Brake fluid change Audi A4 8K (Solution)
dieselschrauber, Turbinchen and durnesss likes this.
Post06-04-2019, 20:32    Subject: Brake fluid change Audi A4 8K Quote
This model features a reservoir for brake fluid that is divided into multiple chambers, with a separate chamber specifically for the clutch hydraulics.
The threshold for overflow from the main chamber (into which you add liquid) is set very high. So high that, with a sufficiently full container, nothing can spill out.
The volume of the chamber is then insufficient to allow for the fluid change in the clutch hydraulics as specified by the manufacturer (150 ml). You can't replace the filling in one go; instead, you pump air into the system.
Therefore, when changing the brake fluid or bleeding the brakes, it is essential to monitor the fluid level. It's best to fill the container completely to the brim beforehand.
Post16-07-2025, 13:02    Subject: Brake fluid change Audi A4 8K Quote
Brake fluid reservoir, Audi A4, 8K.
 File size:  164.53 KB
 Viewed:  5844 times
Ratings - Brake fluid change Audi A4 8K
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts Audi 80 B4 On-Board Diagnostics (OBD)
No new posts LOG Audi 2.5 AKE Upload
No new posts Audi AFB STG: Repair & Replacement Diesel Engine Technology
