T4 Rear Axle Upgrade: Save on Taxes
solLte man iM InterneT nur klEIN SCHReiben?
ja
25%
 25%  [ 1 ]
nein
75%
 75%  [ 3 ]
Total votes : 4
sympatie
2020 Skoda Karoq
Post25-07-2003, 8:21    Subject: T4 Rear Axle Upgrade: Save on Taxes Quote
hello community,
I've heard that you can increase the payload of a motorhome by using reinforced rear axle springs. Do you also need to change the shock absorbers for this, and where can I find information about that? Unfortunately, VAG (presumably a company or organization) is just talking in circles.
It's a 1994 T4 with a 1.9L engine, 50kW power, and a gross vehicle weight of 2515 kg.
Best regards, with sympathy.
Translated on 05-09-2026, 4:27.
mersente
Post11-02-2004, 21:09    Subject: T4 Rear Axle Upgrade: Save on Taxes Quote
The shock absorbers will remain. You need to contact VW and provide them with a copy of your vehicle registration.
They will then send you a list of quills/spindles that you need to temper (with color coding).
So, you obtain these parts and, after installation, have a qualified technician confirm the installation. Then, you need to take the vehicle to the TÜV (German technical inspection authority) for registration.
It might be enough to simply clean the feathers/rods and mark them with the appropriate color and a brush, but I haven't said that because that would be fraud.
Translated on 05-09-2026, 4:29.
bitsch1m
Post04-03-2004, 18:07    Subject: T4 Rear Axle Upgrade: Save on Taxes Quote
'With my T4, the total weight was simply increased by 10 kg.'
Then I weighed 2810 kg.
My friend had it done on a 2.4L diesel engine.
He probably just needed new feathers, and I suspect the same might be true for you.
He did it at: http://www.pkw-auflastung.de/vw_bus.htm
Hi Michael,
Translated on 05-09-2026, 4:30.
huskydoctor2002
Post04-03-2004, 22:13    Subject: T4 Rear Axle Upgrade: Save on Taxes Quote
Take a look at the two major VW T4 forums.
www.t4forum.de
www.t4-forum.de
or under this private page, which explains the entire situation very well.
http://t4.x-fish.org/
Hi huskydoctor.
Translated on 05-09-2026, 4:31.
No new posts Cracking noise from rear axle, Audi A6 4F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J, Clicking, Squeaking at the rear axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K bis 03/98, Geräusche von der Hinterachse Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cat Tax Savings: Retrofit Your Car Now! Diesel Engine Technology
No new posts TDI Taxes: Calculation and Reclassification Diesel Engine Technology
No new posts Hinterachse entrosten Transmission, Chassis, Body & Interior
No new posts Rear Axle Noise: Causes and Solutions Transmission, Chassis, Body & Interior
