AGR Deactivation / Longlife Interval
jti
Post13-02-2004, 23:45    Subject: AGR Deactivation / Longlife Interval Quote
Does deactivating the Diesel Particulate Filter (DPF) affect the amount of soot produced and therefore the mileage until the next long-life service? It seems like it should, since a deactivated DPF would presumably release less soot from the back. Or have I misunderstood something?
Jürgen.
Translated on 20-07-2026, 6:58.
Marco
Post13-02-2004, 23:57    Subject: AGR Deactivation / Longlife Interval Quote
Hi jti,
What else can I say about this?!?
The deactivation of the automatic gearbox (AGR) does not affect the long-life service interval.
Translated on 20-07-2026, 6:59.
christians
Post14-02-2004, 1:48    Subject: Re: AGR Deactivation / Longlife Interval Quote
jti wrote:
Or did I misunderstand something?
Probably yes. The oil's wear is not measured directly but estimated based on operating conditions.
Gruß Christian
Translated on 20-07-2026, 7:00.
Avatar-Jan6K
Post14-02-2004, 11:50    Subject: AGR Deactivation / Longlife Interval Quote
When an EGR system is deactivated, less soot is produced because there is simply less soot being "generated," not because the existing soot remains somewhere else (e.g., in the oil). Therefore, you don't need to worry about the Loglife service; instead, you should be concerned about the car's operating permit, which expires when the EGR system is deactivated.
Jan.
1Z5 CFHF / AHB H4D
Translated on 20-07-2026, 7:01.
palmstrollo
Post14-02-2004, 12:18    Subject: AGR Deactivation / Longlife Interval Quote
Hi.
Da durch die stillgelegt AGR weniger Ruß prodiziert wird, gelangen auch weniger Rußanteile/ Schwebeteilchen in's Öl. Das LL-Intervall ist unbeeinflusst; die Ölqualität am Ende des Intervalls dürfte allerdings noch erheblich besser sein, als mit intakter AGR. Es gibt zudem spezielle Microfilter, die sämtliche Rußteilchen aus dem Öl herausfiltern. Dies geschieht mit einem zusätzlich in den Kreislauf eingebrachten Spezialfilter. DadSome manufacturers claim that even with extended service intervals of 90,000 km, the oil can maintain its lubricating properties without degradation.
Hermann.
Translated on 20-07-2026, 7:02.
mersente
Post14-02-2004, 20:18    Subject: AGR Deactivation / Longlife Interval Quote
There's nothing to add to the comments except that the amount of nitrogen oxides increases when you close the EGR valve because this raises the combustion temperature.
Otherwise, it only has advantages.
Post15-02-2004, 8:50    Subject: AGR Deactivation / Longlife Interval Quote
mersente wrote:
There's nothing to add to the comments except that the amount of nitrogen oxides increases if you close the EGR system, because this raises the combustion temperature...
... and therefore, the oil temperature also increases (slightly), and the control unit assumes a higher load. Consequently, the service life interval could even shorten.
The oil temperature (and its temperature profile) is the most important factor to consider when calculating the service interval.
Translated on 20-07-2026, 7:03.
Gremlin
Post15-02-2004, 11:50    Subject: AGR Deactivation / Longlife Interval Quote
Well, then I can reassure you...
My car needs to go in for servicing at 42,600 km.
The EGR valve has been defective since the car reached a mileage of 3000 km.
CU Gremlin.
Translated on 20-07-2026, 7:04.
Julian
Post15-02-2004, 15:11    Subject: AGR Deactivation / Longlife Interval Quote
'Yes, me too. The oil temperature is not affected by the EGR system. I've already tested this on an ALH engine, and it won't be any different on an AWX engine.'
And with the AWX engine, the AGR (Automatic Guided Reading) system has been 'defective' since kilometer : 7, and according to the longlife maintenance schedule, the timing chain needs replacement only at 32,000 km, given my driving style. This is an extremely good value for the AWX engine, but compared to Gremlin's value, it pales in envy. icon_wink.gif
Translated on 20-07-2026, 7:05.
No new posts Service Interval Display for Longlife Oil Diesel Engine Technology
No new posts AGR Deactivation: Questions & Answers for TDI Diesel Engine Technology
No new posts No power after removing the EGR valve on an AFN TDI Diesel Engine Technology
No new posts Longlife Service: Your Questions Answered On-Board Diagnostics (OBD)
