320 km
Time: 0.
Date: 2022.04.07
Time: 15:15:00
text
from
Voltage: 12.50 V
text
from
one
text
from
text
from
text
from
01259 - Fuel pump relay (J17)
009 - Intermittent short circuit to ground.
Error status: 00101001
Error priority: 5
Error frequency: 4
Lost Count: 226
Mileage: 206,616 km
Time: 0.
Date: 2022.04.03
Time: 17:47:00
text
from
Voltage: 12.40 V
text
from
one
text
from
text
from
text
from
Error priority: 2
Error frequency: 26.
Lost Count: 250
Mileage: 206,507 km
Time: 0.
Date: 2022.03.29
Time: 17:36:00
text
from
Voltage: 12.70 V
text
from
one
text
from
text
from
text
from
Address 15: Airbag
Label file: DRV\8P0-959-655-94.lbl
Part number SW: 8P0 959 655 L, Hardware part number: 8P0 959 655 L.
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial Number: 003CP001RST$
Encoding: 0071612
VCID: 4BC29B934FCD3FE3027-801E
Subsystem 1 - Serial number: 6332DRB4064652129.
Subsystem 2 - Serial number: 6342DRB4064290ADS.
Subsystem 3 - Serial number: 63528RB403268F43L.
Subsystem 4 - Serial number: 63628RB4032B5505C.
Subsystem 5 - Serial number: 63747RB403274937I.
Subsystem 6 - Serial number: 63847RB403274B4FU.
Address 16: Steering wheel electronics
Label file: DRV\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 AH, HW: 1K0 953 549 AH.
Component: J0527 036 0070
Encoding: 0000022
VCID: 78A8145F6EDB647B9F5-802C
"One error found:"
00883 - Ignition switch (German) Terminal S.
Address 17: Control panel module
Label file: DRV\8P0-920-xxx-17-MY8.clb
Part number SW: 8P0 920 901 J, Hardware part number: 8P0 920 901 J.
Bauteil: KOMBIINSTR. VDO H22 0650
Revision: D0H22002 Serial Number: 124NG002100321
Encoding: 0004123
Operating number: WSC 82000 110 00001.
VCID: 372AD7632345AB0356F-8062
Address 19: Diagnostic interface
Label file: .DRV\1K0-907-530-V3.clb
Part number SW: 1K0 907 530 L, HW: 1K0 907 951.
Component: J533__Gateway H15 0180
Revision: H15 Serial Number: 1400K07B0800EB
Encoding: E9807F060002022102
VCID: 3038EC7FC62B7C3B175-8064
"One error found:"
Error priority: 2
Error frequency: 29.
Lost Count: 250
Mileage: 206,507 km
Time: 0.
Date: 2022.03.29
Time: 17:36:59
Address 25: Immobilizer
Label file: DRV\1K0-920-xxx-25.clb
Part number SW: 8P0 920 901 J, Part number HW: 8P0 920 901 J.
Revision: D0H22002 Serial Number: AUX7Z0GNFN5046
Address 42: Door electric control unit
Label file: 8P0-959-801-MIN3.lbl
Part number SW: 8P0 959 801 K, Part number HW: 8P0 959 801 K.
Component: Door module H03 0050
Coding: 0000176
VCID: 43D2B3B3679DF7A3FA7-8016
"One error found:"
02071 - Local data bus.
Address 44: Steering Assist
Label file: DRV\1Kx-909-144-G2V3.clb
Part number: 1K1 909 144 M
Component: EPS_ZFLS Class 078 H08 1901.
Operating number: WSC 02069 000 90108
VCID: 3536DD6B39495913443-8060
Address 46: Comfort System
Label file: DRV\8P0-959-433.lbl
Part number: 8P0 959 433 L
Component: KSG H11 0080
Encoding: 1880202002186D0985054C8F0167
VCID: 45D6ADAB69A9C993D43-8010
Subsystem 1 - Component: Sounder (not mounted)
Subsystem 2 - Component: NGS, not mounted.
