Diagnosis: Common Questions & Answers
tekkno
Post05-08-2004, 11:06    Subject: Diagnosis: Common Questions & Answers Quote
hello
I have some questions about the VAG-COM 302.2 software.
Okay, so I've now connected the T4. I noticed that the pin configuration of the OBD port was as follows: pin 16 = 12V, pin 4 = ground, pin 5 = L-line, and pin 7 = K-line.
Although the L-line should actually be on pin 15, right???
'So, I looked at the pin assignments for the T5, and it turns out that pins 1, 4, 5, 6, 7, 14, and 16 are all used, with 12V present between pins 4 and 16. What are the other pins for? Probably for additional sensors. That would mean I need a different interface, wouldn't it? I thought OBD interfaces had standardized pin assignments.'
'Anyway, I once connected the T4 and tried to access the OBD2 menu. icon_sad.gif Then it said, 'Vehicle is not OBD2 compatible,' } even though there is an OBD connector present. (This is a 1998 model year).'
I was then able to connect to the engine (01), ABS brake (03), and external WFS (25).
was ist eigentlich ext. WFS???
What can I actually do with the 'wag-scope'?
What could that mean: (motor 01)
'One error found:'
00625 - Speed signal.
27-00-implausible signal
Can the program actually read out data from every control unit in VAG vehicles?
'Thank you.'
'Hello'
Translated on 30-09-2026, 16:42.
joergs
Post05-08-2004, 11:50    Subject: Diagnosis: Common Questions & Answers Quote
Oh my god...
The presence of an OBD-II connector does not necessarily mean that the vehicle is OBD-II compliant. OBD-II compliance refers to the implementation of the OBD-II protocol within the vehicle's control unit (ECU) software. Variations in pin assignments are also possible. In newer models, the diagnostic connector may also include CAN or a 2.0 K-line, for example. Furthermore, newer vehicles can often only be diagnosed via CAN. Also, the L-line may not always be required.
This is the standardized pin configuration.
1. Manufacturer-specific.
2 J1850 Bus+
3 manufacturer-specific examples.
4 Vehicle Mass
5 Signal Mass.
6 CAN High (J-2284)
7 ISO 9141-2 K outputs.
8 manufacturers specifically.
9 manufacturer-specific.
10 J1850 Bus.
11 manufacturers specifically.
12 manufacturers specifically.
13 manufacturers specifically.
14 CAN Low (J-2284)
15 ISO 9141-2 L output.
16 Battery Positive Voltage
Okay, pay attention! And maybe try using Google sometime...
Regarding the other questions: use the search function, the VAG-COM manual, and your own brain!
Translated on 30-09-2026, 16:45.
No new posts Glow Plug Information: Types, Function & More Technical Articles
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A8: Driver Side Control Units Malfunction Electrical Systems, Vehicle Electronics, Multimedia
No new posts Vag-Com: Climate Issues & Troubleshooting. Diesel Engine Technology
No new posts Car Accident: Questions & Answers Transmission, Chassis, Body & Interior
No new posts A4 TDI AFN: Performance Questions & Tuning (Kassel/G�... Diesel Engine Technology
