Starter motor noise Golf III
D.
Post01-10-2003, 19:56    Subject: Starter motor noise Golf III Quote
Hello!
I've been experiencing a 'sawing' noise for some time now, but only when starting the machine when it's only partially warm.
Could it be that the starter ring gear isn't disengaging quickly enough?
I hadn't really paid much attention to it before, but I heard it yesterday on a TDI Golf III in the neighborhood.
I think I've read something about the magnetic switch before, which might need to be replaced.
Can someone provide more details (I know it's difficult to describe sounds accurately). I would still be very grateful for any advice, before the starter motor potentially gives up, even though it probably isn't the problem!
Best regards, D.
Translated on 23-09-2026, 17:09.
Golfmann
Post01-10-2003, 21:15    Subject: Starter motor noise Golf III Quote
Hello.
I had the same issue with my Golf 3 1Z engine. It was a kind of roaring sound after starting the engine when it was warm.
During my engine replacement, I simply relocated the starter motor without making any changes. Since then, it hasn't been working. Perhaps you should try removing the starter motor and lubricating or greasing the magnetic switch.
If it's constantly rotating, that certainly isn't an advantage in terms of durability.
I know several Golf 3 TDIs that have this problem. It seems to be a common issue.
Translated on 23-09-2026, 17:10.
DocSnydor
Post02-10-2003, 10:50    Subject: Starter motor noise Golf III Quote
The starter motor has also been replaced in my 1Z (fortunately under warranty), and it seems that this is not uncommon for the 1Z model. icon_confused.gif
Translated on 23-09-2026, 17:11.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4: Right Front Inner Fender Liner Transmission, Chassis, Body & Interior
No new posts TDI "Wiring Issues": Golf 3 Engine Control Problem? On-Board Diagnostics (OBD)
No new posts Golf Roof Antenna: Drill & Installation Dimensions Transmission, Chassis, Body & Interior
No new posts Accident Golf III Gti 20 years and "reference points"? Transmission, Chassis, Body & Interior
