DIY Car Tuning: Chip Tuning Guide
JackyDee
Post31-03-2004, 22:10    Subject: DIY Car Tuning: Chip Tuning Guide Quote
Hello everyone!
Can anyone give me a tip on where I can find a relatively detailed description of how much effort it takes to install a custom-burned chip into a VW Beetle 1.9 TDI engine control unit (ECU)?
I just bought an EEPROM and would like to do the tuning myself.
Soldering and similar tasks are no problem!
Who has gained experience?
Translated on 17-10-2026, 14:28.
palmstrollo
Post01-04-2004, 10:21    Subject: DIY Car Tuning: Chip Tuning Guide Quote
I hope you didn't 'create' the characteristic curve yourself, did you?
You should only do that if you're absolutely sure of what you're doing. Otherwise, you might not enjoy your Beetle for very long.
I haven't opened up a Beetle's engine control unit (ECU) yet.
Hermann.
Translated on 17-10-2026, 14:29.
Rudi
Post01-04-2004, 11:48    Subject: DIY Car Tuning: Chip Tuning Guide Quote
Hi Jacky,
three questions:
- What is the VAG number of your control unit?
- Which programmer (with which adapters) did you get?
- Where does the chip come from?
Best regards, Rudi.
Translated on 17-10-2026, 14:30.
Uwe
Post01-04-2004, 16:41    Subject: DIY Car Tuning: Chip Tuning Guide Quote
The chip is simply soldered in. For an experienced solderer with the appropriate equipment, this is not a problem. The control unit can also be easily opened with a ratchet. But where did you get the software?
Uwe
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
JackyDee
Post02-04-2004, 3:46    Subject: Things to do: 1000+ ideas! Quote
That's a lot of things all at once!
I think I'll just leave it alone.
I don't have any specific software for this, I was actually hoping to get some help here. I can tell you the exact type of EEPROM once I have it, I bought it at an auction on eBay!
Well, maybe someone will give me a tip!
Best regards, Sven.
Translated on 17-10-2026, 14:31.
Basti
Post04-04-2004, 10:42    Subject: DIY Car Tuning: Chip Tuning Guide Quote
My advice is to have this done by people who understand the process. You can certainly try soldering it yourself, but just so you know, the board is 4-layer, and you'll likely never get it out in one piece without experience. It's better to invest a few extra euros, because a new unit costs quite a bit more.
Cu Basti
Translated on 17-10-2026, 14:32.
Back to top Profile PM Email
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Auto Volume Changes Automatically Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts Machining a cylinder head for a VW 1.6TD (Golf) - DIY Diesel Engine Technology
No new posts DIY Chip Tuning Removal: How To Undo It On-Board Diagnostics (OBD)
No new posts [Poll] Vehicle weight increase, who has done this before? Transmission, Chassis, Body & Interior
No new posts AEL Nozzles in AAT 1. Gen: I Did It! Diesel Engine Technology
