Audi A6: Door Sill Removal Guide
tobi999
Post23-11-2004, 11:32    Subject: Audi A6: Door Sill Removal Guide Quote
Dear A6 experts,
Within the (door frame), there's a strip at the bottom that has a silver Audi logo. I would like to remove it and clean off the dirt and salt. icon_question.gif
I've tried gently to remove it before, but the strip is really stuck on tight. What's the trick to getting it off?
Thank you in advance, and best regards, Tobias.
Translated on 10-09-2026, 8:51.
Post23-11-2004, 11:46    Subject: Audi A6: Door Sill Removal Guide Quote
Take a look at this.
http://www.passat3b.de/tips.php
According to the information provided, you won't have much success there, as the things are glued on. So, if you want to remove them, you'll have to use a lot of force, and you won't be able to clean them afterwards.
But since it's glued in, there's probably not much dirt underneath, and you can probably clean it while it's still installed.
Translated on 10-09-2026, 8:52.
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 2.5 TDI Engine Exploded View Diagram and Front Disasse... Diesel Engine Technology
No new posts Disassembling ZMS: A Step-by-Step Guide Transmission, Chassis, Body & Interior
No new posts Rear bumper removal Audi A6 4F sedan Transmission, Chassis, Body & Interior
No new posts Passat 1.9 TDI Visco Coupling/Power Steering Pump Removal Transmission, Chassis, Body & Interior
