Steering Problems? Get Expert Help Now!
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post28-07-2009, 23:29    Subject: Steering Problems? Get Expert Help Now! Quote
HI,
Why is the steering in a standard Golf 4 easier than in a Seat Leon TopSport? This was tested with identical tires: 18-inch wheels and a 225mm width. If it's an intentional design choice for the steering system, why only for certain models?
It really gets on my nerves when I have to go on long trips.
Do you have similar experiences?
reflexsilber met.
Translated on 21-08-2026, 10:28.
Post28-07-2009, 23:33    Subject: Steering Problems? Get Help Now! Quote
A friend of mine has a top-of-the-line sports car, and the steering feels exactly like it does in my Golf. Actually, I haven't driven any Leons yet where the steering felt significantly heavier or lighter.
What is the difference in your case?
Translated on 21-08-2026, 10:29.
Devilseye503
Post29-07-2009, 2:02    Subject: Steering Problems? Get Expert Help Now! Quote
It seems like the steering systems in different Leon models can vary quite a bit in terms of how easily they turn. In my first Leon, the steering was lighter than in a later model year.
Translated on 21-08-2026, 10:30.
RedR32
Avatar-RedR32
Post29-07-2009, 18:54    Subject: Steering Problems? Get Expert Help Now! Quote
The differences lie in the variants of the models. The Leon Sport, Cupra, or Golf GTI have a slightly heavier steering system with limited power steering assist due to the larger wheels they are equipped with. This steering feel is likely also intentionally tuned to be firmer. In my ALH G4, which has no sporty or GT/GTI trim, a different steering system is installed. I can tell this by the part numbers and PR codes.
You can really feel the difference when you have a direct comparison, like I do.
Has anyone ever remodeled something because of this annoyance?
reflexsilber met.
Post29-07-2009, 19:30    Subject: Steering Problems? Get Expert Help Now! Quote
RedR32 wrote:
Golf GTIs have a slightly heavier steering feel with power steering assistance limitations
To my knowledge, only the R32 in the fourth generation Golf had a different steering rack (requiring fewer turns from lock to lock) compared to the other models.
Translated on 21-08-2026, 10:32.
RedR32
Avatar-RedR32
Post29-07-2009, 22:58    Subject: Steering Problems? Get Expert Help Now! Quote
There are different steering systems; compare the part numbers and product codes. The steering gear seems to play a major role in vehicle manufacturers' chassis tuning.
Besides replacing the steering gear, are there any other options? For example, could the control valves be changed? If anyone knows anything about this, please share your knowledge.
reflexsilber met.
Devilseye503
Post30-07-2009, 0:24    Subject: Steering Problems? Get Expert Help Now! Quote
'@redr32 - if that's the case, it makes sense. Also, I think the steering in the sport models feels less precise... not so nice. On the other hand, driving on the highway at high speeds is more relaxed this way.'
Translated on 21-08-2026, 10:33.
No new posts Document: Audi A3, from 05/03, Seat lengthwise adjustment... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Luop 6X1 MJ 2002, Window regulators stiff Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Loading pressure too high, ASZ (likely referring to a spe... Upload
No new posts Gear linkage stiff, adjust clutch? Diesel Engine Technology
No new posts Rear Brake Caliper: Sticking Handbrake Mechanism Transmission, Chassis, Body & Interior
No new posts Is Lima's clutch always so difficult to engage? Diesel Engine Technology
