Summary: Does anyone know a cheap workshop that can replace the DQ200 clutch discs?
My DQ200 from 2014 has recently been reporting:
Code: |
| 21211 - Gangsteller 4 nicht regelbar P176D 00 [10001000] - - |
Most of the time, after switching from R (Drive) to D (Reverse), the error message "Gear malfunction, Reverse gear not available" appears. Then only gears 1, 3, 5, and 7 will function.
The (easily replaceable) memory module was replaced (after a previous failure) two years ago.
I suspect that the "Schlupfperlen" for the double switch fork for 6/R are now being installed. The repair is too complicated for me to do myself (even if I were able to).
Inquiry with a local gearbox specialist in the far north resulted in a quote of 4,400€. Request in the area approximately 500km south of Cologne resulted in a payment of 2400€.
Has anyone had good experiences with a more affordable provider? Possibly somewhere near the border, such as in Poland or elsewhere?
The car is over 10 years old and has over 250,000 km. Residual value intact, probably around €5,000... Selling the item as "defective" could also be an option, if someone knows of good "flippers" (people who buy and resell used items).
Thank you for your tips.
Guste
