Audi A6 2.5 TDI: OT Markings Explained
m3nx
Post15-04-2004, 12:56    Subject: Audi A6 2.5 TDI: OT Markings Explained Quote
Hello!
Apparently, the heat and sun today in Frankfurt have affected me somewhat, because I can't find any timing marks (OT markings) on either the camshaft sprockets or the crankshaft sprocket of this Audi A6 2.5 TDI.
Does anyone happen to have a (helpful) tip?
'Thank you.'
Translated on 22-10-2026, 6:54.
m3nx
Post15-04-2004, 12:58    Subject: Audi A6 2.5 TDI: OT Markings Explained Quote
MKB is actually AKN.
Translated on 22-10-2026, 6:55.
volker32
Avatar-volker32
Post15-04-2004, 13:31    Subject: Audi A6 2.5 TDI: OT Markings Explained Quote
Hello, you can't find it because it doesn't exist. The crankshaft is brought to the top dead center (TDC) position by a dowel, and the camshafts are aligned using two thin rulers.
Volker
Marco
Post15-04-2004, 13:47    Subject: Audi A6 2.5 TDI: OT Markings Explained Quote
Okay, open the oil filler cap and take a look at the camshaft. It's not designed for adjustment, but it can give you a rough idea. To do it properly, you'll need the two rulers and the crankshaft dowel.
Translated on 22-10-2026, 6:56.
m3nx
Post15-04-2004, 18:22    Subject: Audi A6 2.5 TDI: OT Markings Explained Quote
Hello!
Okay, it seems to be working now. It appears the issue was only with the crankshaft and the fuel injection pump being misaligned. I suspect the left camshaft might also be slightly out of alignment, but I need to get all the necessary tools tomorrow first.
Ugh, it's annoying that you can't check the right camshaft through the oil filler cap or something similar; the left one is clearly visible.
Translated on 22-10-2026, 6:57.
volker32
Avatar-volker32
Post15-04-2004, 19:22    Subject: Audi A6 2.5 TDI: OT Markings Explained Quote
Hello, I really hope you didn't use the "OT" marking on the camshaft as a reference point. That would be very, very inaccurate.
Volker
m3nx
Post16-04-2004, 2:00    Subject: Audi A6 2.5 TDI: OT Markings Explained Quote
No, I just wanted to check if the waves are roughly aligned with the timing marks, because a 'so-called expert' before me had messed up almost everything. But it seems to be okay, although I'm not 100% sure about the right side. Can we use the position of the wheels relative to the timing belt as a reference point?
Greetings.
Translated on 22-10-2026, 6:58.
Marco
Post16-04-2004, 6:57    Subject: Audi A6 2.5 TDI: OT Markings Explained Quote
Hello m3nx,
Unfortunately, the NW (crankshaft) pulleys cannot be used as a reference point because there are no manufacturing markings on them. Many workshops make their own markings on the pulleys before changing the timing belt, which often works well, but not always, and in your case, it's not applicable because, as you mentioned, everything is misaligned. So, definitely get the tools mentioned above. This will save you a lot of rework and give you the certainty that the crankshaft and camshafts are properly aligned.
Translated on 22-10-2026, 6:59.
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differences in MSG for Audi 2.5 TDI AAT engines On-Board Diagnostics (OBD)
No new posts AGR EGT Sensor for Audi A6 2.5 TDI Diesel Engine Technology
No new posts Audi A6 C4: Crankshaft Pulley Bolts Diesel Engine Technology
No new posts Tiptronic Problems Audi A4 B5 2.5 TDI Transmission, Chassis, Body & Interior
