A4/B5: Instrument Cluster Replacement, Seal Issues
flaufer
Post17-08-2003, 11:16    Subject: A4/B5: Instrument Cluster Replacement, Seal Issues Quote
Hello!
Sure, here's the translation:
'Short question:'
My instrument cluster was recently replaced because the PM display was having contrast issues (and it was covered by my warranty insurance).
Yesterday, I noticed that what appears to be sealing rings (fabric material) are 'protruding' from the top of the air vents in the center.
Could this be related to the instrument replacement (poor workmanship), or could it possibly be due to the extreme heat of the past few days?
Felix.
Translated on 06-10-2026, 23:00.
Michael II
Post17-08-2003, 17:01    Subject: A4/B5: Instrument Cluster Replacement, Seal Issues Quote
actually, you never know with workshops, but this probably has nothing to do with...
The combination instrument needs to be changed.
Tschüss
Michael II
Translated on 06-10-2026, 23:01.
Manuel Thomas
Post17-08-2003, 18:28    Subject: A4/B5: Instrument Cluster Replacement, Seal Issues Quote
'That's right, with the B5, you can remove the instrument cluster without having to disconnect anything else. Just loosen four screws towards the steering wheel and pull it straight out!'
Unfortunately, the piece of fabric that comes loose from the middle nozzle is a common issue with the B5 model! It happens to about half of the cars. The solution is quite simple: remove the nozzle and then reinstall it!
Manuel.
Translated on 06-10-2026, 23:02.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Immobilizer Replacement: Questions & Answers On-Board Diagnostics (OBD)
No new posts Diesel to Gas Gauge Cluster Swap: Possible? Diesel Engine Technology
No new posts Passat 3B - Issues with Comfort Control Unit / Instrument... On-Board Diagnostics (OBD)
No new posts ESP Leak / Seals: Causes & Solutions Diesel Engine Technology
