VP44 Injector Testing: Leak Detection & Repair
Polarlarry
Post05-03-2004, 10:41    Subject: VP44 Injector Testing: Leak Detection & Repair Quote
I recently wanted to have my fuel injectors checked at a Bosch service center.
AKE 2.5 TDI... VP44..
The 'expert' told me directly: It's not possible. We can no longer test two-stage injectors; the only thing you can do is replace them.
Could you please give me a second opinion on this?
Thank you.
Translated on 31-08-2026, 22:30.
Gremlin
Post05-03-2004, 12:22    Subject: VP44 Injector Testing: Leak Detection & Repair Quote
Tell your Klingon to order and hang up the workshop poster with the number 4 400 001 051.
Of course, you can test a two-stage demand valve regulator. While the standard equipment only allows you to determine the opening pressure of the first stage, this already provides information about the rest of the system's function. And, of course, you can assess the spray pattern regardless of the combination used!
CU Gremlin.
Translated on 31-08-2026, 22:31.
josie
Post07-03-2004, 2:55    Subject: VP44 Injector Testing: Leak Detection & Repair Quote
It works perfectly with a Hartridge device. Both opening pressures and spray pattern can be assessed. The Bosch technician is not up-to-date on the latest information.
Goodbye, Josie.
Translated on 31-08-2026, 22:32.
No new posts VE Injection Pump Data: 6-Cylinder Engine Performance (VP44) Technical Data
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts How to administer LLK (medication)? Diesel Engine Technology
No new posts Nozzle Cleaning: Get Your Nozzles Cleaned Now! Diesel Engine Technology
No new posts VP44 Mystery: Unveiling the Secrets Diesel Engine Technology
This topic is locked, you cannot edit or reply. VP44 Pump: Suction Pressure Explained Diesel Engine Technology
