Cannot open navigation control unit (37)??!!!
MONCHI
Post05-10-2004, 19:37    Subject: Cannot open navigation control unit (37)??!!! Quote
Hey everyone,
..I treated myself to an Audi Navi Plus for my little Ibiza. It took some work to get it installed, but it was worth it; everything works perfectly. I just have one problem: when the navigation system turns on, I get an error message that says 'TMC tuner disturbed/not found.' ... This is normal, since I don't have one connected, but you can disable it in the navigation control unit (ECU). However, I can't access the ECU. I have VAG-Com versions 3.02 and 0.81. When I go to module 37, the navigation screen sometimes flashes 'Diag.' for a second... but VAG-Com can't open the module icon_confused.gif icon_confused.gif. What could be the problem? In VAG-Com version 3.02, there's an option that says 'change baud rate etc. for newer ECUs'... I've already tried that, but it doesn't do anything!
...does anyone have any ideas??
Greetings,
Cheers,
Warmly,
Sincerely,
(or simply)
Hey,
Love, (if appropriate)
XOXO, (if appropriate)
Monchi.
Translated on 20-07-2026, 1:13.
Karma: +807 / -0   Thank you, like it!
Post05-10-2004, 20:00    Subject: Cannot open navigation control unit (37)??!!! Quote
Perhaps you should try it using a) current diagnostic hardware that is actually reliable and b) a recent version of VAG-COM.
PS: I would be happy to send you the current professional adapter for two weeks for a deposit of €330. This way, you can see what is possible with proper hardware and the latest software version. Of course, you will get your money back after returning it.
Translated on 20-07-2026, 1:15.
MONCHI
Post06-10-2004, 7:16    Subject: Cannot open navigation control unit (37)??!!! Quote
...I have a relatively inexpensive diagnostic tool (it doesn't use optocouplers or whatever they are called).
.......everything else works perfectly, I can get in everywhere without any problems icon_lol.gif .......but the navigation doesn't work !! icon_confused.gif
Let's see!
Monchi.
Translated on 20-07-2026, 1:16.
MONCHI
Post06-10-2004, 20:06    Subject: Cannot open navigation control unit (37)??!!! Quote
I managed to solve the problem myself today!
'The ISO connector with the K-line wasn't making full contact with the navigation system. I simply unplugged it and plugged it back in, and immediately I was able to access the control unit and disable the TMC tuner (I don't have one, so otherwise a silly error message appears every time I turn it on).'
Greetings,
Cheers,
Warmly,
Sincerely,
(or simply)
Hey,
Monchi.
Translated on 20-07-2026, 1:17.
No new posts Lupo Door Problems: 6X1 MJ 2002 Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Do windows open on their own? General Tips
No new posts Audi B5, 1999 - Retrofitting from small navigation system... Transmission, Chassis, Body & Interior
No new posts Rear door won't open Transmission, Chassis, Body & Interior
No new posts Navigation CD cannot be ejected Electrical Systems, Vehicle Electronics, Multimedia
No new posts Stuck Hood: How to Open & Fix It Transmission, Chassis, Body & Interior
