Air Conditioning Compressor: Storage After Removal?
Mick
Post19-11-2003, 18:14    Subject: Air Conditioning Compressor: Storage After Removal? Quote
Hello everyone,
I removed a Kimak compressor from a 'slaughter festival' (likely referring to a dismantling or salvage event) and want to set it aside for future use.
Do I need to seal the connections if I'm going to leave it unused for a longer period?
Best, Mick.
Translated on 02-09-2026, 16:51.
Gremlin
Post20-11-2003, 12:34    Subject: Air Conditioning Compressor: Storage After Removal? Quote
Do bare metal parts oxidize if they are exposed to air for an extended period?
CU Gremlin.
Mick
Post20-11-2003, 18:07    Subject: Air Conditioning Compressor: Storage After Removal? Quote
Hello Gremlin,
I would answer that with a resounding 'Yes!'
But oxidation also involves water or moisture, and I didn't want to put the compressor in the garden.
Can I conclude that sealing alone is not sufficient and that I also need to charge the compressor with refrigerant?
Best, Mick.
Translated on 02-09-2026, 16:52.
Gremlin
Post20-11-2003, 19:37    Subject: Air Conditioning Compressor: Storage After Removal? Quote
In our climate, the relative humidity of the air is usually around 50%.
Furthermore, the oil used in the compressor has the unfortunate property of readily attracting water; it is hygroscopic, like brake fluid.
Ideally, a treatment with a suitable anti-corrosion oil would be best -> consult with a climate specialist.
Definitely make sure to seal the connections properly.
CU Gremlin.
Translated on 02-09-2026, 16:53.
Mick
Post20-11-2003, 20:01    Subject: Air Conditioning Compressor: Storage After Removal? Quote
Hello Gremlin,
Why don't we live in Italy? I saw a 200D/8 there that didn't even have underbody protection, and there wasn't a trace of rust on it!
I will look into the matter concerning the oil.
Thank you for the tip!
Best, Mick.
Translated on 02-09-2026, 16:54.
christians
Post20-11-2003, 20:33    Subject: Air Conditioning Compressor: Storage After Removal? Quote
At the university, we operated some compressor and turbine test benches with CFCs due to the reduced speed of sound. The result was an extraordinary tendency for corrosion in pipes and components. If the compressor material is not inherently corrosion-resistant, I would definitely do something about it using a suitable oil.
Gruß Christian
Translated on 02-09-2026, 16:55.
WarLord
Post21-11-2003, 19:42    Subject: Air Conditioning Compressor: Storage After Removal? Quote
@Mick
Blow out with compressed air, fill with nitrogen, and seal the connections (with rubber stoppers or other means).
Best regards, WarLord.
Mick
Post26-11-2003, 13:22    Subject: Air Conditioning Compressor: Storage After Removal? Quote
Hello everyone!
Thank you for your help! With the precautions being taken, he will probably be preserved.
Best, Mick.
Translated on 02-09-2026, 16:56.
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Air conditioning compressor making noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Removal: How to Open It Diesel Engine Technology
No new posts Data Migration After Powerbox Upgrade Diesel Engine Technology
No new posts AC Compressor Failure: After Just 6 Years? Transmission, Chassis, Body & Interior
No new posts 1Z measurable increased consumption after removal of the ... On-Board Diagnostics (OBD)