Subsystem 3 - Component: IRUE (not mounted)
Two error codes found:
00950 - Motor for central locking system, tailgate (V53); UNLOCK.
007 - Short circuit to ground - Intermittent.
00849 - S terminal at the ignition switch (German).
008 - implausible signal - sporadic.
Address 52: Door electric, passenger side. Label file: .DRV\1K0-959-702-MIN3.clb
Part number SW: 8P0 959 802 K, HW: 8P0 959 802 K.
Coding: 0000176
"One error found:"
Address 56: Radio
Label file: DRV\8J0-035-1xx-56.clb
Part number SW: 8P0 035 152 C. Hardware: 8P0 035 152 C.
Component: R Chorus2+ H01 0270
Revision: 00H01000 Serial Number: AUZ1Z2G9270997
Encoding: 0000221
VCID: 2B02FB13EF0D1FE3227-807E
Address 62: Door electrical, left/right. Label file: DRV\8P4-959-801.lbl.
Part number SW: 8P4 959 801 E. Part number HW: 8P4 959 801 E.
Component: Door Module H04 0040
Coding: 0000144
Operating number: WSC 06314 000 1012544
VCID: 41DEB9BB7D81E5B3E8B-8014
"One error found:"
Address 72: Door electric strike, right side. Label file: DRV\8P4-959-802.lbl
Part number SW: 8P4 959 802 E. Part number HW: 8P4 959 802 E.
Coding: 0000144
VCID: 42DCB6B77887FEABF11-8016
End -------- (Duration: 01:10, Battery voltage start/end: 12.2V/12.3V) ---------
Translated on 14-07-2026, 22:45.
Post30-05-2022, 21:52    Subject: 1.4 TSI CAX Idle Jerking/Surging Quote
Unfortunately, I have no idea about the engine mechanics themselves, but what do the adjustment values for the lambda control system indicate? At least there, you would see if there are any errors in the fuel-air mixture preparation.
I would also like to see if there's something like a "load" measurement block, or observe the current injection quantity.
It's important that an auxiliary component, such as the air conditioning compressor, doesn't draw more power than usual.
Translated on 14-07-2026, 22:46.
Ich_Can_nix
Karma: +248 / -0   Thank you, like it!
dieselschrauber and Turbinchen likes this.
Post11-06-2022, 23:34    Subject: 1.4 TSI CAX Idle Jerking/Surging Quote
Good evening.
"Sorry, I just discovered this post now."
I once did something crazy – I went on vacation.
I experienced the same problem with an Audi A3 manufactured before 2009, equipped with a CAXC engine. It exhibited uneven running and occasional, sporadic misfires that occurred across all cylinders.
The cam bearing retaining ring had detached from the camshaft.
The camshaft has been replaced.
See TPI 2023011/2.
Since March 2009, optimized camshafts have been installed.
Michael.
Translated on 14-07-2026, 22:47.
golifix
Post07-07-2022, 13:11    Subject: 1.4 TSI CAX Idle Jerking/Surging Quote
dieselschrauber wrote:
Unfortunately, I have no idea about the engine mechanics themselves, but what do the adjustment values for the lambda control system indicate? At least, you would be able to see if there are any errors in the fuel-air mixture preparation there.
I would also like to see if there's something like a "load" measurement block, or if it's possible to observe the current injection quantity.
Best regards, Rainer
It took some time, and it's now my son's car, so it's not always readily available.
The engine still exhibits the same behavior even after a cold start, so I don't think the lambda control is playing a role. (!!) The learning values of the engine control unit have been erased multiple times, but it never made a noticeable difference.
The belt was loose, and neither the water pump, alternator, nor compressor were rotating unusually stiffly. The alternator was also disconnected via the D+ signal to ensure it wasn't being rhythmically controlled by the engine control unit. The idle speed is slightly increasing, but the behavior of the engine isn't changing significantly.
