hb2000 Guest
12-10-2004, 21:27 Subject: TDI Timing Help: Strange Error Message? |
hello
I once tried using VCDS to check the TDI timing and received a message that made me a bit concerned: 'timing is too advanced to be plotted.' After putting in a lot of effort to get the engine temperature to 85 degrees Celsius, I received this message. The car is a Passat 3B, TDI, AJM with 115 hp. Is it really possible that the timing is that far advanced, or is this message just a joke? The car seems to be running fine overall and sounds like any other PD diesel. The timing belt was replaced at 120,000 km, and now the car has 155,000 km on it and should still be working for a while. I would appreciate any answers that can help me with this.
Best regards.
hb2000
Translated on 11-10-2026, 3:57.
wolfi_b Profi-Schrauber
13-10-2004, 6:27 Subject: TDI Timing Help: Strange Error Message? |
The error message simply means that the injection point is outside the visible range. 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 11-10-2026, 3:58.
hb2000 Guest
13-10-2004, 8:07 Subject: TDI Timing Help: Strange Error Message? |
But the Passat is actually running perfectly fine - shouldn't that be noticeable???
Translated on 11-10-2026, 3:59.
13-10-2004, 8:21 Subject: TDI Timing Help: Strange Error Message? |
Normally, yes, due to factors like poor starting behavior and increased fuel consumption.
Now I've looked it up: AJM is actually a PD engine. I somehow assumed it was a VP, and unfortunately, I'm also unsure about the injection start timing for PD engines.  1993 Audi 80 B4 1Z
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
13-10-2004, 8:29 Subject: TDI Timing Help: Strange Error Message? |
What do the data blocks indicate? Tschüss
Michael II
Translated on 11-10-2026, 4:00.
MichaelJ Schrauber
Joined: 04/05/2004 Posts: 53 Karma: +6 / -0 Location: Bonn
13-10-2004, 9:23 Subject: TDI Timing Help: Strange Error Message? |
Could it be that, in a PD (Pump-Düse) engine, the TDI-Timing function (TDI-Graph) simply doesn't work at all?
On the TDI-Timing website, it states:
Quote 1:
Note: This DOES NOT apply.
to 1.9 PD (unit injector) engines.
Quote 2:
Note to 1.9 PD (pump düse, also unit injectors) owners: you cannot, and do not need to, set your timing electronically. There are no graphs published for the simple reason that the timing is set using a dedicated VAG locking tool when changing the timing belt  .
I translated it in a way that indicates there are no electronic adjustments for the PD motor.
but rather the start of injection using a VW tool (similar to the round pin used in the VP-ESP).
is determined when replacing the timing belt.
Greetings.
MichaelJ Audi 80 TDI , MKB: 1Z, KM >455.000 r.i.p.
Passat 3B TDI, MKB: AJM, KM >331.000 r.i.p.
Audi A4 Cabrio Quadro, MKB: ASB KM> 119.000 -ZKD defekt, 6 Zylinder voller Riefen ATM 16tsd €! ATM 2 Tage vor Garantieende getauscht, da drei defekte Injektoren zwei Jahre lang nicht getauscht wurden.
Translated on 11-10-2026, 4:01.
Bertil Profi-Schrauber
13-10-2004, 9:58 Subject: TDI Timing Help: Strange Error Message? |
"Those who can search have a clear advantage."
/viewtopic.php?t=5408&highlight=misconfiguration+pd
/viewtopic.php?t=5257&highlight=setting Gruß Bertil
Translated on 11-10-2026, 4:02.
MichaelJ Schrauber
13-10-2004, 11:01 Subject: TDI Timing Help: Strange Error Message? |
@ Bertil
Thank you for the links - now I can imagine how to adjust a PD motor.
It works, if I ever happen to have a TDI with a PD engine  .
But my statement that TDI timing only works with VP engines - and that's why...
Is that what the thread is about, or am I wrong?
Greetings.
Michael. Audi 80 TDI , MKB: 1Z, KM >455.000 r.i.p.
Translated on 11-10-2026, 4:03.
Joined: 04/12/2002 Posts: 18139 Karma: +805 / -0 Location: St.Gallen 2018 Volkswagen T6
13-10-2004, 11:11 Subject: TDI Timing Help: Strange Error Message? |
Yes, the TDI timing checker is only for engines with a distributor injection pump.
Translated on 11-10-2026, 4:04.
Profile PM WWW Garage |
hb2000 Guest
13-10-2004, 21:16 Subject: TDI Timing Help: Strange Error Message? |
Thanks for the info - I probably could have figured that out myself.
The PD (phase difference) is only adjustable using the dial indicator; nothing else works.
Translated on 11-10-2026, 4:05.
joergs Guest
13-10-2004, 21:20 Subject: TDI Timing Help: Strange Error Message? |
What are you talking about? Are you referring to the timing or the preload setting of the PDEs? *looks questioningly*
hb2000 Guest
15-10-2004, 10:28 Subject: TDI Timing Help: Strange Error Message? |
*valve timing*
