4Motion: How to Modify All-Wheel Drive
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post20-11-2010, 18:44    Subject: 4Motion: How to Modify All-Wheel Drive Quote
I have a simple question.
The 4Motion system has a default torque distribution of 90:10 (front:rear), and then adjusts accordingly when there is no longer sufficient grip at the front.
Is it possible to adjust the electronics via VCDS in such a way that the transmission ratio, for example, can be set to 50-50?
"This question has been bothering me for a while, but unfortunately, I haven't found an answer anywhere yet. Maybe someone here can help me?"
Greetings.
Translated on 30-10-2026, 22:26.
Post20-11-2010, 18:54    Subject: 4Motion: How to Modify All-Wheel Drive Quote
Using VCDS, nothing works. You need an additional module, which is available from various manufacturers. The price starts at around ~900€, with no upper limit. icon_confused.gif
Translated on 30-10-2026, 22:27.
klahaui
Avatar-klahaui
Post20-11-2010, 19:36    Subject: 4Motion: How to Modify All-Wheel Drive Quote
Do you happen to know what that module is called? And which manufacturer makes it?
Just out of curiosity.
Thank you.
Post20-11-2010, 21:49    Subject: 4Motion: How to Modify All-Wheel Drive Quote
For example, Haldex itself offers one.
or eBay number: 270662515661 (this is a reputable seller!).
*note* I will most likely purchase the item shown in the book as well. icon_wink.gif
Translated on 30-10-2026, 22:28.
klahaui
Avatar-klahaui
Post21-11-2010, 11:35    Subject: 4Motion: How to Modify All-Wheel Drive Quote
"It sounds interesting what they're writing, but one wonders if it's worth the money for the average consumer, or for people who, like me, live in remote mountain areas."
I'd say, for €950, you can already get nice Audi 90 or 100 Quattro models with a 5-cylinder or V6 engine icon_smile.gif.
I can even manually lock the rear axle up to 30 km/h.
I'd be interested to know how it drives and whether it actually works properly.
You can let me know when you buy one and tell me how it is.
Greetings.
Translated on 30-10-2026, 22:29.
Post21-11-2010, 11:46    Subject: 4Motion: How to Modify All-Wheel Drive Quote
klahaui wrote:
It sounds interesting what they are writing, but one wonders if it's worth the money for the average consumer.
No. This kind of thing is very useful and intended for racetracks, drifting, slalom events, and quarter-mile runs. Or, if you like to drive sideways, but with 150 horsepower, you can't do much. That's why I'm only getting it when the appropriate power is available. icon_wink.gif
Translated on 30-10-2026, 22:30.
klahaui
Avatar-klahaui
Post21-11-2010, 12:57    Subject: 4Motion: How to Modify All-Wheel Drive Quote
Off-Topic:
What else are you planning to do with your ARL?^^
Post21-11-2010, 19:41    Subject: 4Motion: How to Modify All-Wheel Drive Quote
klahaui wrote:
OT:
What are your plans for your ARL?^^
Translated on 30-10-2026, 22:31.
klahaui
Avatar-klahaui
Post22-11-2010, 20:09    Subject: 4Motion: How to Modify All-Wheel Drive Quote
I tried something new today.
Specifically, during the all-wheel drive actuator diagnosis, I encountered an error that caused the all-wheel drive test to be interrupted and terminated.
If it were closed, would that mean I have a 50/50 chance? icon_biggrin.gif
If this is already possible, then theoretically, it should be possible to make changes using VCDS.
In addition to that, a charging pump failed, and I can't imagine what could be underneath the charging pump. Or, to put it another way, I'm not entirely sure about that.
Greetings.
EDIT: I need to rephrase this after doing some research.
Okay, here's the translation:
"I'd like to go for a fun, short snow ride on a field with my colleague on our sleds. Would I be able to simply activate a "Short 2...3km" mode via the control unit diagnostics to engage the Haldex system and have permanent all-wheel drive?"
Translated on 30-10-2026, 22:32.
Post22-11-2010, 20:43    Subject: 4Motion: How to Modify All-Wheel Drive Quote
klahaui wrote:
All-wheel drive actuator diagnosis triggered and completed separately.
Yes, of course, that's an actuator diagnosis. With continuous driving, it will probably stop after a few kilometers.
As I said: It's not possible to change it via VCDS. And having to "activate" it every time using the actuator diagnostic function, well... icon_confused.gif
Translated on 30-10-2026, 22:34.
klahaui
Avatar-klahaui
Post22-11-2010, 20:47    Subject: 4Motion: How to Modify All-Wheel Drive Quote
Yes, the "actuator dia." thing isn't a permanent state, but it's certainly good for a bit of fun.
In the MWB 2 (or 1?), I also have the display showing the Haldex voltage, before the actuator display. It showed 13.60V, but then dropped to only 0.7V. This would mean that if the voltage is lower, the Haldex is closed, and the permanent all-wheel drive kicks in:D
Translated on 30-10-2026, 22:35.
Post22-11-2010, 20:49    Subject: 4Motion: How to Modify All-Wheel Drive Quote
klahaui wrote:
is not a permanent condition, but it's certainly good for a short-term fun.
That might work.
P.S. Just for fun, you could take the BMW; icon_wink.gif it's probably better at it anyway.
klahaui
Avatar-klahaui
Post22-11-2010, 20:51    Subject: 4Motion: How to Modify All-Wheel Drive Quote
He has the numbers 4-10 associated with that phone number.
Somehow, this topic won't let me go icon_smile.gif.
Translated on 30-10-2026, 22:36.
Post22-11-2010, 20:55    Subject: 4Motion: How to Modify All-Wheel Drive Quote
klahaui wrote:
Oh, they must have lowered the prices. It's been a while since I last checked. icon_wink.gif
klahaui
Avatar-klahaui
Post22-11-2010, 20:56    Subject: 4Motion: How to Modify All-Wheel Drive Quote
Well, I'm waiting for the feedback when you have it. I'm curious, but my ARL will remain a gasoline series, with a V8 engine instead of diesel power icon_twisted.gif.
Translated on 30-10-2026, 22:37.
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J 4Motion, Oil Leak on Haldex Coupling Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Vibrations and Rumble Noises with 4Motion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4Motion Turbo: Diagnose & Probleme On-Board Diagnostics (OBD)
No new posts Disable 4Motion control module in the CAN gateway On-Board Diagnostics (OBD)
No new posts Fuel sensor Passat 3B Syncro/4Motion Transmission, Chassis, Body & Interior
No new posts VW Passat 4Motion: AVF Engine Idler Pulley Diesel Engine Technology
