Passat Tiptronic: Faulty Reverse Gear
Olaf Glitzner
Post15-03-2004, 18:29    Subject: Passat Tiptronic: Faulty Reverse Gear Quote
'Hello, I own a Passat TDI PD 1.9 l, first registered in July 2000, with 160,000 km on the clock. After I recently replaced the engine due to a tire blowout, the car ran perfectly for 8 weeks. However, this weekend, the Passat stopped reversing. While it's possible to engage reverse gear ('R'), unfortunately, nothing happens. The gear selector is displayed correctly on the instrument cluster, and the reverse light works, so I suspect the problem isn't with the gear linkage. When I checked the error memory, there were no error codes. The local VAG dealer told me that a new transmission needs to be installed (approximately 3,500 EUR). This is a significant amount of money that I'm not necessarily willing to spend. Perhaps someone in this forum can help me with troubleshooting or has some tips on this issue.'
Best regards, Olaf.
Translated on 25-10-2026, 6:40.
No new posts Passat 2000: Sun Visor Light Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0044 AMF, Difficult to shift reverse gear Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reverse Gear Not Working: Doku Sharan Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat High Fuel Consumption: AJM & Tiptronic Issues Diesel Engine Technology
No new posts Biodiesel Passat V6 TDI: ESP Failure Fix Diesel Engine Technology
No new posts Headlight Range Control Passat 3B Faulty Transmission, Chassis, Body & Interior
No new posts Mass Air Flow Sensor Problem: VW Passat Variant 2.5 TDI Diesel Engine Technology
