24-07-2006, 14:32 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
The air conditioning in the Leon doesn't really get very cold.
I think it just needs some refrigerant topped up.
What does something like that usually cost?
Thank you.
Translated on 10-10-2026, 5:24.
Profile PM Garage |
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
24-07-2006, 14:51 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
Can you rule out the usual suspects?
- One of the fans has failed, level 1 is not active.
- Defective temperature control flap actuator.
At least on the G IV, both of these things can happen, as the Leon isn't that different technically.
Does the error memory contain any information?
I once paid 140 DM in 1999 for the evacuation and refilling, but it didn't last long...
The capacitor is defective, with a full warranty of up to 4 years / 100,000 km, and the dealer did not inform me about this at the time  .
Translated on 10-10-2026, 5:25.
Profile PM Garage |
24-07-2006, 15:10 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
During a test a few weeks ago, the fans started up.
I haven't checked the temperature valve or the F-memory yet (haven't had the chance).
Today, the VTG payment is due.
Translated on 10-10-2026, 5:26.
Profile PM Garage |
Arno Guest
24-07-2006, 19:18 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
The cost depends on the amount of refrigerant that needs to be refilled. The system in my Passat once had to be completely refilled. I paid 85 euros including the contrast agent and 1150g of R134a, but that was without the refrigerant being evacuated first, since it was completely empty beforehand. Surprisingly, they were even the cheapest among all the competitors  .
Today, the VTG is due...
Did you buy a car or find a job  ?
Translated on 10-10-2026, 5:27.
24-07-2006, 21:23 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
Thank you for the information.
The Leon is not mine, but I take care of him  .
The VTG... of course, it's "she." The stupid woman suddenly goes smoothly and evenly. So, everything that was loose is reattached (everything except the two curved  .
Maybe all that high-speed driving at 190 km/h yesterday actually made a difference.
Translated on 10-10-2026, 5:28.
Profile PM Garage |
25-07-2006, 7:44 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
HI,
The diagnostic tool didn't report any error codes, and the actuator diagnosis seemed plausible based on what was heard and felt.
Last night (it's quieter then), I could hear quite distinct flow noises in the refrigerant circuit. The hissing and gurgling sounds were still audible for some time after turning off the engine, and they clearly came from the area of the air conditioning system.
Then I guess I'll have to get it filled.
Thank you.
Translated on 10-10-2026, 5:29.
Profile PM Garage |
25-07-2006, 8:05 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
Error codes: Read directly from the control panel, or retrieved via diagnostics?
The actuator motor usually triggers an error code initially, and this error is only readable through the diagnostic system, not on the control panel.
Translated on 10-10-2026, 5:30.
Profile PM Garage |
25-07-2006, 9:41 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
Selected by the women's interest group committee.
I don't understand the control panel of the 1M-Climatronic anyway  .
Unfortunately, I don't have a useful label file either.
Translated on 10-10-2026, 5:31.
Profile PM Garage |
Jochen_145 Guest
25-07-2006, 16:01 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
When was the refrigerant last refilled?
Contrary to popular belief, air conditioners are not maintenance-free.
Actually, the refrigerant should be refilled every two years.
An air conditioning system that was originally well-sealed will gradually lose refrigerant over time.
Often, this issue isn't noticed until 4 to 5 years later, when the cooling performance has significantly decreased and the fan immediately switches to the medium setting as soon as the air conditioning is activated. However, at that point, usually less than 50% of the refrigerant remains in the system.
'I recently also paid €85 for a refill. The price seems to be stable in this area. With some providers, the price depends on the amount of refrigerant used. R-134a is not cheap...'
Best regards, Jochen.
Translated on 10-10-2026, 5:32.
25-07-2006, 16:09 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
I think that...
The Leon hasn't seen a mechanic for its air conditioning system since it was born in 2000.
Translated on 10-10-2026, 5:34.
Profile PM Garage |
Arno Guest
25-07-2006, 17:30 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
I think that
The Leon hasn't seen a climate service (air conditioning service) since it was born in 2000.
It was probably the same situation with my Passat. When I bought it, it was also 6 years old. After I bought it, I immediately had the A/C system serviced (even though the cooling performance was still just barely acceptable). In any case, only half of the coolant was left. You certainly can't generalize from this, but just as a point of reference  .
Boro Guest
26-07-2006, 12:23 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
I once paid 69 euros for this service during an ATU promotion in 2004! The refrigerant is extracted and new refrigerant is filled at the same time.
Translated on 10-10-2026, 5:35.
euwing Guest
28-07-2006, 11:17 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
Hello.
A month ago, the refrigerant in my 1997 Golf was topped up because the cooling performance was decreasing. Since more than 50% of the original refrigerant was still present, it cost €52. Of course, the old refrigerant was also extracted beforehand.
Translated on 10-10-2026, 5:36.
28-07-2006, 14:09 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
... and where was it so cheap?
Profile PM Garage |
golf3schrauber Blaumann
Joined: 10/15/2003 Posts: 140 Karma: +1 / -0 Location: Erkelenz
31-07-2006, 19:08 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
Go to a specialized company that handles climate control systems, including cold storage facilities and large refrigeration systems. They will be able to help you with this, and they generally have more expertise in what they do.
I work in the aviation industry, and we always have someone who is responsible for refilling the air conditioning systems of the aircraft. They also maintain the cooling rooms.
He fixed my Polo the other day for 40 euros. The sound system was completely empty.
He does everything manually, not with an automated machine.
Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 10-10-2026, 5:37.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1513 Karma: +647 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
04-08-2006, 19:49 Subject: AC Recharge Cost: Get Your AC Refilled Now! |
Hi.
A filling costs between 30 and 50 euros with us, depending on the amount of material used.
We do have a filling station, but I prefer to walk; it's much faster.
Best regards, Rüdi.
Translated on 10-10-2026, 5:38.
Profile PM Garage |
