Coupling issues (intermittent)
dieselkugel
Post22-12-2003, 14:45    Subject: Coupling issues (intermittent) Quote
Hey folks
Do you have any further questions about my clutch problems?
Basis:
Car: Beetle
Motor: ALH
Performance: 90 hp engine without power increase
Kilometer: 76000
Portable heater
To the Problem:
The car can be operated without problems for about 10 to 15 minutes, with no issues in the transmission. However, the clutch then fails for a short period. That is, when the turbo engages, the RPMs increase sharply to around 2600. The acceleration then fails, and the Beetle becomes even faster, but not as smoothly as usual. If you then gently press the pedal with your foot for 15 minutes, the situation improves to the point where you can once again drive normally and cheerfully.
I also visited the friendly mechanic today. The only thing they noticed was that the needle on the tachometer 'jitters' when the engine is at full throttle (below 2000 RPM). D.h. a short overswing, then a underswing. (So, apply gas and then hold it).
The stupid thing is that the error, of course, didn't occur at the car dealership. icon_neutral.gif
Furthermore, at the car dealership, the opinion is that once the clutch has failed, it will only slip and now they are blaming the electronics. new_shocked.gif
They also tried to read the error codes, but I could have told them there was nothing there.
The problem is also that my warranty expired on 15.12.2003, and when I asked about any possible goodwill considering that I will likely need a new clutch soon, the response was simply 'not much.' icon_cry.gif
How long should a clutch last? I've never had to replace a clutch in any of my previous cars.
No new posts Transporter 7D Clutch Problems: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L, Golf 4 etc. - Turn signal relay is malfunctio... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Light On: VW Transporter T4 Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kupplungsprobleme Diesel Engine Technology
No new posts Clutch problems Transmission, Chassis, Body & Interior
No new posts Skoda Superb 1.9 TDI - Clutch Problems:( Diesel Engine Technology
No new posts Kupplungsprobleme bei Golf Cabrio TDI Diesel Engine Technology
