Gearbox Conversion: Change Gear Ratio
donalexo
Post12-02-2004, 13:21    Subject: Gearbox Conversion: Change Gear Ratio Quote
Hello everyone!
Since I've now mentally ruled out installing a 6-speed transmission due to the immense amount of work involved (dual-mass flywheel, clutch, starter, drive shafts, etc.), I would like to draw on your experiences in the field of transmission conversions.
"More and more often, one hears and reads about transmission modifications where the 5th gear is extended, meaning a new set of gears is installed."
That would be one approach, but I think it would be more sensible to moderately extend the axle ratio to avoid making the jump between 4th and 5th gear too large.
Who has experiences they can share?
What is the cost and effort involved in making such modifications (parts costs, labor, etc.)?
Is it possible to perform these repairs without a complete overhaul of the gearbox?
Thank you for the responses.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 12-10-2026, 3:46.
Tagessuppe
Karma: +36 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post12-02-2004, 13:57    Subject: Gearbox Conversion: Change Gear Ratio Quote
Hello Alexander!
Is there any news about the turbocharger boost pressure?
Regarding your question, user Kenny has already performed a similar modification to my knowledge base.
I was asked how difficult the renovation would be, and I received the following answer:
Removed the gearbox, put in a new gear, closed the gearbox. I don't remember if Kenny posted this.
but one of the people who allegedly carried out the renovation.
I was also planning to rebuild the 5th gear. But the mechanic isn't very cooperative.
In that regard, and I don't necessarily want to put two gears on my nightstand if you know what I mean *g*.
Okay... if it works out for you, I'll get you a bottle of red wine.
Almost as a bonus for having to follow only your professional instructions from now on icon_smile.gif.
Best regards and good luck.
Translated on 12-10-2026, 3:48.
Uli S.
Post12-02-2004, 14:19    Subject: Gearbox Conversion: Change Gear Ratio Quote
donalexo wrote:
Is it possibly
to perform these tasks without a complete overhaul of the gearbox?
You can shift into the 5th gear with the gearbox installed; it's located at the very end and is accessible with the cover removed. To access the axle drive, you must completely disassemble the gearbox.
Best regards, Uli.
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
Translated on 12-10-2026, 3:50.
donalexo
Post12-02-2004, 22:39    Subject: Gearbox Conversion: Change Gear Ratio Quote
Hello Uli!
It sounds like you've already rebuilt one or more transmissions before.
Can you provide some more details about the procedure (work steps), any specialized tools required, the necessary components, part costs, etc.?
Thank you.
Alex.
Translated on 12-10-2026, 3:51.
No new posts Audi A6 C5 Allroad transmission conversion: from Multitro... Gasoline Engine Technology
No new posts AHF vs. ASV: Game, Match, Results Diesel Engine Technology
No new posts Alles eine Frage der Übersetzung? Diesel Engine Technology
No new posts Hydraulic Translation Bosch Piezo Injector Diesel Engine Technology
