Dieselpilot Guest
19-09-2003, 20:23 Subject: Whistling Noise 1.9 TD (AAZ) Engine |
hi,
I drive a Golf III 1.9L TD with the AAZ engine.
The following problem has occurred: The engine has been making a whistling or humming noise at low RPMs for some time now. It's barely audible inside the car, but if you stand next to the vehicle, you can hear it quite clearly.
Meine Frage: was könnte da die Ursache sein? Damage from improper storage?
This is already my second engine; in the first one, a connecting rod bearing shattered and shot through the engine block.
Of course, I've also done quite a bit of performance tuning (increased fuel injection, a different nozzle for turbocharger pressure enrichment, more turbocharger pressure, intercooler, etc.).
Translated on 05-10-2026, 3:18.
mersente Guest
10-02-2004, 21:11 Subject: Whistling Noise 1.9 TD (AAZ) Engine |
A whistling sound likely originates from a leak in the turbocharger's pressure system or from the turbocharger itself.
Translated on 05-10-2026, 3:19.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
12-02-2004, 9:49 Subject: Whistling Noise 1.9 TD (AAZ) Engine |
Hi Dieselpilot,
"Try using the search function."
If there are no leaks and the loader isn't consuming any oil, I would just ignore it.
I've already tried several chargers, but I couldn't find any defects on the pipes.
If the charger is broken, it might make a whistling sound, but conversely, just because it's making a whistling sound doesn't necessarily mean it's broken.
Translated on 05-10-2026, 3:20.
Profile PM WWW Garage |
palmstrollo Guest
12-02-2004, 23:53 Subject: Whistling Noise 1.9 TD (AAZ) Engine |
Perhaps also a Spanish-style roll from Lima?
Hermann.
mersente Guest
13-02-2004, 20:43 Subject: Whistling Noise 1.9 TD (AAZ) Engine |
Okay, then spray some Caramba or something similar on it, and that should make the noise disappear, at least for a while.
Translated on 05-10-2026, 3:21.
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
14-02-2004, 0:19 Subject: Whistling Noise 1.9 TD (AAZ) Engine |
Hold the exhaust pipe. If you hear a hissing sound, the exhaust system has a leak, which makes the turbocharger whistle very audible!
____________
Kein Auto mehr!
