The display in the instrument cluster is not showing anything
sirecki
Post04-07-2004, 1:03    Subject: The display in the instrument cluster is not showing anything Quote
I acquired a used instrument cluster (new Galaxy, year 2000). My old one is 7M5 920 820 K, and the new one is 7M7 920 840 L. All the displays are working, except for the central, large display (MFA/FIS). The lower (larger) part of that display is slightly illuminated as soon as I plug in the left connector into the instrument cluster, and it remains lit even with the ignition off. However, nothing is actually displayed. I've transferred the codes from my old cluster and also performed an output test, but there's no display in that section. Here's the translation:
'However, the following error code is stored in the CAN gateway's memory:'
Control Module Part Number: 6N0 909 901
Component and/or Version: Gateway K<->CAN 0001
Software Coding: 00006
Workshop Code: WSC 05406
1 Fault Found:
00778 - Steering Angle Sensor (G85)
49-00 - No Communications.
Is that related?
Does anyone have any other suggestions? (Is there anything else I need to adjust or repair, or are there any individual components that can be replaced?)
Sure, I'd be happy to help! Please provide the text you would like me to translate from German to English.
Best regards, Sirecki.
Translated on 05-07-2026, 8:57.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post04-07-2004, 8:46    Subject: Re: Display in the instrument cluster shows nothing Quote
sirecki wrote:
I have acquired a used
distribution board insert. Best regards, Sirecki.
That might already be the source of the error. Do you know for 100% that this thing was working on the previous model?
B.Eng (FH) u. KFZ Meister
Translated on 05-07-2026, 8:59.
sirecki
Post04-07-2004, 13:35    Subject: The display in the instrument cluster is not showing anything Quote
I'm not sure if the speedometer was working before, but I've contacted the seller again and am waiting for a response.
I don't have ESP, could the error message be related to that, is that normal? It sounds like it's related to steering angle.
Theresias
Post04-07-2004, 20:22    Subject: The display in the instrument cluster is not showing anything Quote
It is highly likely that the AI is defective, because at the very least, some output should appear on the display during the output test.
Translated on 05-07-2026, 9:00.
sirecki
Post11-07-2004, 21:42    Subject: The display in the instrument cluster is not showing anything Quote
It seems there's a defect. I will exchange the AI.
No new posts TDI Exhaust Tuning: Just for Show? Technical Articles
No new posts Audi A2: Dashboard shows only range Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo Combo Instrument Cluster, 10.99-09.2001 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The climate control display is no longer showing anything. On-Board Diagnostics (OBD)
No new posts Renault Master III 150dCi displaying a strange message on... Diesel Engine Technology
No new posts Bordspannungsanzeige im Kombiinstrument zeigt zu viel an. Diesel Engine Technology
No new posts Transmission re-encoded and nothing noticed? On-Board Diagnostics (OBD)