There's a channel in the engine control unit (ECU) called "load request," and its numerical value increases slightly at the same time that the engine speed drops. Similarly, the injection times increase slightly. This all happens until the engine speed returns to its optimal level. However, both the engine speed and load regulation always remain within the target range. The older ECU doesn't yet have measurement channels that describe the desired state.
The idle speed never drops below the "acceptable" value, so the car is drivable under normal conditions – finding a solution to this problem would be quite interesting.
"The compression/pressure loss hasn't been checked yet. Could we see anything about it in the knock sensor readings?"
Andreas
Translated on 14-07-2026, 22:51.
golifix
Post07-07-2022, 13:29    Subject: 1.4 TSI CAX Idle Jerking/Surging Quote
Ich_Can_nix wrote:
Good evening,
See TPI 2023011/2.
Michael
Indeed, CAXC 03/2008. There was nothing to find in the vehicle's history up until 2012; we have owned it since then.
During the high-pressure pump replacement, the cam was visible in the center of the bore on the intake side. Is there a way to assess the condition without removing the valve cover?
Andreas
Translated on 14-07-2026, 22:55.
Post15-07-2022, 12:55    Subject: 1.4 TSI CAX Idle Jerking/Surging Quote
Error status: 00101001.
Error priority: 5.
Error frequency: 4.
Lost Count: 226
Mileage: 206,616 km
Time: 0.
Date: 2022.04.03
Time: 17:47:00
Has this error been addressed before?
Translated on 14-07-2026, 22:58.
golifix
Post24-07-2022, 12:31    Subject: 1.4 TSI CAX Idle Jerking/Surging Quote
Error priority: 5.
Error frequency: 4.
Lost Count: 226
Mileage: 206,616 km
Time: 0.
Date: 2022.04.03
Time: 17:47:00
Wurde diesem Fehler mal nachgegangen?
Hi, sorry for the late reply, I was on vacation.
This error has been cleared and hasn't reappeared so far; it likely occurred during troubleshooting.
Today, I found a new bug in the memory.
000308 - Bank 1, Sensor 1.
P0134 - 000 - No activity detected - Intermittent.
Error status: 00110000
Error priority: 0.
Error frequency: 1.
Lost Count: 255
Mileage: 211,931 km
Time: 0.
Date: 2022.07.01
Time: 09:01:42
"...but it's from July 1st, and I've driven a few hundred kilometers since then. I deleted the data and will drive for a few days before reading it again."
Andreas
Translated on 14-07-2026, 23:01.
golifix
dieselschrauber and E30_V8 likes this.
Post08-02-2023, 13:37    Subject: 1.4 TSI CAX Idle Jerking/Surging Quote
Update after six months and almost 40,000 km:
The oxygen sensor was replaced due to recurring error messages. The engine misfire has become less and less frequent and is now completely gone. I have never been able to identify any connection with the parameters of the engine control unit.
It was probably just the dirty air intake all along...
Thank you for your efforts.
Andreas
Translated on 14-07-2026, 23:05.
golifix
Post06-08-2025, 12:48    Subject: 1.4 TSI CAX Idle Jerking/Surging Quote
last updated:
Today, our paths diverged at kmStand: 322000; the rust forced me to stop.
The error described above has not occurred again. To date, the engine has "consumed" two timing chains and one variable valve control unit, and another chain replacement would have been due. The oil consumption until the end was approximately 1 liter per 10,000 kilometers.
Andreas
Translated on 14-07-2026, 23:06.
Post06-08-2025, 14:42    Subject: 1.4 TSI CAX Idle Jerking/Surging Quote
Translated on 14-07-2026, 23:07.
No new posts Golf 7, 1.4 TSI CHPA Gasoline Engine Technology
No new posts Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Gasoline Engine Technology
No new posts Idling Jerk on Golf TDI PD, Engine Code ATD Diesel Engine Technology
No new posts Log file: Idle surging on AJM engine Upload
