It's hard to get started
Thomas100
Post09-06-2004, 9:23    Subject: It's hard to get started Quote
Hello forum!!!
'Since last week, I've been having a problem with the gears (1-5) in my TDI 110PS car. They are very difficult and jerky to engage. When I push the gear knob forward or backward, I feel resistance. It takes a lot of force to get the gear to engage. There are no loud noises or clunking sounds.' The entire process is not speed-dependent, and it doesn't always happen.
A badger chewed through a pair of coolant hoses, and I replaced them. One of the hoses was the one that runs from the engine into the passenger compartment. I disconnected it directly at the engine, and some coolant spilled onto the transmission. Later, I realized that the cover for the clutch was missing, so I can't rule out the possibility that some coolant may have gotten into it. But the clutch isn't slipping.
I've just lubricated all the mechanical components on the gearbox. It has achieved a little bit, but it's still far from being good.
Does anyone have any idea what else it could be?
Thank you in advance.
Thomas.
No new posts Golf5 Getriebe schaltet während d. Fahrt nicht in alle G... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine and instruments fail - Relay 109? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0044 AMF, Difficult to shift reverse gear Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gänge verlängern? Diesel Engine Technology
No new posts Lupo 3L legt keine Gänge mehr ein / Fehlerdiagnose Transmission, Chassis, Body & Interior
No new posts Keine Richtige Power mehr in hohen Gänge On-Board Diagnostics (OBD)
No new posts Accessing Car ECUs: How-To Guide On-Board Diagnostics (OBD)
