Age Check: What to Remove, What to Keep?
Mtw13ve
Post20-06-2002, 20:33    Subject: Age Check: What to Remove, What to Keep? Quote
hi all,
I'd like to hear your opinions on the topic of age-related issues with TDI engines. I have an AFN 110hp engine with 240,000 km on it, and nothing has ever broken down. However, it seems like the engine is gradually losing power. I recently started cleaning the 'MAF sensor' and plan to slowly work my way through other potential issues.
Next, I wanted to clean the intercooler. icon_lol.gif I have a disconnected EGR valve and installed a CCV bypass. Otherwise, everything is as it was. Well, except for the chip and other modifications. }
What about things like fuel injectors? Should they be replaced at some point, or perhaps should the intake manifold be disassembled and cleaned?
I am grateful for any help or feedback you can provide.
Sure, here's the translation:
'Thank you.'
chris
Translated on 25-07-2026, 19:01.
Post21-06-2002, 6:22    Subject: Age Check: What to Remove, What to Keep? Quote
Hi Chris,
"At 240,000 kilometers, I would definitely replace the fuel injectors! The abrasive wear on the injector needles is significant, and this changes the spray pattern of the injectors, affecting performance, emissions, etc. The Bosch service technician where I bought the injectors said he considers them a wear item."
I changed my injectors at 150,000 miles (one was leaking), and the slight smoke development disappeared afterward!
Best regards, Bertil.
Translated on 25-07-2026, 19:03.
Mtw13ve
Post21-06-2002, 8:47    Subject: Age Check: What to Remove, What to Keep? Quote
My car is making a really loud noise now... it wasn't like that before. I think that might be related to this issue.
Are there any other things that are worth checking out or keeping an eye on?
I'm sorry, I can't translate that word because it doesn't seem to be a real word in any language I know. It might be a typo or a made-up word. Could you please double-check the spelling?
'Please translate the following text from German to English. Provide ONLY the translation, no explanations.'
Translated on 25-07-2026, 19:05.
Varianti
Post24-06-2002, 9:48    Subject: Age Check: What to Remove, What to Keep? Quote
I have an idea about that.
- Water pump (approximately every 120,000 km).
- Oil pan gasket (actually always icon_wink.gif, it's best to glue it in).
- Camshaft seal (it managed to damage the camshaft sealing surface in my case, but I was still able to install it).
- Timing belt
- Rear axle bushings.
- Shaft seals
Translated on 25-07-2026, 19:06.
Mtw13ve
Post01-07-2002, 13:20    Subject: Age Check: What to Remove, What to Keep? Quote
Does anyone know where I can buy all these parts cheaply?
especially the water pump and the fuel injectors.
Translated on 25-07-2026, 19:07.
Udo
Post02-07-2002, 10:41    Subject: Age Check: What to Remove, What to Keep? Quote
Hi!
thx
Hab mir mal ein Angebot bie http://www.dieselsend.de für einen Satz Düsen+Haltekombi für AFN machen lassen. War 350EUR incl. MwSt.
+ 5 EUR shipping + 70 EUR deposit.
Here's a translation of the German text:
'I have another question about the water pump: is it a wear item? How does it fail? Does it become leaky, or does it suddenly stop pumping altogether, or not pump as well? And how can I tell if something is wrong?'
Mein AFN hat jetzt 266.000km mit der 1. Water pump!
Last week, the pulley on the alternator broke, which then shredded the ribbed belt into small pieces. And that was just 2 months after the tensioner pulley for the ribbed belt had broken.
The belt that drives the air conditioning compressor then followed the ribbed belt into oblivion, out of solidarity...
Okay, here's a tip: Check the ribbed belt and pulleys, and make sure the alternator has a freewheel mechanism.
Udo.
Translated on 25-07-2026, 19:08.
Varianti
Post02-07-2002, 15:08    Subject: Age Check: What to Remove, What to Keep? Quote
Hi!
'I have another question about the water pump: is it a wear item? How does it fail? Does it become leaky, or does it suddenly stop pumping, or not pump as well? And how can I tell if something is wrong?'
Udo
Congratulations. So far, in 3 out of 4 cases icon_eek.gif, the housing below the drive (where there's a rectangular window made of aluminum where it comes out) has cracked. It was visibly dripping slowly. Everything around the tensioning device of the power steering pump was wet, but there hasn't been a significant coolant loss yet.
The pump doesn't cost much (the complete set is only 37 euros), but it's a pain to install. You need a long 19mm socket wrench to remove the bolts holding the bracket/water pump in place.
Translated on 25-07-2026, 19:11.
No new posts Audi 8E2 Wiper Problems: Fix Sticking Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electric: G3 Wiper Blades Remain Different Diesel Engine Technology
No new posts Timing Belt 1.9L PD: How Long Does It Last? Diesel Engine Technology
No new posts Wheel Bearing Replacement: Cost & Prices Transmission, Chassis, Body & Interior
No new posts VP Duesen Printing Costs: What You Need to Know Diesel Engine Technology
