Engine-Gearbox Flange: Slight Oil Leak
donalexo
Post21-09-2003, 12:48    Subject: Engine-Gearbox Flange: Slight Oil Leak Quote
Hello fellow mechanics!
Yesterday, I noticed that my car is leaking a little oil.
A drop of oil was located right at the junction between the engine and the transmission. This area houses the clutch, and the space below it is open.
Unfortunately, based on the "smell test" of the oil drip, I couldn't determine whether it was engine oil or transmission oil (although transmission oil smells very different).
The amount of oil leaking is very small. Therefore, I suspect the radial shaft seal on the transmission side. In my opinion, the seal on the engine side should leak significantly more oil, as the lubricant there has a lower viscosity and is pumped under pressure to the bearing.
Are there any experiences to share here? What are your thoughts?
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 19-10-2026, 20:31.
Albrecht
Post21-09-2003, 16:41    Subject: Engine-Gearbox Flange: Slight Oil Leak Quote
Hello Donalexo,
Based on my experience, I would lean towards the crankshaft oil seal.
"I also have a slightly oily feeling in that area, but it's not dripping."
Since nothing has changed in the last 30,000 km, and the clutch is also fine, I'll leave it as it is for now.
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
Translated on 19-10-2026, 20:33.
Rudi
Post21-09-2003, 19:32    Subject: Engine-Gearbox Flange: Slight Oil Leak Quote
Hi Alex,
My 1Z is behaving similarly to Albrecht's AFN.
With the difference being that mine has had 117,000 miles since I bought it.
Behavior has (currently approximately 197,000).
Based on its color (black), it is engine oil.
Since both the clutch and the oil consumption are within normal limits.
-> observe and otherwise ignore.
Best regards, Rudi.
Translated on 19-10-2026, 20:34.
donalexo
Post21-09-2003, 22:17    Subject: Engine-Gearbox Flange: Slight Oil Leak Quote
@RudiViewing profile: Rudi:
However, both the clutch and the oil consumption are within normal limits.
Bei mir sind Ölverbrauch und Kupplung ebenfalls o.k. That reassures me.
However, I don't consider the color of the oil to be a particularly reliable indicator, as the oil can accumulate various contaminants (coupling debris, dust, etc.) from the leak point to the bottom edge of the flange, and ultimately always appear black.
I will monitor it regularly and refrain from taking any action for now. Thank you for your responses.
Alex.
Translated on 19-10-2026, 20:36.
Gremlin
Post21-09-2003, 23:21    Subject: Engine-Gearbox Flange: Slight Oil Leak Quote
Based on experience, the crankshaft oil seal...
Just wait until the clutch starts to slip, because everything will have to be taken apart anyway icon_wink.gif.
If it were an old Kadett-D, you could quickly check it. But the ingenious principle is unfortunately out-of-order icon_sad.gif.
CU Gremlin.
Translated on 19-10-2026, 20:37.
To
Post24-09-2003, 10:59    Subject: Engine-Gearbox Flange: Slight Oil Leak Quote
My car has been losing oil for about 50,000 km, and the oil pan is also very dirty, so I haven't been able to pinpoint the exact location of the leak. However, only a few drops appear in the area between the engine and the transmission after the winter break. Unfortunately, the clutch is jerking, but it's not slipping yet.
Tobias.
Translated on 19-10-2026, 20:38.
No new posts Document LT 28, Transmission Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic transmission 01M.C: Identification and error codes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic transmission 01M.J - Identification codes and e... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z Engine: Flex Pipe & Cat Without Flange? Diesel Engine Technology
No new posts Golf 7 GTD manual transmission has a slight leak Transmission, Chassis, Body & Interior
No new posts 1Z vs. AFN Engine: Differences and Comparison Diesel Engine Technology
No new posts TDI Engine with Gas Transmission: Possible? Diesel Engine Technology
