Golf 4 Seat: How to Fix the Clicking Noise
Holger247
Post04-10-2004, 10:11    Subject: Golf 4 Seat: How to Fix the Clicking Noise Quote
seit einiger Zeit stelle ich ein knacken im Fahrersitz fest, zB in starken Kurven, oder bei stärkerem Bremsen. Meiner Ansicht nach kippt der Sitz dann auch leicht nach vorne. The car has 120,000 kilometers on the odometer.
When you wiggle the seat, you can see that the rollers in the seat rails have some play, but it's almost the same on my friend's A3 (with 20,000 km) - except that it doesn't make any noise there.
Does anyone have any ideas?
I read somewhere that a weld seam was broken in an A4. Could that be the case here as well?
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 15-09-2026, 18:29.
Michael II
Post04-10-2004, 11:32    Subject: Golf 4 Seat: How to Fix the Clicking Noise Quote
Do you have the Easy Entry function?
If so:
The noises can occur when the seat is subjected to lateral stress, for example, when sitting down, standing up, or when driving through a curve.
Cause:
The protective cap on the Easy Entry release mechanism is missing.
Solution:
- Unlock the support and fold it forward.
- If the plastic protective cap on the Easy Entry release (located on the side of the seat) is missing, a new cap must be installed (clipped in).
Tschüss
Michael II
Translated on 15-09-2026, 18:30.
DocSnydor
Post04-10-2004, 12:18    Subject: Golf 4 Seat: How to Fix the Clicking Noise Quote
If so:
And if not? I'm having the same problem...
Translated on 15-09-2026, 18:32.
AndreasG
Post04-10-2004, 12:56    Subject: Golf 4 Seat: How to Fix the Clicking Noise Quote
The seat in my '98 Golf IV also started to creak quietly. As it got louder...
I just took a quick look underneath. Here's a picture of it.
http://www.picupload.net/files/20040410/1096890490.jpg
The entire weld seam was completely broken. It was also amusing to see VW's attempt to fix the creaking noise.
to remove: The white residue from the spray oil is still clearly visible.
Post04-10-2004, 13:08    Subject: Golf 4 Seat: How to Fix the Clicking Noise Quote
AndreasG wrote:
It's also amusing how VW tried to address the creaking sound.
icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif icon_eek.gif
I hope you knocked them out right away! Something like that is absolutely unacceptable.
Translated on 15-09-2026, 18:33.
Holger247
Post04-10-2004, 13:15    Subject: Golf 4 Seat: How to Fix the Clicking Noise Quote
Oops, that looks bad. I'll check right away to see if it's broken on my end too.
What did you do then? Did you weld something? Or did you install a new seat frame?
Can this be easily welded? Is there a side airbag involved?
@MichaelViewing profile: Michael II: I have a 4-door model, so it doesn't have the Easy Entry seats.
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 15-09-2026, 18:34.
AndreasG
Post04-10-2004, 13:17    Subject: Golf 4 Seat: How to Fix the Clicking Noise Quote
VW was trying to make the repair a little cheaper for me (around 250 euros for the seat frame).
aber ich hatte dankend abgelehnt. Die reparieren mir nichts mehr. I have the seat.
It was rebuilt and welded. Now it's as quiet as it was on the first day.
Edit: I also have a 4-door model. The connector for the side airbag can be easily removed and secured with a shorting plug. I had the instructions for disassembly.
Here from the forum.
Translated on 15-09-2026, 18:35.
Holger247
Post04-10-2004, 13:34    Subject: Golf 4 Seat: How to Fix the Clicking Noise Quote
I just checked, and the weld seems to be okay for me - thankfully. However, the cracking sound is still present.
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 15-09-2026, 18:36.
Julian
Post04-10-2004, 16:40    Subject: Golf 4 Seat: How to Fix the Clicking Noise Quote
Well, EasyEntry usually has little to do with this problem. In my Golf 4, the seat rails were replaced, and only then was there finally peace and quiet in the car...
Holger247
Post04-10-2004, 16:46    Subject: Golf 4 Seat: How to Fix the Clicking Noise Quote
@JulianViewing profile: Julian:
Can the seat rails be replaced? Aren't they part of the bodywork, or are they welded to it?
Was this due to wear and tear, or was it present from the beginning?
GIV - 98 - ALH
Touran 5T 2.0 TDI
Julian
Post04-10-2004, 16:54    Subject: Golf 4 Seat: How to Fix the Clicking Noise Quote
As far as I remember, they are screwed into the bottom. You also have to loosen them to remove the seat.
to expand.
I had a model from 12/98, and after about 2 months, the squeaking started. After a few mechanics had the 'pleasure' of using their silicone spray cans (the pool of silicone grease under my seats was unbearable), VW finally agreed to replace the seat rails. After that, everything was finally quiet...
Translated on 15-09-2026, 18:37.
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cracking noise from rear axle, Audi A6 4F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Question about the location of the crankshaft sprocket Diesel Engine Technology
No new posts Airbag Seat Replacement: Recaro Conversion Guide Transmission, Chassis, Body & Interior
No new posts Pinout of the MFA (Golf IV) Transmission, Chassis, Body & Interior
No new posts Golf 4 Water Leak: Causes & Solutions Transmission, Chassis, Body & Interior
