Broken LMM Connector Lock: Fix & Repair
Post12-07-2004, 11:52    Subject: Broken LMM Connector Lock: Fix & Repair Quote
Unfortunately, the workshop probably damaged the locking mechanism of the MAF sensor connector during the last service.
It's been 4 months already, and the store will probably never see me again anyway, so I'm just going to fix it myself.
It is a G IV ASZ model from July 2002.
Has anyone ever repaired this before?
Im Teilekatalog gibt es unter Kabelbäume - Einzelteile zwei Teile zu diesem Stecker. Einmal der Steckereinsatz rot und dann ein Gehäuse dazu. Was brauche ich genau ? Boaths?
And then there are two index numbers on the housing without any specific model information (G and H). What is the correct one, or what are the differences? Do both fit the LMM?
Sure, no problem! Here's the translation:
"Thank you in advance!"
Translated on 28-09-2026, 12:03.
No new posts Document A2 8Z0 MJ 2003, broken rear spoiler Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 Serpentine Belt Tensioner Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken 1.9 TDI AFN Camshaft: Causes & Fixes Diesel Engine Technology
No new posts Broken Fuel Line Holder: Causes & Fixes Diesel Engine Technology
No new posts Timing Chain Tensioner Broken Again? Diesel Engine Technology
No new posts Pierburg MAF Sensor Failure: Troubleshooting Diesel Engine Technology
