Wobbly Steering Wheel When Braking? Causes & Fixes
ARL-TDI
Post03-08-2004, 12:58    Subject: Wobbly Steering Wheel When Braking? Causes & Fixes Quote
Hello!
Well, I've been having this problem for the past 8 months. I noticed it back then too, when I had to brake from, say, 160 km/h down to 100 km/h. In April, I got new brake discs and pads, but the problem persists.
Does anyone have any idea what can be done about it, or where the problem actually lies?
As I said, the new tires now have 10,000 miles on them...
EDIT: I'm actually considering installing the brake system from a Golf R32 in the front.
Translated on 19-08-2026, 1:59.
Brunhilde
Post03-08-2004, 16:40    Subject: Wobbly Steering Wheel When Braking? Causes & Fixes Quote
I would check the front axle for worn wheel bearings or damaged ball joints.
When the brake applies force to the wheels, that force is transferred to the steering wheel through the play in the system.
Translated on 19-08-2026, 2:00.
haehnlein
Post03-08-2004, 19:29    Subject: Wobbly Steering Wheel When Braking? Causes & Fixes Quote
A small piece of dirt or debris between the disc and hub, or between the rim and disc, can have devastating consequences (e.g., an old piece of rust). Clean the contact surfaces thoroughly with a wire brush (ideally a flexible grinder with a wire wheel attachment). I had this problem before, and this solved it for me.
____________
Kein Auto mehr!
ARL-TDI
Post03-08-2004, 23:28    Subject: Wobbly Steering Wheel When Braking? Causes & Fixes Quote
Thanks for the suggestions; I'll take it to the dealership, as my warranty just expired... but this problem has been going on for a while.
By the way, when I first noticed this, I still had winter tires on. It's still happening with my Santa Monica tires... let's see what it is.
Translated on 19-08-2026, 2:01.
ARL-TDI
Post03-08-2004, 23:30    Subject: Wobbly Steering Wheel When Braking? Causes & Fixes Quote
Oh yes: when it was first checked in January, the car had 33,000 km on the odometer, and now it has 66,000 km.
Translated on 19-08-2026, 2:02.
ARL-TDI
Post05-08-2004, 0:40    Subject: Wobbly Steering Wheel When Braking? Causes & Fixes Quote
Okay, I just bought a brand new Audi S3 brake system for the front axle, so I'll be careful to keep it clean and free of dirt between the rotors during installation. My workshop will check if anything is worn out.
ARL-TDI
Post16-08-2004, 9:02    Subject: Wobbly Steering Wheel When Braking? Causes & Fixes Quote
The brake is installed now.
Conclusion after 1000 km of driving: the braking performance is incomparable. Excellent; I wouldn't say it's a Porsche-level brake, but it's definitely a brake that lives up to the car's performance.
'...I'm also no longer experiencing any vibrations in the steering wheel, but I think that was probably due to the preemptive installation of the new brake discs, as I can't imagine that the discs themselves would have a 'flat spot'.'
Translated on 19-08-2026, 2:03.
thekk
Post17-08-2004, 10:47    Subject: Wobbly Steering Wheel When Braking? Causes & Fixes Quote
I'm experiencing the same problem with my Ibiza 6L PD 96kW.
I bought the car new, and after about 8,000 km (winter driving), I experienced strong vibrations when turning. On snow and ice, the car wouldn't stop because the ABS system was constantly activating even with very light braking.
Following the recommendation of my mechanic (diagnosis: warped brake discs), I purchased hardened, slotted brake discs from Ferodo. Unfortunately, the problem has reappeared after just under 32,000 kilometers.
My mechanic claims that it's due to my driving style and that the windshields can't withstand it. However, I think that's nonsense because while my driving is brisk, it's always anticipatory. I rarely drive on the highway at all.
Recently, I noticed that when I stop on a slight incline and then release the brakes, the car only rolls backward slowly, or not at all, depending on the steepness of the incline.
Could it be that the brakes aren't releasing properly and are therefore constantly rubbing?
How else could I verify this?
I had my brakes checked at a Volkswagen dealership around the corner about four weeks ago.
There, the right front brake had a significant downward deflection of up to 1 millimeter.
Last week, I went to my authorized service center to report the issue. We took the car to two inspection stations affiliated with DEKRA, and everything was fine.
What could have caused all of this?
The front brakes provide approximately 3.3 kN of force, while the rear brakes provide almost 2.4 kN.
Does anyone know if this is too much for my vehicle?
Translated on 19-08-2026, 2:06.
mcgyver2k
Post17-08-2004, 11:15    Subject: Wobbly Steering Wheel When Braking? Causes & Fixes Quote
Jack up the car, secure it properly, and try to turn a wheel by hand. It shouldn't require significant force.
01er Skoda Fabia Combi ATD
Translated on 19-08-2026, 2:08.
Post17-08-2004, 11:39    Subject: Wobbly Steering Wheel When Braking? Causes & Fixes Quote
thekk wrote:
... I obtained hardened, perforated discs from Ferodo. ....
I can tell you a few things about that Italian junk car.
I installed a set of Ferodo pads on my racing car, and after 400 km, they were completely worn out.
The reason is that the discs are so hard that they only provide usable friction values at extremely high temperatures. However, these discs then achieve this friction value very abruptly. If you're not careful and reduce the pressure on the brake pedal, you will damage the discs. Due to the steel hardness, the discs cannot expand properly and warp very quickly. This results in extremely unpleasant vibrations.
When used with Ferodo racing brake pads, heat dissipation is improved, and this issue should no longer occur. However, these pads have an extremely high operating temperature of over 850°C, making them completely unsuitable for road use.
These brake discs are completely unsuitable for a road car.
In competitive use, they are good for only one (or possibly two) events, after which they should be retired.
Translated on 19-08-2026, 2:10.
thekk
Post18-08-2004, 10:05    Subject: Wobbly Steering Wheel When Braking? Causes & Fixes Quote
Hmm, that wasn't mentioned in the description though...
Unfortunately, there were no other perforated or slotted windshields available for my car at that time, so I had no choice.
However, I also have Ferodo brake pads...
I guess I'll have to look for something else then.
Perhaps another tip? ATE?
Translated on 19-08-2026, 2:12.
Post18-08-2004, 11:23    Subject: Wobbly Steering Wheel When Braking? Causes & Fixes Quote
Vieleicht noch einen Tipp? ATE?
At least it's better than Ferodo.
By the way, I recently had a very good experience with a combination of Ferodo ID346 brake pads (which are roughly equivalent to the DS2500 today) and ATE brake discs. It was cheap and effective.
If you want something decent (but unfortunately very expensive), then take a look at what the companies on the islands offer.
Sure, I understand. Please provide the German text you would like me to translate into English.
http://www.mintex.co.uk/
Translated on 19-08-2026, 2:13.
christians
Post18-08-2004, 12:58    Subject: Wobbly Steering Wheel When Braking? Causes & Fixes Quote
My experience with ATE:
/viewtopic.php?t=4175&postdays=0&postorder=asc&highlight=ate%20rhone*&start=24
Gruß Christian
Translated on 19-08-2026, 2:14.
No new posts Doku Lupo 6X1 MJ 2002, Vibrationen im Lenkrad Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentary, low-frequency noise from rear brakes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Wheel Problems: Wobbles & Pulls Transmission, Chassis, Body & Interior
No new posts Dito! Bremsen 1000 KM neu,Lenkrad schlägt vor und zurück Transmission, Chassis, Body & Interior
No new posts Replacing the steering wheel of a 2009 VW Passat B6 with ... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Steering wheel vibration when accelerating? Diesel Engine Technology
