Audi A3 8P Steering Angle Sensor G85
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Ralph75
Post27-05-2025, 8:41    Subject: Audi A3 8P Steering Angle Sensor G85 Quote
Hello community,
I have a customer's vehicle here under warranty, and it's driving me crazy.
Audi 8P, 2003.
Error: Steering angle sensor G85.
I replaced it with one from Febi, but that one was new and unfortunately defective, which caused me to waste a week troubleshooting.
A new OEM part has now been installed, and it paired successfully without any issues. Since then, the error is no longer persistent but occurs sporadically.
I can't pinpoint the exact cause, as it sometimes happens after 2 hours of driving without any issues, and other times just 20 seconds after starting the engine.
Address 44: Steering Assist
Label file: DRV\1Kx-909-143-GEN1.clb
Part number: 1K1 909 143 L
Component: EPS_ZFLS, Size 6, 0402.
Operating number: WSC 00000 000 00000
VCID: 33426B938EED9AE762-8066
"One error found:"
00778 - Steering angle sensor (G85).
013 - Please read the error memory.
I don't have anyone who can help me with this, and all the Bosch service centers and similar companies are refusing to assist.
My VW mechanic mentioned things like wheel sensors, etc., but I checked everything through the measurement blocks while driving, and everything seems to be fine.
Something's not quite right; I can't seem to see the forest for the trees, or maybe I'm stuck and missing something.
Perhaps someone among you has a tip or idea about what I can check to make progress.
Sure, here's the translation:
"Thank you in advance."
Ralph.
Translated on 16-07-2026, 7:22.
Post27-05-2025, 11:51    Subject: Audi A3 8P Steering Angle Sensor G85 Quote
Hi Ralph,
Please perform a complete car scan.
Perhaps you will see more then.
"LG" translates to "Best regards" or "Sincerely" in English. It is a common abbreviation used at the end of emails and letters.
Translated on 16-07-2026, 7:25.
dieselschrauber likes this.
Post27-05-2025, 14:37    Subject: Re: Audi A3 8P Steering Angle Sensor G85 Quote
Ralph75 wrote:
Mal sind 2 Stunden keine Fehler im Fahrbetrieb, mal 20 Sekunden nach dem Starten.
You mentioned that the error sometimes appears 20 seconds after starting. Does this mean the error occurs even when the vehicle is stationary, or only while it's moving?
If it only occurs while driving, I would suggest logging the individual wheel speeds during straight-line driving and cornering over a longer period of time to see if there are any occasional anomalies. (This is only possible on some vehicles at low speeds (<20 km/h, I believe).)
Translated on 16-07-2026, 7:26.
Ralph75
dieselschrauber and guste100 likes this.
Post27-05-2025, 14:55    Subject: Audi A3 8P Steering Angle Sensor G85 Quote
I logged the wheel speeds, and they were all within normal range.
I think I just found the error.
Fault code: Steering angle sensor (G85) defective.
Replaced with a Febi part; not programmable, which is a shame considering the time spent troubleshooting and attempting to program it. At least the Febi was a new part.
Then I ordered the part from an OEM supplier, and now a package arrived with "OEM" printed on it.
It was easy to pair initially, but now I'm getting error code 07788: steering angle sensor, intermittently. I've been troubleshooting this for over a week.
Today, I installed a steering angle sensor from a Volkswagen Golf V. This vehicle is currently in my inventory as a sales car.
After re-pairing, all the errors have disappeared.
I've test-driven it several times now, and each time I've checked the error codes, there are none – no intermittent errors, nothing at all.
Parking, unparking, turning left and right - no errors.
It was obviously due to both of the non-OEM sensors, as the one from the Golf V works perfectly fine.
Thank you for your help. When it comes to two new steering angle sensors, one wouldn't necessarily think of those specific components.
Ralph.
Translated on 16-07-2026, 7:29.
Post27-05-2025, 16:56    Subject: Audi A3 8P Steering Angle Sensor G85 Quote
Translated on 16-07-2026, 7:31.
Ralph75
dieselschrauber, brezelmann01 and Turbinchen likes this.
Post28-05-2025, 8:32    Subject: Audi A3 8P Steering Angle Sensor G85 Quote
Here's some feedback again, following the previous feedback icon_smile.gif.
Since I still can't believe it, but the A3 has been working perfectly without any issues since yesterday, I just installed the Metzger OEM sensor into the Golf, which is where I removed the original VW steering angle sensor that was intended for the A3.
Immediately, the same problems that were present in the A3 model appeared in the Golf.
So, as unbelievable as it may seem, it's actually true.
The febi part couldn't be paired initially. The Metzger part can be paired, but it displays the error message "Steering angle sensor intermittently."
It took me three weeks to do that.
In the future, I will only use original parts for this type of component.
Ralph.
Translated on 16-07-2026, 7:32.
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Steering Angle Sensor VW Polo 9N On-Board Diagnostics (OBD)
No new posts Calibrate steering angle sensor G85 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Steering Angle Sensor Calibration Issues On-Board Diagnostics (OBD)
No new posts Steering Angle Sensor Golf 4: Location & Installation On-Board Diagnostics (OBD)
