Golf 3 TD Steering Rack: 2 Brands Available
kmrlange
Post14-01-2004, 8:59    Subject: Golf 3 TD Steering Rack: 2 Brands Available Quote
Hello there,
I have a Golf III TD (AAZ) where the power steering is loose.
Turning left is difficult (as long as everything is cold), but turning right always works well.
Now, there are probably two manufacturers.
ZF 1H1 422 061
XTR USA 1H1 422 055
To find out what's written on the built-in part, you would need a stethoscope.
Therefore, my question is: Does it matter which ones I install? As far as I know, there's only one body and a limited number of tie rods.
Best regards, KAi.
Translated on 20-10-2026, 23:05.
olli
Karma: +46 / -0   Thank you, like it!
Post14-01-2004, 22:39    Subject: Golf 3 TD Steering Rack: 2 Brands Available Quote
It's likely that both steering racks will fit in your Golf. The question is which specific parts, such as tie rods, mounting brackets, hoses, etc., are specific to each steering rack.
As far as I know, you can identify the manufacturer by looking at the profile of the sleeves between the steering rack and the tie rod. Otherwise, you could ask the parts specialist at your trusted dealership. I would only replace what is absolutely necessary, mainly because of the limited space in the Golf.
Olli.
A6 CANA/JME /
Ex-A6 AEL
Translated on 20-10-2026, 23:07.
kmrlange
Post15-01-2004, 10:43    Subject: Golf 3 TD Steering Rack: 2 Brands Available Quote
Okay, I'll look into that.
Be careful with your AEL! Mine was completely destroyed because the timing chain tensioner broke.
Best regards, Kai.
Translated on 20-10-2026, 23:08.
Jürgen
Post15-01-2004, 12:39    Subject: Golf 3 TD Steering Rack: 2 Brands Available Quote
I once had a manufacturer-related issue with the steering gear on a Passat 35i.
There were also those two manufacturers (according to my information, XTR should be TRW).
and I needed a cuff. Back then, I found the letters XTR or...
TRW is cast onto the housing. Additionally, it has ZF steering racks.
(normalerweise) ein richtiges, angenietetes Metalltypenschild. Try it.
Please provide the text you would like me to translate from German to English. I need the text to be able to provide a translation.
it doesn't matter which manufacturer produced the steering system. If the steering gear is...
It shouldn't matter when the tie rods are delivered!
In the spare parts trade, there are also companies that refurbish such parts.
I've had very good experiences so far with offering something in exchange.
Translated on 20-10-2026, 23:09.
PrivatBereich
Post15-01-2004, 12:48    Subject: Golf 3 TD Steering Rack: 2 Brands Available Quote
@Jürgen:
Don't forget that he was talking about a servo steering system.
I would not be sure with two manufacturers whether the hydraulic connections are identical on both. And if new keys need to be installed, it's not exactly a bargain icon_wink.gif.
@kmrlange: Could you perhaps identify the manufacturer using a small mirror? I would prefer to buy from the same manufacturer...
Private.
Translated on 20-10-2026, 23:11.
Jürgen
Post15-01-2004, 20:22    Subject: Golf 3 TD Steering Rack: 2 Brands Available Quote
Hello private sector,
I understand that, but German manufacturers usually provide it.
The threading of fittings may differ when sourced from US vendors.
to order something.
I can recall, for example, that GM in the US used the same automatic transmissions in...
'The company manufactures gearboxes in both inch and metric sizes.'
Please check the VAG catalog to see if there are different options available.
There are available connections.
'On a Passat 3B, I replaced the power steering pump two years ago.'
switched to a new one - it was from a different manufacturer - no problems at all.
And then there are also the butchers!
Translated on 20-10-2026, 23:12.
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Garage door broken? Get fast repair! Transmission, Chassis, Body & Interior
No new posts Fuel Temp Sensor Spoofing Possible in CR Engines? Diesel Engine Technology
No new posts Two K-Lines: Installation & Benefits Diesel Engine Technology
No new posts K-Lines: Two Ships Collide Diesel Engine Technology
