7.5x16 Wheels: ET35 with 205 Tires
Golfdriver
Post23-04-2002, 21:15    Subject: 7.5x16 Wheels: ET35 with 205 Tires Quote
Hello everyone,
I'd like to buy 7.5x16 inch rims for my Golf Variant, possibly with an offset of ET 35. My question is whether I can fit these rims with 205-size tires without any problems, and without needing to roll or pull the fenders. I'm not sure if it makes a difference, but the car also has a lowered suspension by 40mm.
Okay, I'd really like to get 16-inch rims. Give me some tips on how to do that! Thanks in advance.
Your golf driver.
Translated on 25-07-2026, 5:45.
Stukov
Post24-04-2002, 7:18    Subject: 7.5x16 Wheels: ET35 with 205 Tires Quote
I have tires with a size of 195/50 mounted on rims that are 7 inches wide with an offset of 36, and the inspector said that problems only start to occur with offsets of 28 or higher.
With ET 28, the outer edge of my tire would be 61mm away from the wheel hub. Based on your information, it would be 60mm. So, it's very tight. I would almost say that you can't avoid needing to roll the fender (at the rear) if you want to have enough clearance and avoid issues.
'I used to have 15mm wheel spacers on the front, which gave me an effective ET of 21. With that setup, it started rubbing against large speed bumps (in a 30 km/h zone). However, you're likely to experience fewer issues with your tire combination in the rear.'
Translated on 25-07-2026, 5:46.
No new posts 7J 16 Wheels with 205 Tires: Will They Fit? Transmission, Chassis, Body & Interior
No new posts AGR Injectors: Review & Experience with Size 205 Diesel Engine Technology
No new posts 205 vs 216 Injectors: Which is Best? Diesel Engine Technology
No new posts Golf IV ALH: 0.205 Injectors from ASV - Compatibility? Diesel Engine Technology
