A3: Error code 01367 "Central locking pump shut-off"
Peter
Post12-08-2003, 23:26    Subject: A3: Error code 01367 "Central locking pump shut-off" Quote
Hi there,
In the error memory of the central locking system for my Audi A3 (manufactured in March 1998), the following code is displayed:
Error code 01367.
'Pump shut-off for central locking.'
35-00--
Has anyone else experienced this before, and could someone possibly explain to me what's going on?
I haven't noticed any malfunctions so far.
And what does '35-00--' mean?
'Thank you!'
Peter.
Translated on 11-07-2026, 23:00.
Michael II
Post13-08-2003, 7:54    Subject: A3: Error code 01367 "Central locking pump shut-off" Quote
Possible causes include:
- Insufficient pressure in the pneumatic lines (leak).
- Central vacuum pump failure.
Tschüss
Michael II
Translated on 11-07-2026, 23:01.
Post13-08-2003, 9:01    Subject: A3: Error code 01367 "Central locking pump shut-off" Quote
I've also been experiencing this error sporadically for more than a year.
Car: Audi A3, manufactured in July 1998.
@MichaelViewing profile: Michael: I understand the error to be that after activating the main switch, the pump...
a) either doesn't start up (never observed, always makes a "rrrrrrrr" sound).
b) It starts up, but due to a leak or a faulty pump, not enough vacuum is generated for it to shut off. However, I have never been able to detect an excessively long "rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr" sound.
Since the error occurs sporadically and there have been periods of several months without it happening, I'm just going to wait and see.
Translated on 11-07-2026, 23:03.
Michael II
Post13-08-2003, 9:05    Subject: A3: Error code 01367 "Central locking pump shut-off" Quote
Hello Rainer,
"Air leaks are a common problem with the pneumatic suspension system. Over time, the air lines (especially at the connectors) can become leaky. This causes the pump to take longer to complete each cycle. If a certain amount of time is exceeded, this error will occur. I've experienced this issue on an A4 Avant MJ '97 and an A3 MJ '00. It's not a pleasant job to check and repair the system."
Tschüss
Michael II
Translated on 11-07-2026, 23:04.
Post13-08-2003, 9:10    Subject: A3: Error code 01367 "Central locking pump shut-off" Quote
What still surprises me is:
35 means no error type (no further description).
10 means "error is sporadic".
00 means the error is permanent
The error isn't constant; I'm just doing nothing and waiting for the central ventilation system to stop working.
What about the trunk lid? Does it have a vacuum hose that's sensitive to kinks running to the lock, or a cable with its own pump?
Könnte mir vorstellen, daß bei der Kabeldurchführung/Schlauchdurchführung zur Klappe was gebrochen ist. Das war beim letzten 2er Golf ne Dauerkrankheit. icon_rolleyes.gif
Translated on 11-07-2026, 23:06.
Michael II
Post13-08-2003, 9:14    Subject: A3: Error code 01367 "Central locking pump shut-off" Quote
Hello Rainer,
In our MJ models, the tailgate is also operated via a pneumatic line.
The damage on the A3 was to the driver's door (the rubber grommet was torn), and on the A4, it was to the rear right door (also with a torn grommet).
Tschüss
Michael II
Translated on 11-07-2026, 23:07.
Post13-08-2003, 9:17    Subject: A3: Error code 01367 "Central locking pump shut-off" Quote
Okay, thanks! I'll take a look at the places you mentioned sometime.
Michael II
Post13-08-2003, 9:28    Subject: A3: Error code 01367 "Central locking pump shut-off" Quote
Here are the plans for the 3-door and 5-door models.
 File size:  33.24 KB
 Viewed:  10407 times
 File size:  28.3 KB
 Viewed:  5862 times
Tschüss
Michael II
Translated on 11-07-2026, 23:08.
Peter
Post13-08-2003, 9:32    Subject: A3: Error code 01367 "Central locking pump shut-off" Quote
Hello Michael,
Thank you for the suggestions, I will take a look at them.
Peter.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kann ich an einem Pumpe Düse Element die "Spitzen&q... Diesel Engine Technology
No new posts Audi A6 2.5 TDI error code "00575 intake manifold pressure" Diesel Engine Technology
No new posts A3 8P ESP Abschaltung Stufe 2 Diesel Engine Technology
No new posts Glühstiftzusatzheizung im AFN - temporäre Abschaltung Diesel Engine Technology
