More power for standard TD
GH1
Post22-07-2004, 10:39    Subject: More power for standard TD Quote
Hello fellow diesel enthusiasts!
I apologize for intruding with a standard TD engine question. Perhaps someone can help me.
I have a standard turbocharged diesel engine with a displacement of 1900cc and only 90 horsepower. Is there anything I can modify to increase its power? I'm grateful for any ideas you might have!
Best regards.
GH1
Translated on 18-07-2026, 17:42.
delvos
Post22-07-2004, 10:56    Subject: More power for standard TD Quote
"We could definitely do something about it. However, it would be very helpful to know which car and engine we're talking about."
GH1
Post22-07-2004, 11:59    Subject: More power for standard TD Quote
It is a motor from Renault icon_sad.gif.
1900cc engine capacity.
90 horsepower.
mechanical fuel injection pump
I've already shortened the pressure sensor rod from the turbo by about 1 cm. Boost pressure was previously 0.4 bar --> now it's approximately 0.8 bar.
Oh, but still not enough power!
Best regards.
GH1
Translated on 18-07-2026, 17:43.
Avatar-Jan6K
Post22-07-2004, 17:06    Subject: More power for standard TD Quote
Perhaps you should first familiarize yourself with the basic principles of diesel tuning. Simply increasing the boost pressure without making other changes, especially to the fuel injection amount, will achieve absolutely nothing.
"For a 1.9-liter engine with 90 horsepower, I find 0.4 bar to be too low for the standard pressure – are you sure this thing is working correctly, or do you know the specified values?"
Jan.
1Z5 CFHF / AHB H4D
Translated on 18-07-2026, 17:45.
Sir Tortsch
Post22-07-2004, 21:10    Subject: More power for standard TD Quote
'Box, chip... why don't you read the technical article about it?'
wolfi_b
Post23-07-2004, 6:23    Subject: More power for standard TD Quote
Sir Tortsch wrote:
Box, chip
Where do you want to install it? Into the radio? icon_wink.gif icon_biggrin.gif
This is a TD (transaction document) --> there's no message associated with it.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 18-07-2026, 17:46.
BigB
Post23-07-2004, 10:31    Subject: More power for standard TD Quote
Since you seem to be quite bold with your tuning, why don't you simply shorten the throttle cable? Or more precisely, where the throttle cable ends, you should find several adjustment screws for maximum throttle, idle speed, etc. You can play around with those as well.
I think it's quite risky to double the pressure, but it's your car.
Best regards, BigB.
Translated on 18-07-2026, 17:47.
wolfi_b
Post27-07-2004, 8:45    Subject: More power for standard TD Quote
I happened to see something about TD earlier.
http://www.kw-systems.de/zubehoernews.htm
The question is whether you have a Bosch ESP system.
1993 Audi 80 B4 1Z
GH1
Post29-07-2004, 11:03    Subject: More power for standard TD Quote
Hello everyone!
Thanks for your tips so far!
I'm currently working with the kw-system. Let's see what comes out of it.
I just spoke with a Ford mechanic. He said that on a Ford Escort TD with 90 horsepower, you only need to slightly increase the fuel injection pressure of the pump and increase the turbo boost – then it should really take off.
Does this work for me too?
Are there any best practices or guidelines available for that?
And will the fuel injectors withstand it?
Or, to put it another way, by how much does this reduce the lifespan of my engine?
Thank you for your contributions!
Best regards.
GH1
Translated on 18-07-2026, 17:49.
Post29-07-2004, 11:28    Subject: More power for standard TD Quote
GH1 wrote:
I just talked to a Ford mechanic. He said that with the Ford Escort TD with 90 horsepower, you only need to slightly increase the injection pressure of the pump and increase the turbo boost – then it should really take off.
Does that also work for mine?
Assuming the pump design is similar to that used by Ford, I would say no – because, as far as I know, mechanical pumps (like those from Bosch VP) do not have a screw for adjusting injection pressure.
If I'm right, the Ford employee probably just gave you some common sense advice suitable for someone with a blood alcohol content exceeding 0.03%. new_all_coholic.gif
Translated on 18-07-2026, 17:51.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post29-07-2004, 14:20    Subject: More power for standard TD Quote
Hi.
I installed the same engine in my second car, a Volvo 460 TD from 1994.
To my knowledge, it can only be tuned using the methods already described (boost pressure + gas throttle control).
It would also be interesting to trace the boost pressure hose that leads into the pump.
Perhaps there's still something we can adjust there.
Translated on 18-07-2026, 17:52.
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel Performance: Boost Your Engine's Power! Diesel Engine Technology
No new posts Biodiesel in Diesel: Is it Safe? Diesel Engine Technology
No new posts FIS exchange for a standard speedometer? Diesel Engine Technology
No new posts Soot Buildup: More in Summer? Diesel Engine Technology
