What is being programmed at the WFS?
Gunther Bastian
Post10-04-2004, 19:27    Subject: What is being programmed at the WFS? Quote
In the WFS (Whole Vehicle System) process, are the keys programmed to the control unit, or is the control unit programmed to the keys? Can you replace a control unit if it has already been programmed, or does it always have to be reprogrammed? icon_question.gif
Gunther.
Translated on 05-07-2026, 17:00.
KombiBlue
Post11-04-2004, 10:02    Subject: What is being programmed at the WFS? Quote
Hello, so the control unit "learns" which keys it is allowed to accept.
And if the control unit is replaced, the new one needs to "learn" again which keys are the correct ones!
Gruss Ralf
Passat Var. 2.0 TDI 3/2009, 125kW, CBBB
Translated on 05-07-2026, 17:01.
Gunther Bastian
Post11-04-2004, 10:22    Subject: What is being programmed at the WFS? Quote
That means I can create a control unit with chips, keep the original one, and swap them, after the second control unit has been properly programmed. icon_question.gif
Translated on 05-07-2026, 17:02.
Uwe@Ross-Tech
Post13-04-2004, 17:54    Subject: What is being programmed at the WFS? Quote
The keys are learned by the immobilizer control unit. This unit is either a separate component or integrated into the instrument cluster. Therefore, the process of learning keys has nothing to do with the engine control unit. The engine control unit needs to be adapted to the immobilizer control unit.
-Uwe-
Wolfgang, syncro16
Post14-04-2004, 16:51    Subject: What is being programmed at the WFS? Quote
'However, is it possible to program two IMMO (immobilizer) control units to the same key? In other words, could I install an additional IMMO control unit and an engine control unit, which are pre-configured and ready to use, in the trunk as a backup in case of emergency?'
Hello.
Wolfgang.
Translated on 05-07-2026, 17:03.
Uwe@Ross-Tech
Post14-04-2004, 17:16    Subject: What is being programmed at the WFS? Quote
However, is it possible to program two IMMO control units to the same key? That is, can I install an additional IMMO control unit and an engine control unit, which are pre-configured and ready to use, in the trunk as a backup in case of a problem?
I don't know. It might work if it's still using 'fixed code' keys, but probably not with 'rolling code' keys. With 'rolling code' keys, the code changes with each use, and the immobilizer control unit also stores the next code. You just have to try it.
-Uwe-
Translated on 05-07-2026, 17:04.
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts ECU needs to be reprogrammed??? On-Board Diagnostics (OBD)
No new posts AGR Valve: Location & Removal Guide Diesel Engine Technology
No new posts AYM V6 Overheating: 2.5L Engine Problems Diesel Engine Technology
No new posts Hot Brakes: Causes and Solutions Transmission, Chassis, Body & Interior
